Question about Car Audio & Video
Hello, I am Terry. And I have recently purchased a Kia Rio car which has a JVC CD receiver KW-S601 fitted. When the ignition is on or the key is in the accessory position, and I set the radio to the settings to what I like. The unit works fine and remembers the settings fine, no problem, the problem is when I switch the ignition of and lock the car up over night. The unit resets it self back to default settings, all expect from the radio presets on the radio, it is so frustrating to get in the car and when I turned on the car I end up with a radio that I have never heard off. The same thing happens when I play a CD instead of playing from the last track it goes back to track one. I am due to take the car back to the dealer on 22/05/09 so that they can rectify the problem. Could you also advise me on how the following unit is mounted and would the current roof Ariel will work with the unit. KT-DB1000 or where to get instruction/advice before I go mad and purchase the unit. I leave in the UK. Please do contact me if you need any further information. Thank your time in this matter. Regards, Terry Macavoy
  • terry308 May 17, 2009
    I do applogise for posting this in the wrong place. Would it be ok to contact you with the result when I have been back to the car dealer but thank you for your help.
    Terry.
    Sergeant:
  • 326 Answers
Yes it will be possible .as from when you return from your car dealer.as mostly he will give you the right settings to set the radio.as he will make your settings the default settings.so it will not revert back to the orignal default setting in which the radio goes.
thanks.keep updated.please do rate the solution,.
Posted on May 17, 2009
  • 952 Answers
Hi terry, I have checked the KW-s601 and found out that its DAB ready. There is a port at the back of the head unit for DAB modules such as KT-DB1000. Its plug and play. About the roof ariel, Im sorry but the stock roof ariel will not work for the KT-DB1000. You need to buy a special roof ariel for this.
About the radio not being able to store data. You'd better ask the dealership about this. usually, this happens if the radio was wiring problems.
I sure hope that i've helped you out. Have a good one.
Jvc kw-s601 cd stuck sedona
Error E1 ,remove the cartridge and take all the CDs out then put it back in and press the reject button and the Cd should go back into the cartridge ,refit all the CDs and it should work again
Sep 24, 2012 | 2007 Kia Sedona LX Minivan
How to install jvc kw-av70bt
Hello I am installing a JVC- kw-av71bt to 2 audiovox headrest monitors. can you tell me the easiest way to run the rca cables from the headunit to the monitors.
Apr 14, 2012 | JVC KW-AV70BT DVD receiver
Battery keeps getting drained in kia rio
You will need to replace ignition switch.
Feb 11, 2012 | 2006 Kia Rio
JVC KW-NT1 GPS not working in UK
Have you tried re-flashing the unit with the latest EU firmware update available from the JVC website? http://www.jvc-victor.co.jp/english/car/support/navi/nt1/eu/index.html Should overide the current firmware then allow you to use UK maps. If it doesn't work you can always reflash it with the USA update.
Nov 28, 2009 | JVC KW-NT1 Car GPS Receiver
Connecting a subwoofer to JVC KW AVX800
Hello pmdharan, It sounds like the subwoofer is not turned ON. Go to MENU ITEM > SPEAKER SIZE >SW (subwoofer) and select ON. Hope this helps.
Jun 06, 2009 | JVC KW-AVX800 CD Player
Car Aerial
it sounds like you don't have the yellow wire going to a constant power source. the ;yellow wire provides the power for retaining memory.
May 17, 2009 | Car Audio & Video
What colour are the power wires, are they green & yellow, black, black & grey, blue & grey, red & grey or black & green. I want to connect a cd/radio player but don't know what wires connect to the cd...
JVC KW-AVX800 The black wire is your ground The yellow is your positive 12v constant so connect this to the wire that has 12v when the car is off. The red connect this to the key switch wire meaning the wire will have a 12v signal only when the key is tured to the on position. The blue is for a power antenna the blue/white stripe is if you have external amps this wire goes to the amps remote on The orange/white stripe connect this wire to your cars dimmer switch Happy Wiring
Mar 21, 2009 | JVC KW-AVX800 CD Player
Jvc
will have a another look around for you but you could start here
http://4jvc.co.uk/cgi-bin/pne.pl?display=entry&brand_id=2158&f-10=%20JVC%20KW-S601%20car%20stereo
see if they can assit as well , i i find one i will post back for you, good luck .
riz.
Nov 20, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
