Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
MY C drive Booting drive is 30GB, in side c drive file properties is showing 20GB bt free space is showing 2GB
  • 19,396 Answers
That can happen when the partitioned space is smaller than the maximum space available on disk.
The best way to extend current partition is by re-partitioning and re-formatting the hard drive.
Doing this will delete Operative system and all data on drive, therefore you will need to reinstall Windows , software and drivers, and backup and restore your data.
Moreover those missing couple of Gigabytes on disk space may have been reserved by laptop manufacturer to host a recovery partition.
Unless you have to reinstall system for other resons, better leaving partition as it is and freeing some space on disk, maybe removing obsolete software, cleaning temporary files, and moving some of your files on an external disk.
Posted on May 17, 2009
  • 27 Answers
Its probably formatted not to use the entire space of the disk, is there another partition or "D" drive where your restore/backup stuff is? That could be take up the rest of the space. Hard disks are always described as being a certain size but can be formatted by windows tlo split up the drive into smaller chunks called partitions. Your C drive/partition might be way less then 30Gb therefore only showing up as 22Gb
My Satellite Pro S200 running XP has a 30gb C drive and 100gb D drive. The computer constantly whines that is low on C drive space. I have moved everything possible to D drive, cleared 2.8gb space a few...
windows - start - control panel - administration - computer administration - hard drive administration - resize your C drive to bigger capacity, but first resize D drive to smaller capacity to free a space for C drive enlarge, then apply setting, reboot, my computer drive C right click - propertis- service - defragmentation and same operation and chek it for errors
Nov 15, 2012 | Toshiba Satellite Pro P300-28L 17-Inch...
Flash Memory CRUZER shows only 2 Mbps instead of 4
are you talking about the space on this 2GB cruzer
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
right click on your usb drive select properties you will see ammount of space used and free space
if you need more help with this post a reply
hope it helps
Aug 24, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My pen drive is of 2GB i dont know how but now it showing 1.50GB as used space and only 500mb odd free space and its completely empty,there is no data inside plz solve my problem
Insert the USB stick in your computer, then go to "Start" then "My Computer", locate the USB icon and right click and select "Properties". From there you can do a format of the stick. This will erase all the data including some hidden files that you might have and solve the problem.
Note that even though it says 2Gb, the data you can use is slightly less. This is true for any storage device out there.
Nov 10, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The properties show that the usb is using 1.5gb of space, but I am unable to view any of the files that are using up that space. Any ideas how I can go about viewing these files?
You could try viewing them from a different computer, possibly one running a different operating system. Are you using the computer that the files originated from?
Oct 14, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
New hard drive only shows 13gb free space
its because the update and all the gamerpics and themes that come with it take up space
Jan 20, 2010 | Microsoft 20GB Hard Drive for Xbox 360
Vista Hard Disk eating itself
you need to free up disk space by deleting temp files and old unused web pages. These mount up over time and if you do not watch it... the hard drive fills up pretty quickly. If you have Windows 7 or Vista go to control panel-system security-administrative tools there you get
a menu which says free up disc space.... click on it and get rid of the **** you do not need.
Jan 06, 2010 | Computers & Internet
Sandisk 4gb pendrive not working
Best thing to do is format the drive. Dont go for a quick format
Jun 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba 2GB USB Flash Drive Capacity Problem
format the Flash Drive in in slow mode
click on the properties of flash drive
then click on tools then CLICK ON DEFRAGMENT NOW TAB
Mar 11, 2008 | Computers & Internet
Computers & Internet Logo
133 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
David Payne
David Payne
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
