Whirlpool aqua steam awo/d as148. 1400. Keeps pausing in cycle and gets a red light which is a picture of small squares inside a circle. Can't find the manual so please help or direct me to where I can get online manual. Thanks
SOURCE: flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
SOURCE: have just got new
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct [email protected]
If it is codes 32 it will be the pressure switch which is not working right
SOURCE: Whirlpool AWO 5140 Service-Red-Blinking lamp
hiya
it could be something thats been stuck in the pump filter, usually on whirlpools these are located at the front of the machine behind the plastic kick plate on the bottom. you may need a couple of towels or old rags as there will be some water comes out of the filter when you remove it.
hope this helps
