Question about Planar XP17W 17 in. LCD Television
Green Light on no picture
The power green light is on on my Planar XP17W but i have no picture's at all!!
    Problem Solver:
  • 9 Answers
More than likely, the planar LCD sets have a set of 5 1000uf 16volt caps that fail. There could be other problems, but to check, unplug, pop off the cover, and look at the brown cannisters. They will mostl likely be bulging, or you may see blackish goo coming out of them. They're fairly easy to replace if you have experience with a soldering iron.
Posted on Jun 23, 2009
Planar PDP-42BK 42" Green Light just Flashes no picture. I am having the same issue. TV worked great yesterday than today I get a flashing green ligh and no picture.
remove all the connection and try to fit somewhere else. the socket which is directly connected to the wall.or then it could be the tube problem inside call some service technician.hope this will help you.
Jun 06, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
The monitor has no picture at all and the light goes from green to yellow
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Planar PL1910M (Black) 19 in. Flat Panel...
Power light blinks red, green and off. No picture
Is there another monitor input on the back of you computer? Sometimes this happens when your graphics card is not compatible so it is best to try another one. If you have another one plug it in there first. If you don't try the monitor on a friends computer. If it still does the same thing, it may be a manufacturer defect and may need repair.
Nov 06, 2009 | Planar PL1911M-BK (Black) 19" LCD Monitor
Planar PDP42BK no picture
Check the 15v line that runs through all the boards, left, right and top.. If that has no power, then look on the ysus board (left one) there is a flyback reg (5pin) standard to-220 case surrouded by caps, it does dc to ac conversion, if you dont have the 15v output then the chip is bad. I just did 2 of these that had the same problem.
Oct 27, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Email this guy @ exoticimports360@yahoo.com, he has planar parts to sell he might have a power board
or change the c97,c19 and c16 caps below is where I got mines.
Got it from a site called digi-key.com their phone # is 1800-344-4539. The part #s are EF6225-ND you need 1of these and E6105-ND you need 2 of these, the cost is $16 for all. Let me know how it went.
May 15, 2008 | Planar PDP-42BK 42 in. Plasma HDTV
Green Light on black screen
These units have the power supply and ballasts on one board, It's common for the capacitors on them to fail(bulge, leak, pop), those are the visual ques that they are bad, i've had good luck replacing the capacitors on this model to save them from the trash.
inspect C20, C21, C34, C37, and C36, they are all the largest caps on this board that the power cord plugs into.
Oct 17, 2007 | Planar XP17W 17 in. LCD Television
Planar XP17W 17"
The power supply ballast board has 5 1000uf, 16 volt capacitors that fail(you will likely see them swelling, or leaking), These are common cap's.
This can either cause the backlight to not work at all, light temporarily, or display no picture, but still give you sound.
BCF
Apr 09, 2007 | Planar XP17W 17 in. LCD Television
Open Questions:
See all Planar XP17W 17 in. LCD Television Questions
Planar XP17W 17 in. LCD Television Logo
103 people viewed this question
Top Planar Televison & Video Experts
JonSnell Electronic
JonSnell Electronic
Greg Hull
Are you a Planar Televison and Video Expert? Answer questions, earn points and help others
