Question about Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112)
On start-up a window entitled ?Program Compatibility Assistant? appears with the following message: This driver is blocked due to compatibility issues. The driver identified is: ?Driver: Sonic Solutions DLA? This window keeps popping up frequently.I have tried to remove this offending driver through the Vista remove programs process without success.
  • 8 more comments
  • techfriend May 17, 2009
    simply used control panel to uninstall update KB929427!
    Then click on shutdown.
    Then reboot computer and No compatibility assistant errors!!
    You are awsome
  • Atlanta102 May 11, 2010
    Can you update your copy of Sonic Roxio by visiting their website and seeing is there an update?
  • sian snedden
    sian snedden Jan 20, 2017
    do i have to down load a site to connect my tom tom to my computer?
  • sian snedden
    ps. i have windows 10, does that matter?
  • kamesakbar
    kamesakbar Jun 23, 2017
    advanced ip scannerhttps://www.advanced-ipscanner.com/ is dependable network IP scanner that scans your Wi-Fi network or LAN to provide information about the computers connected to it. Advanced IP Scanner is a Network Scanner free for your PC. Advanced IP Scanner is a very fast, IP scanner and port scanner.
  • Jordan Davidson
    Jordan Davidson Aug 03, 2017
    I'm sure you already know about how it will take away the option you would otherwise have of choosing a school based on how much financial aid they give.Essay Writing Service
  • laura martin
    laura martin Aug 30, 2017
    just a couple of days left before the due date? We have a group of profoundly proficient, experienced and gifted article journalists and they will give you an especially elegantly composed exposition to guarantee your prosperity. Essay Help UK
  • Neil Jakson
    Neil Jakson Sep 14, 2017
    Program Compatibility Assistant? appears with the following ... The driver identified is: ? ... I have tried to remove this offending driver through the Vista remove ... pop-up window appears with the message that the driver is blocked due .... The Roxio Sonic Solutions DLA problem went away for a little while.
    dissertation Writing Service
  • Anonymous Dec 16, 2017
    Check driver updates first
    song contest new rnb songs find new music
    New Friend:
Note that some software needs to be configured to stop starting themselves when the PC boots or they will just continue themselves to the list of start up again. In this situation, there is usually a setting in a program's options to stop it from starting with Windows.
Posted on Dec 28, 2017
    Top Expert:
  • Microsoft Master
  • 14,161 Answers
Posted on Jan 15, 2017
    Master:
  • 147 Answers
Testing to see if I get more views.
Posted on Mar 09, 2015
Drivers not compatible with window 7
Hello Witonada, what type of driver issues are you having, Windows 7 comes loaded with a compatibility assistant that will install native xp or vista drivers for windows 7. to do so put the driver on your desktop, right click and choose the capability assistant then select try recommended settings, This option allows us to test run the program to see if the new compatibility settings fix the issue. Click on Start the program to begin testing it out. After testing the program and determining if the settings work or not click on Next. This will finish your new installation. In some instances the assistant may ask if the program worked in another platform say yes and choose windows xp sp3. walla your all set .
May 25, 2011 | Computers & Internet
When trying to install Math Workshop I received the following message: cannot start or run due to incompatibity with 64 bit versions of Windows. Is there a version available that is compatable?
right-click on file
go to properties
then click the tab that says compatibility
then go run this program in compatibility mode for:
usually the Windows XP (service pack 3) works for me.
The image below is an example of what the screen should look like. It`s from a different game but it`ll look similar
Dec 02, 2010 | Video Game Consoles & Games
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
I want driver of shro am-400 for win vista plz do needfull
Well sorrsy to say but there is no win vista driver's for this model, anyway there is a way to use windows xp drivers in windows vista, follow the below steps -
1. Click the "Start" menu in the lower left-hand corner of the Windows Vista screen.
2. Select "Run" from the Start menu.
3. Type "msconfic" in the Run box. Click "OK." A window will appear that lists all of the programs scheduled to run when Windows Vista is turned on. Uncheck all unessential software programs. Be sure to leave critical programs checked, such as antivirus and firewall programs. Click "OK."
4. Click the "Start" menu and select "Restart" to reboot the computer.
5. Open "My Computer" (located in the Start menu or on the Vista desktop).
6. Double-click the "C:\\" drive. Find the installation directory for the Windows XP program or device that you wish to run in Windows Vista. The installation directory is usually given the name of the program, the program's manufacturer, or a shortened version of either of these two options.
