Question about Compaq V700 17" CRT Monitor
Black bar at the end of my compaq v700 monitor
I get a horizon flikkering black bar at the bottom of my compaq v700 monitor, when i startup my computer.
if it is a hardware problem please tell how to solve this problem, maybe sending me a schematic and the location where to look or test the component!
My Best Regards,
Kenny
  • Compaq Master
  • 5,271 Answers
The monitor is bad.
its CRT monitor.
only googling find relic schmematics
you do know right the 2nd anode is at 15,000 volts right?
and that is lethal , right>?
zero 2nd chances.
no photos by you, so no answers ever possible on CRTs.
it works like old TVs did, only uses, different cathode drive
called DATA. (no tuner or radios inside, like TV)
the lines are my guess, caps bad in the Horizontal or vertical drivers for the yoke coils.
do not get killed playing with HV ok?
Posted on Aug 30, 2017
  • Anonymous Sep 01, 2017
    no photos of screen how sad.
    buy newer screen
    life is too short for VACUUM tube CRTs.
    id consider it a fire hazard in my home this old. sure would,
    upgrade for $50
3 Suggested Answers
SOURCE:
SOURCE: i need it's schematic
no work
Posted on Jun 17, 2008
  • 109 Answers
SOURCE: no power
check for Horizontal output transistor and flyback conditions..
Posted on Mar 09, 2009
No Signal After Restoring PC to Factory Settings
It's not recognizing the TV as a monitor. Find out what resolution the TV runs, then set the PC to those using the other monitor.
Apr 06, 2017 | Compaq Computers & Internet
Horizon gray bar
One or two CCFL lamps inside the display panel might have gone weak.; [low light emission]. Check and replace them.
May 12, 2012 | Vizio VO320E LCD TV
I want Pin connection of VGA cable Diagram From CPU to Monitor
Try to search in the internet,just type and search the VGA connector diagram.
Jul 13, 2011 | Compaq V700 17" CRT Monitor
No power compaq v700 monitor
Mar 09, 2009 | Compaq V700 17" CRT Monitor
Monitor can not open
usual cause is defective 5 volts 3 pin regulator..
Jan 01, 2009 | Compaq V700 17" CRT Monitor
Need to swipe-out pc
there's a couple things you can do...
you can contact HP/Compaq and order replacement recovery discs.. visit this link for more info
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bph07143
you can try running ubuntu http://www.ubuntu.com/ on your computer, its pretty easy to install and its really neat. its very different from windows however but it works great. best of all its FREE!
of course you can look filesharing sites for copies of Windows XP or Vista (wink wink), but i can't help you with that since its agains't FixYa's piracy policy and i don't want trouble.
Dec 30, 2008 | Compaq V700 17" CRT Monitor
Compaq Armada M300 Loose Display Screen
There is no adjustment on the m300 v300 m700 v700. These hinges will have to be replaced. I do have a set from an v300 am not sure if they are compatible but you can have them if you want.
Mar 18, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq V700 17" CRT Monitor Logo
82 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
