Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
My hotpoint washing machine door wont lock, my washing machine fuse blew in the plug, but the machine was in cycle at the time, the door released letting me get the wash out. When i got the power back on (changed the fuse) The door will no longer lock to let me start a wash agian....... Cheers if you can help
SOURCE: Hotpoint WD52 washing machine door not opening
hi when your fuse blew it welded contacts inside door lock mech replace and all will be fine **** it could have been the door lock that blew fuse but check carbons whilst you have top of ALL THIS IS DONE WITH THE PLUG OUT DONT FORGET
Posted on Sep 20, 2007
  • 209 Answers
SOURCE: Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Posted on Sep 25, 2007
  • 1294 Answers
SOURCE: Hotpoint WD420 - Stuck in wash cycle
Suggestion: Plug off the wall first. Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Check out user's manual. Good luck. Also check if your inlet into the machine is not clogged.
Posted on Oct 01, 2007
SOURCE: Hotpoint WD129 Wash programme stuck
The solution was correct it was the heating element, after it was replaced the machine now works fine !!!!
Thanks for the help !!
Posted on Dec 22, 2007
eagle338
  • 4889 Answers
SOURCE: hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Oct 01, 2008
The door on my Hotpoint Aquarius Dryer CTD00 pops open during cycle is it the door catch that's worn?
If the door latches correctly at the time of wash then it is possible that there is a false trigger to release the door, if so you need to check on the lock.
check on this link for tips: Door lock
Jan 12, 2013 | Washing Machines
Hotpoint aquarius extra wma40 - door locked light is flashing and want lock. also before this happened a sound from the machine like an explosion which blew out fuse in the house. please advice
Hi.
I suspect that the top control board has blown , this happens when the brushes wear out in the motor, and short circuit the motor armature, which in turn blows the control board.
Either way it is likely to be an expensive repair, my advice to you would be to buy a new washer if it is more than 5 years old.
I know from experience that this is the most likely course.
Nov 13, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint wf540 will not start a cycle it very quicly steps to wash light showing but nothing happens door locked light is not illuminated.Just prior to this fault the fuse in the mains plug had blown.I...
1st you need to know if power is getting to machine, Next could be door interlock switch faulty the fact the fuse blew indicates possible short circuit/ excess current draw occured also check motor brushes assuming machine fills with water 1st
Nov 05, 2009 | Washing Machines
Wash cycle will not start door locked led flashes
sound like water has been splashed over circuit
board. dry out and replace any damaged components.
Mar 15, 2009 | Hotpoint WMA31 Front Load Washer
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Sep 20, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
352 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