7. Right-click the program or driver. Select the "Properties" option in the pop-up menu that appears.
8. Click the "Compatibility" tab in the window that appears. Check the box next to the heading that reads, "Run this program in compatibility mode." In the drop-down menu, select "Windows XP." Click "OK" to close the window. The program or driver will now operate in Windows Vista in Windows XP compatibility mode, allowing the driver to function as it did in Windows XP. Note that the Windows XP driver will not be able to take advantage of any of the new features in Windows Vista while it is running in compatibility mode. You can also follow the below link for more help -
http://www.softwaredriverdownload.com/try_fool_windows_vista_to_install_in_windows_xp_mode
Good Luck!!
Jun 08, 2010 | Sharp AM-400 Digital Multifunction Printer
We just got a new computer with Windows 7. We
You could try installing the version 5 on your pc. There could be a compatability issue so follow the information below if it will not install.
The Windows® Vista Program Compatibility Wizard can allow older programs that were not designed for use with Windows® Vista to run on Windows® Vista.
The Program Compatibility Wizard prompts you to test the program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows® XP, set the compatibility mode to Windows® XP and try running the program again. If successful, the program will start in that mode each time. The wizard also allows the use of different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
To run the Program Compatibility Wizard, complete the steps below:
  1. Close all programs and windows and return to the desktop.
  2. Click the Start button on the Windows® taskbar. The Start Menu will appear.
  3. Click on Control Panel. The Control Panel window will appear.
  4. Click on Programs. Additional program options will display.
  5. In the Programs and Features section click the link Use An Older Program With This Version of Windows. The Program Compatibility Wizard will launch.
  6. Click Next to Continue.
  7. Click the “I want to choose from a list of programs” radio button and click Next. A list of programs will display.
  8. Select the program that is to run in a Compatibility Mode and click Next to continue. A list of Compatibility Modes will display.
  9. Click the radio button next to the desired Compatibility Mode and click Next. A list of display settings will display.
    NOTE: These display settings are not available options in Windows® Vista. They are only available when running a program in Program Compatibility Mode. The only reason to choose either of these settings is if you are experiencing difficulty installing or running an older application designed to run in Windows® 95, Windows® ME or Windows® 98. If all options remain unchecked, then the current Colors and Screen Resolution settings will not be altered.
    By default, Windows® Vista uses visual themes that may change the appearance or behavior of other programs, especially those games or educational programs that include intensive graphics and animation. To prevent the visual themes from affecting these programs, check Disable Visual Themes.
  10. Choose the desired display settings and click Next to continue. Administrator privilege options will display.
  11. Choose the desired administrator privilege setting and click Next to continue. A Test Your Compatibility Settings window will display.
  12. Verify that the settings are correct. And click Next to continue.
    NOTE: If the settings are not correct, click the Back button to return to the previous screen (or screens) and make the necessary changes.
  13. With the correct settings selected and showing in the "Test Your Compatibility Settings" window, click Next. The selected program will launch.
  14. Run the program to test the settings.
  15. After testing the settings, or close the program to return to the Program Compatibility Wizard.
    NOTE: After the program is closed, a window with the question "Did the program work correctly?" will appear. The "Yes. Set this program to always use these compatibility settings" will be selected.
  16. If the program functioned properly using the compatibility mode that was selected above click Next. The Program Compatibility Data window will open.
    NOTE: If the program did not function correctly, click "No, try different compatibility settings" and complete the Wizard. After completing the wizard, try the program again.
  17. Choose Yes or Now and click Next to continue. The Completing the Program Compatibility Wizard window will appear. Click Finish to close the window.
  18. Launch and use the program.
NOTE: If you have questions regarding the Program Compatibility Wizard or Windows® Vista (or both), contact Microsoft®, or go to http://www.microsoft.com for additional information.
Apr 01, 2010 | The Learning Company The Print Shop...
Vista compatibility problems when trying to install set up program for yumi pro mp4 player v 4.05 get message blocked due to known compatibility problems
Copy the installation to your hard drive.
now take the properties and setup it for windows xp under the tab compatibility.
now run your application with administrative privilage. right click then "Run as Administrator'
Vista's Compatibility assistant is known to have a lot of bug.
if it didn.t work then
Press the keyboard combination "Windows Key +R"
you will have run dialogue box
type in "services.msc"
in the window that appears look for "Program compatibility assistant" and then disable it.
now restart your computer and try installation
it will be fine
its recommended that you switch your os to windows 7 from vista as windows 7 is more bug free and crash is unlikely to happen
Jan 08, 2010 | Sumvision Yumi Pro Digital Media Player
This version of Windows does not support this version of Roxio DLA. This product, which was created by Roxio, Inc., has been blocked from running because it might keep your computer from starting correctly...
Getting older programs to run on Windows XP Getting older programs to run on Windows XP Most programs run properly on Windows XP. The exceptions are some older games and other programs that were written specifically for an earlier version of Windows. To run your program on Windows XP, try the following:
  1. Run the Program Compatibility Wizard. As an alternative, you can set the compatibility properties manually.
  2. Update your program, drivers, or hardware.
These options are covered in detail below.
