Question about Lexmark X5650 All-in-One InkJet Printer
I install the software.printer is works,but when i want to use scan,there is on the screen ocr software mising ,install the software.on the printer scan is failed.how can i scan?thanks
I have a lexmark X5650 and the the little window will show copy but it wont do noting else i have window vista but when i hook it up to window xp it work will it work on window vista
Posted on Jan 09, 2010
  • Lexmark Master
  • 684 Answers
In this case please insert the disk to the computer goto My Computer in XP and Computer for Vista...... There u will see a icon which says DVD RW lexmark 5600 u need to right click on it and click on explore and then click on Abby and run the setup.exe file and then try to scan it will work fine................
Good Luck
Posted on May 17, 2009
The lexmark x2650 doesn't have the OCR software in it. I try to scan a document and edit it but can't because no OCR software included
To scan documents for editing and saving as PDF file, you will need to install the Lexmark OCR scan software on your computer. The Lexmark scan software (no downloadable version) is only available on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center for assistance.
To install the OCR scan software from the printer installation CD:
  1. Insert CD into the CD-ROM drive. If the installation screen open, click Cancel.
  2. Double-click on My Computer / Computer.
  3. Right-click on Lexmark XXXX CD and select Open.
  4. Double-click on OCR.
  5. Double-click on Setup.exe to install the OCR software. Your operating system will then determine the language in which it is installed.
Mar 05, 2012 | Lexmark X2650 All-In-One InkJet Printer
OCR doesn't work with WINDOWS 7 and my Lexmark X5650es printer
Try this approach:1. Uninstall your existing printer driver. On your computer, go to Start menu > Programs > Lexmark X5600 Series folder > Tools > Uninstall. After the uninstall process, reboot your pc when prompted.2. When your pc turns on, check if your Windows 7 is running on 32-bit or 64-bit operating system. On your computer, go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.3. Use the link below to download and re-install the corresponding printer driver for your operating system:- Lexmark X5650 Printer Driver for Windows 7 32-bit- Lexmark X5650 Printer Driver for Windows 7 64-bitSimply follow the instructions on your computer screen to complete the installation.4. To re-install the Lexmark OCR scan software, insert the printer software installation CD in your pc CD-ROM drive.5. Click on Install > Install Additional Software > select the Lexmark OCR Scan Software > continue with normal installation steps.
Then try to create a PDF or Scan and Edit text (OCR) to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center at 1-800-539-6275 for additional assistance.
Feb 13, 2012 | Lexmark X Office Equipment & Supplies
Error says that ocr is not installed
I hope this helps.
Feb 01, 2012 | Lexmark All-in-One Printer with PictBridge
How to use the ocr
The function to do OCR scanning will be part of whatever scanning software you are using with this printer. Probably some scanning software came with the printer. If it doesn't have OCR capability , you'll have to use some third-party software. Just Google OCR software.
Jul 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I need to scan a printed page into a txt file using Notepad. Gone through the Lexmark Imaging option and attempted to scan, Come up with a message about installing OCR software. I can't find original...
The Lexmark OCR scan software allows you to scan documents to your computer. It enables you to scan to PDF or scan a document and convert to text to edit. The Lexmark OCR scan software is only available in the install disk that came with your printer. Please contact Lexmark technical support for assistance. Thanks.
Nov 12, 2010 | Lexmark X2350 All-In-One InkJet Printer
My printer OCR command does not respond. The printer says it's connecting to the PC but after a short period reverts to standby.
  1. faq000559_002 When I try to OCR into WordPad using the ScanSoft® PaperPort® SE with OCR or the Brother ControlCenter3, the text comes out as gibberish. This started after I installed Windows® XP Service Pack 2 (SP2). Why and what should I do?
  2. faq000093_012 What is MFL-Pro Suite Software?
  3. faq002613_000 When I try to scan to OCR I get an error message saying "This feature is not available because there is no OCR Software installed".
  4. faq002561_000 How do I configure or change the settings of the ControlCenter 2 or 3 scanning options?
  5. faq000562_002 When scanning to OCR from Brother Control Center3, the OCR application doesn't launch. I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  6. faq000563_002 When scanning to OCR from PaperPort® SE, the following error message appears: "System error incurred in external ink module EZText.g32. The OCR server is unable to process the document". I have Windows® XP Service Pack 2 (SP2) installed. What should I do?
  7. faq002620_008 Windows® 7 Support Information
Oct 26, 2010 | Brother DCP-330C All-In-One InkJet Printer
I can't scan on my lexmark printer model x5650. When I scan a document it gives me the message " Install the OCR from the OCR folder". I can't find the OCR folder in my computer. What should I do".
The Lexmark OCR scan software is available in the installation disk that came with the printer. You can explore the installation disk and look for the Abby setup application in the OCR folder (for Windows). For Mac OS, right-click on the Install icon and choose Show Package Contents. Open Contents folder > open Package folder and manually install the Abby Finereader application.
However, if you don't have the installation disk, contact Lexmark technical support. Thanks.
Sep 30, 2010 | Lexmark X5470 All-In-One InkJet Printer
I was given a Lexmark x7170 printer by a friend, but had no install disc. I downloaded the necessary driver for Windows XP and it has been working fine. I want to scan some documents into a word processor,...
Hello. The Lexmark OCR software can only be installed using the installation cd for your printer. The scan software is not available for download online since it's a big file. I would advise you to call Lexmark for assistance with the installation cd. They might send you one for free. Hope I can assist you more with this.
Mar 29, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My X4270 will not scan, keeps saying i need my ocr software. but I have reinstalled lexmark all in one .
You can run your lexmark cd installer again and select custom installation and click on install additional software,, now make sure that you are going to put checks on the boxes especially your abby finereader
If you dont have the cd you can check this link
http://www.mydigitallife.info/2008/02/01/free-ocr-software-program-download-simpleocr/
Aug 14, 2009 | Lexmark X4270 All-In-One InkJet Printer
OCR application error with the Dell ALL in ONE
OCR is a software provided by Dell to convert a scanned document to editable text(word) document. If you scan without OCR software, printer will scan it as a Picture and you can not edit it.
Now here is your answer.
When you install Printer CD, it also install OCR software (Abbyy Fine reader) along with it.
You might have uninstalled the printer drivers and reinstalled them by downloading it from Dell support site.
I must tell you that Downloaded drivers from Dell site DOES NOT contain OCR software.
Solution:
1. You can download free trial version(15 days) from Abbyy.com
Click here to download
2. If any of your friend or relative have printer listed below then you can use the same CD to install the OCR software.
List: Dell 924, Dell 926, Dell 928, Dell 944, Dell 946, Dell 948, Dell 964, Dell 966, Dell 968.
location on Disc:
D:\OCR\setup.exe
3. You can scan using MS Paint.
Click on Start > All Programms > Acccessories > Paint
Click on "File" on Top left corner.
Click on "From scanners and cameras"
Click on "Scan"
It should be able to scan.
4. If you want to use Dell All In One Center.
You can disable OCR option for scanning and it will scan as an image.
Open Dell All in one center.
Click on Advanced scan options Under scan,
Uncheck "Use OCR software".
Click OK and try to scan again using Dell All In One center or using the printer operator panel.
Please revert for any further assistance.
Nov 05, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark X5650 All-in-One InkJet Printer Logo
216 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
