Question about Bose Audio Players & Recorders
Hi. I would like to connect a Bose controller between a pair of Bose 802 speakers and a Studiomaster Powerhouse 300 MIXER/AMP. The diagram on the top of the controller shows the amplifier connected just before the speakers with the controller between an AMP and MIXER which are seperate Could you please help me with this? Pete
  • 1 more comment
  • theturtons May 17, 2009
    Thanks so much for the last bit of info. That has made is clear to me. This Soundmaster Powerhouse 300 is such a great bit of kit I would like connect it to the Bose speakers and controller, but if it has to be a seperate amp/mixer-so be it.
    Thanks for getting me clude-up to the way the system works - everything you have sent has made sense. Keep up the good work. Pete
  • theturtons May 18, 2009
    Hi. I have had this dillema for about 6 weeks and as I thought, and with your explanation, everything now is understood. The way you explaned it all was
    spot-on.
    Many Thanks, Pete
  • Anonymous Mar 12, 2014
    studiomaster powerhouse 300, 300 + 300 has suddenly lost all volume on left speaker out. Could this be a blown fuse?
    Brigadier General:
  • 8,546 Answers
Tech data sheet with diagrams:
http://www.bose.com/pdf/professional/802III_techdata.pdf
In a nutshell, the controller would go between any preamp Stereo OUTput and a dedicated amplifier INPUT. You really don't have much choice in the matter. The 802's and their controller are part of an inseperable system.
The Bose 802/901 family uses full-range speakers instead of traditional woofer/tweeter combinations, so they compensate for the response limitations at the extreme frequencies by using severe electronic modification of the program material. Hence, they are a system, functionally inseparable, but the results are outstanding. Consequently, they need a dedicated amplifier so they alone get the processing provided by their electronic component.
I don't have any data on your mixer/amp but if you can't insert the conroller logically between the mixer and its amps then you'll have to get separate dedicated amplification for the 802's, with the controller between the mixer and that amp.
Posted on May 17, 2009
Studiomaster powerhouse does fan come on straight away
If this is an amp, the main relay will come on right away, followed by the speaker relay within 5-20 seconds.
Apr 29, 2014 | Audio Players & Recorders
How to connect Mackie Mixer 1402vlz4 to Bose Accoustimass 5 speaker
you need a power amplifier between the mixer and the speakers to actually drive the speakers. You would have to choose which amp to use (the manual, found here: http://www.bose.ca/controller?url=/shop_online/speakers/stereo_speakers/acoustimass_5/index.jsp#manuals suggests between 10-200 WRMS for power), and thus would have to determine the cabling options depending on the amp you choose, but...go from either the MAIN or CONTROL ROOM outputs of the Mackie mixer into the inputs of the power amp. Then go from the outputs of the power amp to the inputs on the Acoustimass bass module, which also runs the Acoustimass satellite speakers.
Apr 17, 2014 | Music
Connecting Yamaha Mixer with Bose L-1 Amplifier
See this article about connecting a Yamaha mixer to a Bose L1
Mixer Yamaha MG8 2FX
or
Call Bose® Product & Technical Support at (877) 335-2673 (U.S. and Canada only)
Monday-Friday: 8:30 AM - 9:00 PM ET
Saturday 9:00 AM - 5:00 PM ET
Or write to them at the Bose Forum
Ask Bose for Help Forum
Apr 16, 2012 | Bose L1 Speaker
Hi, I need a schematic for a Studiomaster Powerhouse 300
For your requirement of the schematic for your model is not available now. But this schematic will help you. Visit http://www.studiomasterarchive.com/6-2-1sc.pdf and download the PDF. It will help you.
Jun 15, 2011 | Audio Players & Recorders
How do I connect a Bose 802 speaker controller to my Spirit 600 powerstation
If you look in the manual at the "hookups" page 1, connect the controller as if it was an EQ. This will insert the controller between the mixer and the amplifier.
Dan
Aug 29, 2010 | Audio Players & Recorders
Hi. I need a user manual for my Studiomaster
Hiya Pete, Unfortunately ever since they "restructured" anything prior for service is a huge issue with them and especially manuals. It is difficult to even get on the pay sites. You try request it at www.safemanuals.com but i doubt it. If it's something specific that you are needing, i might be able to help?
Jul 11, 2009 | Audio Players & Recorders
Bose 802 C series II to Yamaha rxv 459 Amp
In a nutshell, the controller would go between a preamp Stereo OUTput and a dedicated amplifier INPUT. You can't use Bose 901 or 802 EQ in a multichannel setup without separate amps for the Bose speakers.
In a vanilla stereo configuration you would just put the controller/EQ into a Tape Monitor loop but multichannel sound and digital sources won't work that way.
You should be able to draw off the (assumed) Front L&R channel preamp signal from the MD/CD-R or DVD-R Audio Out (REC) jacks (*). Run that to the Preamp In (or whatever it's labeled on the Bose EQ/Controller). DO NOT run a return RCA pair back to the Receiver as Bose-processed signals will not play well with non-Bose speakers. (*) Run the Output of the Bose EQ/Controller to a powerful separate amp for the Bose 802/901's. I use two channels on a Carver multichannel AV-406 amp but a stand-alone Carver MT-200T also works well. A good clean 100 watts/channel should suffice at home.
* If possible, choose the recorder loop you are NOT using for something else. If you're using the MD/CD-R or DVD-R Audio OUT for a recording device just get some RCA splitters to share the Stereo signal between the Bose and the device at the same time. However, once you select monitoring of that recorder two things will likely happen - 1) you'll lose the Bose and anything digital in the receiver will be disabled.
It's the nature of the digital beast that analog monitoring gets in the way of DSP.
Of course, if anyone who reads this has a receiver with individual analog Audio Outputs for the various 5.1 channels (as I do), the solution would be to draw off the Front L&R channels to the Bose EQ and downstream amplifier and the rest would be the same but without Recorder Loop limitations.
Apr 28, 2009 | Bose 901 VI Main / Stereo Speaker
Bose speakers 800
I' ve just sold 2 pairs of 800's. The buyer(who once owned a music business) used an 802 controller to test them. He said that any bose eq would do the job with no problems.
Jan 01, 2008 | Yamaha Emx88s Powered PA Mixer System
530 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