The Program Compatibility Wizard This wizard prompts you to test your program in different modes (environments) and with various settings. For example, if the program was originally designed to run on Windows 95, set the compatibility mode to Windows 95 and try running your program again. If successful, the program will start in that mode each time. The wizard also allows you to try different settings, such as switching the display to 256 colors and the screen resolution to 640 x 480 pixels.
If compatibility problems prevent you from installing a program on Windows XP, run the Program Compatibility Wizard on the setup file for the program. The file might be called Setup.exe or something similar, and is probably located on the Installation disc for the program.
  1. Start the Program Compatibility Wizard.
  2. Follow the instructions in the wizard.
Dec 19, 2008 | Computers & Internet
Itunes
Hey 0836,
If the error message you are seeing reads as "QuickTime failed to initialize. Error # - 2096" you may wish to turn off Compatibility Mode for QuickTime, as doing so may resolve this problem.
You should be able to disable Compatibility Mode by doing the following:
1) Right-click on the QuickTime Player program and choose the "Properties" option from the menu that appears. Normally the application is kept in the C:\Program Files\QuickTime directory, but may differ if you chose to have the program installed onto another hard drive or in another directory.
2) Once in the "Properties" menu, click on the "Compatibility" tab.
3) Uncheck the box that says "Run this program in compatibility mode" if it is currently selected.
4) Click on the "Apply" button.
If QuickTime was not initially in Compatibility Mode, and you still receive an error message prompting you that iTunes requires Windows 2000 or later (or prompts you to make sure that compatibility mode is disabled in iTunes.exe), you may wish to try the following instead:
1) Shut down iTunes.
2) Click on the "Start" menu, then on "My Computer." You can generally also double-click on the "My Computer" icon on your desktop as an alternative.
3) Once in "My Computer," open the drive where Windows XP is installed. Typically this is the C:\ drive, but please remember that your configuration may slightly differ if you have multiple hard drives.
4) Open the "Program Files" folder.
5) Open the "iTunes" program folder.
6) Next, right-click on the iTunes program - this may be listed as either iTunes or iTunes.exe. Once you have done so, choose "Properties" from the menu that appears.
7) Click on the "Compatibility" tab, and uncheck the option to run in Compatibility Mode if it is selected.
8) Click "OK" to accept the new settings.
One of these two solutions should hopefully resolve the problem, but I would strongly suggest visting Apple's support homepage for more information if you are unsure of how to proceed.
http://www.apple.com/support/
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Apr 13, 2008 | Audio Players & Recorders
Driver blockt work due to compatibility issues.
A user can uninstall the Windows Vista update that is causing this issue. Once the update is uninstalled you will need to wait until Microsoft has released a fix for this issue. Otherwise, a Windows Vista update may cause this problem to occur again if Microsoft has not pushed a fix yet.
To uninstall the conflicting update, do the following:
1. Click Start
2. Click Control Panel
3. Click Programs and Features
4. Choose View installed updates
5. Select "Update for Microsoft Windows (KB943302)
6. Click Uninstall
7. Restart your computer and the update should be uninstalled
Jan 11, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Can I use the PDC 1100 camera with Windows XP?
Yes, you can use the camera with Windows XP, but you will no longer be able to use a USB port to download your photos. Only serial port downloads are supported under Windows XP for the PDC 1100 camera. Follow the instructions below to reinstall the PhotoMAX software and camera drivers using Windows XP's Program Compatibility Wizard. 1. Insert the PhotoMAX CD-ROM in the CD drive. If the program begins installing, press OK to close the "not compatible with Windows NT" error message. 2. Start the Wizard by clicking the Start button and choosing All Programs > Accessories > Program Compatibility Wizard. Follow the on-screen prompts. 3. On the second screen, select I want to use the program in the CD-ROM Drive and click Next. 4. Select Microsoft Windows 98/Windows Me and click Next. NOTE: You may have to scroll down to see this option. 5. Uncheck the following items: * 256 colors * 640 X 480 Screen Resolution * Disable Visual Themes 6. Click Next. 7. Click Next again. The PhotoMAX software will begin installing. Follow the on-screen prompts. 8. Follow on-screen prompts to finish the installation and click Finish. 9. When the Compatibility Wizard asks if the program worked correctly select Yes and click Next. 10. When the program asks if you want to send information to Microsoft, select No and click Next to finish the installation. 11. Shut down and restart the computer. After the restart, you should be able to download photos using Windows XP.
Sep 14, 2005 | Polaroid PhotoMax PDC 1100 Digital Camera
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
2,391,021 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
