Question about Maytag Neptune MAH5500B Front Load Washer
AGITATOR ON WASHING MACHINE NOT WORKING
AGITATOR ON WHIRLPOOL WASHING MACHINE NOT WORKING AT ALL.  PLEASE HELP!!!
  • Anonymous Nov 19, 2007
    Agitator will not run on Estate (Whirlpool), what could be the problem? I have found one bolt on the floor and have since reinstalled it. Gear oil is also leaking but very little. Washer works in all other cycles.
  • 58 Answers
Could be aggitator dogs are worn out
Posted on Oct 31, 2007
Agitates but has stopped spinning...please help as I love my Whirlpool
Most washers have lid activated switch that if you open the lid the machine will not spin. Its a safety feature. That lid switch could be bad causing your problem. Agitation will still work on older machines.
Mar 06, 2016 | Whirlpool Washing Machines
Agitator not working
Here are a plethora of videos for you to watch about the lack of agitation in your machine or one just like it:
http://www.youtube.com/results?search_query=whirlpool+washing+machine+agitator+repair&oq=Whirlpool+Washing+Machine+&gs_l=youtube.1.3.0l10.40414.53833.0.58334.3.2.1.0.0.0.236.444.2-2.2.0...0.0...1ac.1j2.njwYnPVTXzM
How cool is that?
Jan 13, 2013 | Whirlpool Washing Machines
Merry Christmas! Our washing machine whirlpool
Hello there and merry christmas to you too
ok please read this solution fully this will be posted in 2 posts so i can get it all for you ok
There are a couple of different reasons that this problem happnes on these machines i have this listed below please feel free to leave me a comment on any of these if you need help trying to figure out how to inspect them or test them ok but you will need a multimeter to do most of the testing.
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) i will continue in the next post
Dec 26, 2010 | Whirlpool Washing Machines
Whirlpool washer top load agitator does not work
Whirlpool top load machines have a coupling beyween the motor and the gearbox..This coupling can fail with age or if the machine is overloaded. The pump should still work even if the coupling is broken..If this is the case then it's not a big job...You need a tech who knows the tricks, and it won't take long to fix....Good luck....Nomess
May 14, 2010 | Washing Machines
Agitator stops while in spin cycle
Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
Please see the following Whirlpool installation and service manual for top load machines.
If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
Oct 14, 2009 | Whirlpool Washing Machines
Whirlpool agitator not working!
Hello Roger.
Please do the following checks for they might just help.
Check that the water supply valves are turned on
Inspect the filter screens
Test for overheating
Inspect the water pump
Test the water inlet valve
Test the motor
Most probably this case may be due to a faulty motor.Good luck.
Jan 09, 2009 | Whirlpool LSR6232J Top Load Washer
Whirlpool washing machine agitator
You need to replace the agitator dogs. The following link explains how:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
This is a very inexpensive repair. If you run into and difficulties, or require additonal assistance, please let me know. I hope this helps you.
Aug 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Wash Machine and Agitator
check the direct drive coupling between the motor and the transmission
Apr 21, 2008 | Washing Machines
Kitchenaid top load wahing machine # YKAWE870BW1
You need to replace little gears called agitator dogs. Once agitator is removed pull top half of it off. Exposes the dog carrier.
Nov 28, 2007 | Whirlpool LSB6200KQ Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
