Question about Hoover U5750-900 WindTunnel Bagless Upright Vacuum
Replacing water pump - Hoover Jet & Wash S6254 001
Can you tell me how to strip this machine down to get to the water pump?
I have an S6254 001 Hoover jet & wash and have just taken the pump apart to free sticking parts. To get into the top you have to prise off the handle cover to get to 2 screws, unscrew them and the rest is fairly straight forward.
Regards Stu
Posted on Jul 07, 2009
I have a Hoover carpet cleaner that leeks the shampoo water onto the carpet, cannot control it
The machine is standing in the upright position with clean water in it. No power to the machine. If water is pouring out, again no power to machine, then the pump is cracked. I don't know the model number so I am thinking this has a gravity fed pump. It doesn't use electricity to work the pump. Once you pull the trigger water starts to flow. If the pump has a crack water will flow all the time. Hope this helps!
Jun 16, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Repair hoover steam vac F7210
Fixya does not make servicing recommendations.
Jul 23, 2017 | Vacuums
Why wont my hoover 2320LAUS washing machine drain water
Sounds like the water pump is not running either from power lack or defective pump motor.
Nov 15, 2009 | Hoover My Dad Can Arrest Your Dad Kids...
Hoover rug cleaner is leaking water profusley from tank at the underside of equioment.
call hoover with your model and serial number ...this is a known problem with these and Hoover is replacing the tanks for free on defective units...you should have a new tank in about 7 days
oh and dont forget to flush out your solution pump regularly by emptying the solution and filing it with water then spray for about 3 min into a sink ...these pumps are known to lock up from soap residue when it dries..the pump is about $50 plus labor
Sep 28, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Brushes will not spin while locked in machine..
I have the same problem and think I know the solution.
The plastic pegs on the housing unit for the brushes have been stripped out. The pegs are supposed to be squared tip to click into the square hole of the machine. If the pegs aren't the same shape as the hole, the machine can't grab them to spin the brushes.
The tallest peg on mine somehow got stripped to a rounded shape. I tried wrapping tape, plastic, etc around the peg to make it fit in the hole snug, but it only worked for a few seconds and broke again. I am going to have to replace the brush set. You can order parts from Hoover but I haven't priced them yet.
I hope this helps you. Certainly is cheaper than replacing a motor or machine.
Aug 23, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
I need instructions for a JM3 Multi-clean 1500 MR4001
HI I think you mean JMB Multi Clean 1500 as shown here:
http://www.onino.co.uk/vacuum_cleaners/jmb_multi_functional_cleaner_mf4001.html
Sadly as these were part of the Index chain of stores getting parts/manuals can be difficult and JMB is an exclusive catalogue only brand that uses different machines from other brands. On top of that contacting their service department is difficult although you could try and track down Littlewoods customer services and they may be able to help you further.
The model you may have is based on a Hoover Jet N Wash model S6155 which is slightly different looking to the JMB model but internals are the same. You can find a user manual here:
http://www.hooverspares.com/usermanuals/jet-n-wash.pdf
Please rate if this works out for you. Ultimately although the JMB model is worth hanging onto it is seldom sold nowadays through other catalogues. If you research Kays or Great Universal you may be able to find it on there. Littlewoods for example don't sell it now.
Jul 17, 2009 | Vacuums
Hoover Jet and Wash 1500w S6254 001. Used once with great difficulty as assembly and use instructions are hard to follow.Now will not work as carpet shampooer at all, although assembly is correct as far as...
i am having the same prob my uncle got me one i cant find the manual anywhere to set it up the prob i have is where does the handle to make the water go out connect tooo ??? on the main pipe that sucks it back up i have tried every which way but not the right way obviously lol as for it not spraying mine did for all of 2 secs but think it was because i got a bit happy with the solution so gunna just try water and if its too hot it stops it spraying properly too !!
Mar 30, 2008 | Vacuums
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover 500 top load washing machine - water in-flow very, very slow
Check the water valve. Most of the hoses that are hooked to the water valve have a screened filter, turn water off, unhook hoses, check to see if they need to be cleaned. Other wise the water valve is bad and will have to be replaced.
Jan 18, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover U5750-900 WindTunnel Bagless Upright Vacuum Logo
165 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
