Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Screen goes blank for a second while playing xbox 360 through hd
I'm currently using my hyundai plasma screen tv with my xbox 360. when connected through the av cables (ie, red, yellow and white) all is ok (all be it for lesser quality picture. But when i connect it using the hd cables (ie,red, green, blue and the audio cables) the screen is perfect. but every now and again the screen with turn black for a second and display "no signal". then the picture will come back and everything is fine again until the next time it happens. I have played for an hour before this has happened and then the next day it will happen after the first 3 minutes.
does anyone have any ideas of what the cause could be and any possible fixes.
many thanks
  • 140 Answers
SOURCE: losing picture
Six blinks error code could be the Thermal Fuse part# 1-910-006-44
Posted on Sep 28, 2007
  • 3 Answers
SOURCE: Loud bang, unit stopped working
My Sony FWD-42pv1 had a similar failure, but no loud bang, just a click off. When trying to turn it on after that, the green LED would come on for a few seconds, then blink off, then repeat a few times, before finally just giving up and going to solid red.
The problem turned out to be a failed Y-SUS board. The fuse on that board was blown, and the board had also failed (replacing the fuse wasn't enough). With a new board, the TV is running fine.
Posted on Apr 24, 2008
I purchased a new Lamp, but before I had time to install, the problem stopped occurring. I feel that this may be a lamp overheating problem due to dust or temperature and humidity within my house. I was going through power outages due to IKE at the time that this problem showed up. At least I have the replacement bulb to try if this problem shows up again.
Posted on Oct 09, 2008
SOURCE: connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
Posted on Feb 17, 2009
  • 67 Answers
SOURCE: After watching the TV this picture goes black, and
I have a KDF E42A10 which is LCD projection TV. If your's is a projection TV then the blinking red light means that the projection bulb needs to be replaced. The access door is on the lower right side, fairly staight forward to remove and bulb costs about $150( varrious sourses can be found online). If yours is a Grand Wega there is a major problem that Sony is denying responseblity for. Check out a report by Googling " MSNBC problems with Sony Grand Wega". Would like to get a clas action going for KDFs.If your TV is not a projection then disregard all of the above and I can't help with your problem.
Posted on Jun 28, 2009
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
Can you hook up a Xbox 360 (EU) to a Philips 37PF9975 37 in. HDTV-Ready Plasma
do one thing...see at the connector...there is a it normal mode...if it is in HD cant be work in ur tv..
Sep 23, 2012 | Philips 37PF9975 37 in. HD-Ready Plasma...
Xbox 360 elite, no out put,blank screen ?
Make sure your connections are correct. If your using the HD component cable make sure the switch is selected to HD, if you have a HDTV or TV for a regular CRT tv.
HDMI, select the proper input on your tv remote.
Mar 30, 2010 | Microsoft Xbox 360 Console
Cannont connect Ear Force X3 with my HDMI set up .
Is the problem that you're using a single HDMI cable to connect your Xbox to your TV? If so, this Turtle Beach article should help... ________________________________________
HDMI and Connecting Ear Force Xbox Headphones
The current Microsoft Xbox 360 series of gaming consoles allow the use of HDMI cables for simpler hookup to home theater systems and Hi-Definition televisions (HDTV).
The Xbox 360 Elite (the black one) comes with two additional cables, an HDMI cable and a separate AUDIO cable that provides a pair of RCA jacks (red and white) and an optical digital audio output (S/PDIF Out). With this cable package, you can easily connect any of our X-series headsets and an HDMI-connected television at the same time.
This Xbox 360 HDMI Cable package is available as an extra-cost option from Microsoft:
Here's a more in-depth explanation of the Xbox 360 HDMI Cable and how it works:
[NOTE 1:] The standard Xbox models do not come equipped with this cable set. The HD cable they have obscures the HDMI connector, so that the two sockets cannot be used at the same time. If you only have this stock HD connector (component video, composite video, stereo analog audio and optical digital audio connectors), then you will not be able to use the HDMI connector at the same time.
