Question about RCA RCR860 Remote Control
I don't know the model of my remote but
The battery cover has several lines that might help as follows
CRK530 S11AF
2G21001-504
EIA55390196
RWZ 192108
it's black rectangular very simple has OFF ON DISPLAY PC on front top
1-0 numbers chan up & down vol up and down and mute plus an RCA logo
Problem: All channels work with the remote except channels 3, 4, 5 will not come in. The remote will change to those channels but there is no picture or sound, just black screen with static. What could be the problem?
  • 979 Answers
What source/cable/Sat/etc are you using? Are there stations on those numbers? If so, do you have a VCR powered up that is connected to all this. That could be where you're losing your signal....accordianman
Posted on Mar 16, 2008
SOURCE:
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
I bought a RCA remote and i don`t know how to used
Google the name and model of the remote and put instructions behind it....If you don't know the model, it may be under the battery lid (either inside or on the lid itself). If its not there, you can go to google images and type in rca universal remote and find one that looks like yours and it will tell you the model. I have done it before.....
Mar 13, 2012 | RCA RCR815 Remote Control
Lost my pin to access messages. The phone model is a Panasonic cordless Model TGA542AL.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 30, 2011 | Panasonic Lands Phones
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
The garage door remotes and keypad works only when i,m very close to opener, will not work at more then 6 ft away from opener. sears hbw0777
How old are the batteries in the remotes and keypad? Replace the batteries. If that helps, then you have solved the problem.
If it doesn't help, then check the antenna wire of the opener. (Make sure it is extended down from the unit.) Note this doesn't apply to all garage door openers. (We have several models - some with the external antenna and some without.)
Does your garage have metal walls and metal doors? This can shorten the range between the receiver and the remotes or keypad. An antenna extension may be available.
I don't see the HBW077 as a model number at Sears Parts Direct or Manage My Life. Please check the model and let me know if I can provide any additional assistance. (Sears Parts Direct has parts for my garage door openers. Manage My Life has manuals for Craftsman and Sears appliances.)
I hope this helps.
Aug 04, 2011 | Garden
What causes the remotes to stop responding to the system
There could be a few things.
1) if your Wii remote has a fresh pair of batteries you may need to sync it again.
2) This is the one that happend to me - The Wii Jacket wasn't on correctly and was covering the front; anything covering the front of the remote will cause it not to work.
3) If it doesn't have a new pair of batteries, consider switching them out.
4) Wii bar - if anything is in front of the Wii bar - anything preventing you from having a straight line from remote to sensor - this will cause it not to work.
If this doesn't help you completely, please let me know the problem a little more specifically. I would like to help you in any way I can - video game consoles are my expertise. I ask for a good rating to show that I'm on the right track and that you're pleased with the answer.
Respectfully,
- Don
May 10, 2010 | Nintendo Wii Console
The remote for my 20: LCD TV has stopped working, i have changed out the batteries and even bought a new one but still nothing. What should i do?
there are several things to try.. first, isolate the source of the problem... get a universal remote (borrow one from a friend if you don't have one--get the instructions, too)...then program it for your tv...if the UR doesn't work, then there is a problem with either the tv or its remote sensor...try the troubleshooting guide for the tv or call the customer service line (ask if there are similar probs going around for that model..you might get some special incentive to quit ****, if so..) If it DOES work, then it's your remote...best thing to do is make sure that the batts are good (which you did....but make sure you didn't get a fresh set of batteries from the same bad lot - it happens)...then check to make sure that the connections for the batteries are not missing, broken, or bent.. Look for corrosion, loose wires, solder gone...anything you can see which might cause your problem...Nothing visible? send it back..or try to exchange it at the store you bought it from, if it's a currently selling model Hope that helps you
Feb 22, 2010 | Televison & Video
Do not know how to replace batteries on Celestial Air Con remote
I had a similar issue and found this thread.
I pulled my the slider down on my remote to the reveal the hidden buttons and then pressed the 2 side thumb grips inwards on either side on the slider and pulled it down again. This popped it off the slider and thus revealed the 2 flat AAA Batteries!
Jan 12, 2009 | Heating & Cooling
RCA RCR860 Remote Control Logo
63 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
