Question about Brother MFC-685cw InkJet Printer
MFC-685CW Unable to Print 50
I have read the solutions for this problem but i cant fix mine. I have managed to pull the printer down so that the print head is accessable.
This encoder strip - is it the clear piece of film/plastic that is anchored at one end, and attached to a spring loaded white clip at the other ?
If so, i cannot see how it is possible for it to become misaligned, maybe i am looking at the wrong thing ?
Can somebody help by posting a better picture
Cheers - Ian - Australia
aomcopier
  • 22 Answers
SOURCE: Lexmark 5150 All in One Printer - Encoder Strip
I hope this helps. There is usually a spring that holds the encoder strip on either or both ends. The have a hole that the spring is inserted in. The hole brakes and the encoder strip comes off. If you have all the parts including the spring you can modify the encoder strip by cutting a piece of strong tape to fit over where the strip was broken. I use packing tape. Poke a hole in it and reinstall encoder strip. You should also be able to buy a new strip but I am not sure. I also would go to an electronic store and find a tool to help. Buy a spring hook. It is designed to help push on and pull off springs and they only should cost a couple bucks USA. I hope this helps, Bill
Posted on Apr 01, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc845cw
See picture how to do that :-)
Posted on Oct 02, 2007
Cindy Jo
  • 74 Answers
SOURCE: Encoder Strip
What is the question? Where should you put the numerical strip of ownership? Let me know and I will send you in the right direction.
Cynthia Charczenko
Posted on Jan 15, 2008
  • 33 Answers
SOURCE: error 0001001D
Are you still having problems?
Posted on Apr 18, 2008
SOURCE: Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
Posted on May 17, 2008
My brother printer model is mfc-685cw. i checked paper jam but my lcd screen say unable to print 50. I am unable to shut down also.Then i switch of my printer after one hour i started but again i saw same...
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
http://www.fixya.com/support/t227515-printer_paper_jam_brother_mfc
Sep 01, 2010 | Brother MFC-685cw InkJet Printer
I am unable to print black documents on my mfc-685cw printer. i changed the ink, and still unable to print. it will print in all other colors but black
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | Brother MFC-685cw InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
LIGHT FLASSING CANT PRINT
Error 50: Purge cam problem. mfc/dcp has to be taken to service. No chance to fix it by yourself. sorry!
Mar 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-685cw InkJet Printer Logo
183 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