In order to use both sockets at the same time (HDMI and A/V) you'll need to purchase the Xbox 360 HDMI Cable package described above.
[NOTE 2:] The current Xbox 360 Elite Holiday Edition (Fall 2009) does not come with the HDMI Cable set.
Some companies make aftermarket HDMI cables for use with the Xbox 360, but these may not provide the dual RCA jacks that carry the 2- channel analog audio necessary for hookup of the anlog-only Ear Force X-series headsets. If this is what you have, you may need to find another way to connect your Ear Force X-series headset.
The TOSLINK digitally-connected X-series headsets can be always be connected using optical digital "Toslink" connections (and that's the best way to use them!).
The oldest white-and-gray Xbox 360 models DO NOT have an HDMI port. With this particular (obsolete) model, you cannot use HDMI connections, but you can use any of our X-series headsets.
Current Xbox 360 models all have separate HDMI and A/V ports ("sockets") on their back panels.
Here are some suggestions for alternative connection schemes:
For X4 and X41: Your best bet would be to connect the Xbox optical digital audio out to the X4 transmitter's optical digital input. Then connect the X4 optical digital output to the optical digital audio input on your HDTV or home theater amplifier.
[NOTE:] Some HDTV systems have an optical digital audio output that will not transmit Dolby Digital/DTS encoded digital audio, only stereo PCM audio will be passed. In this case, you must connect as above.
For X2, X3 and X31: You can use the Headphones jack or the Audio Out jacks on your TV to connect to the Audio In jack on the Transmitter.
For X1 and X11: You can use the Headphones jack or the Audio Out jacks on your TV (if available) to connect to the headset's analog Audio Input.
NOTE: Please make sure your TV has Audio Out jacks. Some TV's only have Audio In jacks.
Audio In jacks only accept incoming audio signal; they do not send audio signal out. If no audio signal is being sent to the headset, no sound will play from the headset.
You may need to purchase a suitable adapter cable in order to connect the TV audio output(s) to the Ear Force X-series headset's transmitter or Audio Input plug.
- Connect the HDMI cable so that the Xbox 360 plays its audio through the TV.
- For X1, adjust the Dashboard > Settings > System > Voice in the Xbox 360 so that the talkback and game sounds are played together (Play Through Speakers). - For X3, X31, X4 and X41, you should set this to Play Through Headset.
XBOX 360 AUDIO PLAYS THROUGH HOME THEATER RECEIVER (except X4 and X41): This is exactly the same as the above, except that you will use the receiver's Headphones output jack to connect to the Audio In on the Ear Force Xbox-compatible headset's Transmitter (X2, X3, X31) or the green Audio Input plug (X1).
- You may need to obtain a shielded audio cable with 1/4" stereo phone plug to 1/8" stereo mini-phone plug ends. The 1/4" phone plug goes to the receiver's Headphones jack, while the 1/8" mini-phone plug goes to the Audio In on the Ear Force Transmit- ter (X2, X3, X31) or Audio Input plug (X1).
- Adjust the Dashboard > Personal Settings in the Xbox 360 so that the talkback and game sounds are played together (Play Through Both). For X3 and X31, you may also set this to Play Through Headset.
Mar 13, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Xbox 360 Screen Flashing
is your xbox set for 1080 p and are you sure your tv can handle 1080p
Mar 12, 2009 | Microsoft Xbox 360 Console
While playing xbox 360 in 1080p mod, the screen frequently blanks
Most TV's have problems doing 1080p over component. Dial the Xbox back to 1080i. Make sure the big switch on the Xbox AV cable is set to 'HDTV' not 'TV'(common problem) If the problem persists, try plugging into different hookups, use HDMI (if your console supports it) or buy one of the HDMI adaptors from PDP or MadCatz if your console doesnt. HDMI will reduce the clutter and will make 1080p a reality.
Dec 18, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
512 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
