Question about Razer Copperhead RZ01-050100-R1M1 Mouse
Mouse cutting out
My copperhead is cutting out speraticly and it doesnt seem like the cord is loose. Sometimes it happens when the mouse isnt even moving please help
  • 3 more comments
  • Anonymous Nov 13, 2007
    I have the exact same problem with my Razer Copperhead on Windows Vista. The mouse worked perfectly for a few months, but it has lately been sporadically cutting out for a period of about 20 seconds before Vista recognizes it and function returns to the device.
  • William Nov 17, 2007
    same problem but i suspect my cord got pulled. The lite will go on and off when you fool with the cord.
  • El Seanerito Aug 28, 2008
    Yup, same problem here. The fiddled with the cord and nothing happened so it is definitely not loose. I reinstalled the drivers to no avail. The best idea i have is to directly contact Razer and complain like a 3 year old until they send a new one.
  • Sonny Martinez
    Sonny Martinez Sep 05, 2008
    Same here, a problem with the razer after recent windows update, on two seperate computers, same problem.
    The more the issue is brought up, I'm sure we will get a fix sooner or later. For now I uninstalled the driver in add and remove programs and the mouse seems to be working fine.
    Running XP Pro Service Pack 3
    AMD Athlon 64 X2 Dual Core Processor 3.21 GHz
    2.00 GB RAM
  • Anonymous Feb 08, 2009
    I have the same problem, it has only just started happening. I have owned this Razer Copperhead for 4 years now and I originally attributed the problem to its age. like I have said above this problem has only recently began, and I do not know what the problem is.
Its a technical fault with the mouse, my friend a problem with his and he had to solder a wire to get it to work properly, however on my mouse whenever i turn it upside down, it cuts out immediately but when i return it to upright, it comes back on after 2/3 seconds
Posted on Dec 14, 2007
Wish i had a proper solution for this, but im getting the same problem but have found out something interesting....
I recently formatted my machine (xp) and i didn't have a single problem for about 4 weeks!
I have an idea that its a windows update that causes the problem.
Posted on Nov 22, 2007
Copperhead cursor won't move when i move the mouse
this is because the laser light in the mouse had gone bad...all that you can do is to replace that with a new one... or buy a new mouse...
Apr 04, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My Razor Copperhead mouse restarts
I found that when this was happening to me the problem area was where the wire meets the mouse. By wiggling that (moving the mouse) it would cause it to disconnect and reconnect.
Some claim it could be the firmware for various hardware pieces on your pc IE: motherboard, usb. Depending on how old the mouse is this could be true. Mine, however, is 4 years old and needs to either be repaired or replaced.
Mar 30, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
My scroll isnt working on my razer copperhead, any ideas?
Just had the same problem with my copperhead... firstly go to url below to show you how to open up the copperhead (only do this if it's out of warranty!! which is two years if you have your purchase recipt) http://razerblueprints.net/index.php/Copperhead/copperhead-disassembly-guide.html . Once you have got the top off look at the front where the wheel attaches you can pull the wheel out of the circular thing on the left then find some thin paper I used some laser receipt paper (probably gonna wear out but will find something better in meantime) cover the hole with a very small square of whatever thin material you have chosen then push the axle of the wheel back in... this tightens the hole back up allowing the clicking feel to come back and the scroll wheel to work again.
Ultimately the problem is wear and tear with the hole for the axle or the shape of the axle end wearing down.
Jan 01, 2010 | Razer Copperhead RZ01-050100-R1M1 Mouse
Freezes up often. USB comes on says its malfunctioning. Anything I can do this mouse isnt that old
I see this caused a lot of the time by a bad wire within the cord. If you are good with soldering and circuit boards you can replace the cord. But getting a new cord is the fun part, you can usually take it out of another device. Sometimes for a temp fix, you can find where the cord is broken and twist n turn it just right to make it work again, then finding a way to make the cord stay that way. With most breaks in the cord happening right where it meet the mouse, you can sometimes push the cord further into the mouse and get a few more months out of the mouse.
I personally just replace the device when I know it is a cord problem, saves a lot of time, trouble and frustration. I always buy the same model of mouse and it runs around $60+, I use my old devices to repair the newer ones when something goes awry...if permitting.
So my advice is to just buy a new mouse, you can get them for under $10 depending on what you choose to buy.
Oct 17, 2009 | Dell U0636 Mouse
My cord on my razer copperhead mouse is broken
Gaming mice are not cheap,sell for $30 - 130. The cord on my RAZER DIAMONDBACK mouse went bad, I opened the mouse & repaired the broken wires.You have to unplug cord from inside mouse,the connection plug has very small barbs,so you have to pry the socket open a bit to unplug it.Once the cord is out cut the rubber part on the cord that connects to mouse that reinforces the cord.Cut it off on both side,pull out the remaining bits of wire.You have to enlarge the hole in the rubber grommet to reinsert the cord threw it,a heated wire the size of the cord works well to enlarge the hole.Run cord thew grommet splice wires,solder wires if you have a soldering iron makes the best repair,splice wires offset from each other,so they are not all sliced at same location.Use a good tape to isulate the spliced area on each wire,about 1/2 of tape per splice,Scotch Super 33+ Premium Vinyl Electrical Tape. Once you have taped each wire, tape all the wires together, for better isulation.Reinslall wire harness & test mouse.
Jul 08, 2009 | Razer Copperhead RZ01-050100-R1M1 Mouse
My copperhead Razer mouse has started double clicking for one
This double-clicking can be due to a worn out micro-switch in your mouse. If you are well -verse with repairing such gadgets, you can go ahead and replace this switch yourself or refer it to a qualified technician
Apr 23, 2009 | Razer Copperhead Chaos Green Gaming Mouse...
Left click is broken
I came across this post while having the same double-click issue with my copperhead. I've found that the cause is the plastic contact under the left click button itself. It wears out and takes on the shape of the microswitch underneath. To fix it all you have to do is follow the instruction for taking the mouse apart posted above and lightly filing the plastic contact flat again. You only want to take the notch out of it.
Sep 11, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer Copperhead mouse problem
Check the BIOS settings on your computer: is it set to boot from USB drive?  that may be the problem.
Mar 28, 2008 | Razer Copperhead RZ01-050100-R1M1 Mouse
Razer copperhead problem
I have something like you've all described with mine occasionally, normally, turning the mouse over and rubbing the laser surround with my finger vigorously is enough to clean off the crud that seems to be causing the problem..
I've never had any software problems or anything with mine..
Feb 18, 2008 | Razer RZ01050300 Mouse
Scroll (mouse 3) doesnt click
you got to change options on options of the razer ;) is on the options scrool I hope helps sorry but I am portuguese
Dec 02, 2007 | Razer Copperhead RZ01-050100-R1M1 Mouse
Open Questions:
Razer Copperhead RZ01-050100-R1M1 Mouse Logo
774 people viewed this question
Top Razer Computers & Internet Experts
Alun Cox
Sunday Ojelabi
Sunday Ojelabi
Larry Chandler
Are you a Razer Computer and Internet Expert? Answer questions, earn points and help others
