Question about Video Game Consoles & Games
I can not get my Wii connected to the internet. I have seleceted the wireless network but when I do a connection test I get an error code 51330
  • 13,433 Answers
Try restoring the wireless router to default settings, you can do that in the setup of the wireless router if you know what I mean.
Or you can try holding down the reset button on the wireless router down for at least 30 seconds it should restore it to factory defaults.
If that doesn't solve try problem try changing the wireless channel to 1 or 11 also make sure the wireless is transmitting on mixed b/g
if you are far from the wireless router move closer if possible (move the router or the wii or both)
Go over nintendo's suggestions
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US&action2.x=22&action2.y=18
Last step: Try to update the firmware of the wireless router (I will need the brand and model to get you a link but please try the other suggestions above first)
Posted on May 17, 2009
Undefined
From the Wii main menu, use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection Settings."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
Asked to enter a security key?
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  1. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network.
  • As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored.
  • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51330: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
For detailed step by step instructions with pictures use this link: http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-sys-internet-connect
Apr 23, 2013 | Nintendo Wii Video Game Consoles & Games
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
Error code 51331. unable to connect to internet. choose internet settings and then cofirm your connection.
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
(Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
(If you're not sure which is yours, or you don't see any wireless networks, click here.)
Don't know your router's security key?
Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand!
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jun 28, 2011 | Video Game Consoles & Games
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
  5. Click on "Wireless Connection" and then "Search for an Access Point."
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Cannot conneted to internet
    Belkin Apple 2Wire
    All other brands
Mar 01, 2011 | Nintendo Wii Console
How do i set up my new dsi to the internet
Power on your console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." SELECT CONNECTION ONE NONE (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.) Select "OK" and the Wii will display all the wireless networks it finds. (If you're not sure which is yours, or you don't see any wireless networks, click here. Select "OK," "Save Settings," and then "Yes." The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next! The connection test was not successful - If the test was not successful, you will receive an error code. Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information. All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.
Jan 30, 2011 | Nintendo Dsi Pink Console
52030 error message when trying to hook to the internet
Jan 23, 2011 | Nintendo Wii Console
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
