Question about Aspire Acer 7520-5071 Notebook
Hi, I have an acer 7520G laptop, amd turion x2 250 Gb disk 4 gb ram etc etc... When adding another SATA 500gb drive in the bay it won't start up anymore, doesn't get passed the microsoft start up screen, just sits there and waits ;-( If I remove the added drive it works fine? it seems to be a pretty straight forward procedure but obviously something is not working right... on the HD sled there are clearly marked Main and Second referring to the HD drives. second drive is a 500gb Samsung, Original drive is a 250 gb Western Digital! Anybody else experiencing these problems?? Cheers Joe
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Can i connect 500GB sata hard disc and 2 - 2GB ddr2 RAM to this mother board????
The motherboard will take a 500GB SATA hard drive as there are 4 SATA ports on the board. As for the memory then it will only take 2GB maximum.
Regards.
Dec 15, 2010 | Intel D945GCCR Motherboard
I want to upgrade the hard drive. What type do I need ide, ata, sata
the upgrading can be done only if the motherboard support if your laptop had sata provision you can use them if you dont have you cant use sata check the motherboard
Dec 15, 2010 | Acer Aspire 5100-5480 Notebook
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Hi I have a Fujitsu Mobile MHV2120BH 120 GB SATA Hard Drive, I want to install XP home on it. But Ive been reading that I need Sata/raid drivers for the computer to see the drive. I have a HP Pavilion...
The SATA drivers will be on the XP disk. Just put the XP disk in your CD drive, partition the new disk and load the OS.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Sep 16, 2010 | Fujitsu Mobile MHV2120BH 120 GB SATA Hard...
Hi What is te type of disc installed on ACER Aspire 5022 WLMI 100 GB? What is the rotation speed of this disc? Thks
rocessor - AMD Athlon X2 QL-64 / 2.1 GHz ( Dual-Core )
  • RAM - 4 GB (installed) / 4 GB (max) - DDR2 SDRAM
  • Hard Drive - 500 GB - Serial ATA-150 - 5400 rpm
  • Operating System - Microsoft Windows Vista Home Premium
  • Screen - 17.3" TFT 1600 x 900 ( WXGA+ ) - 24-bit (16.7 million colours) - CineCrystal
  • Optical Drive - DVD±RW (±R DL) / DVD-RAM - integrated ... [ more info ]
  • Sep 04, 2009 | Acer Computers & Internet
    Ihad a ACER Aspire 5052AWXMi, AMD Turion MK38,
    yes you can upto 2GB and 160GB HDD
    bkas your laptop having DDR ram, 80GB is ATA HDD,
    Jun 22, 2009 | Computers & Internet
    Where can i find sata driver?
    frist you should call in hp call center who send you link of sata hard drive,s drivers.
    i send you link
    http://www.icare.hp.com.cn/TechCenter_StaticArticle/45904/59724.zipchcenter_stati
    Jan 30, 2009 | Microsoft Computers & Internet
    Laptop
    here are some details below find the right one and take it
    Model No: TM 2403NWXCi
    Platform: Intel Celeron-M Processor 370 (1.5 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    RAM: 256 MB DDR2 400 RAM
    HDD: 40 GB
    Optical Drive: DVD-Rom/CD-RW Combo Drive
    Display: 14.1" Wide Screen XGA TFT w/1280 x 800 resolution
    Graphics: Intel GMA900
    Other Features: Ethernet / Integrated 802.11b/g Wireless LAN/ 56K Fax-Modem/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 6-Cell Lithium Ion Battery
    O.S.: Linux
    Warranty: 1-Year Global Warranty
    Price: Rs. 27,999*
    Model No: TM 2424NWXCi
    Platform: Intel Celeron-M Processor 380 (1.6 GHz, 1MB L2 Cache, 400 MHz FSB)/ Intel 910GML Chipset.
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    Model No: Aspire 5002NWLMi
    Platform: AMD Turion 64 ML-30 (1.6GHz)
    RAM: 256 MB DDR333 RAM
    HDD: 60 GB
    Optical Drive: DVD-Dual Double Layer drive
    Display: 15.4" WXGA Acer CrystalBrite TFT Screen w/1280 x 800 resolution
    Graphics: N.A.
    Other Features: 10/100 Ethernet, 56K Modem, Integrated 802.11 b/g WLAN with Acer SignalUp, Integrated Bluetooth
    Weight: 2.9 KG
    Battery: 8-Cell Lithium Ion Battery
    O.S. : Linux
    Price: Rs. 37,999*
    Model No: Aspire 5004NWLMi
    Platform: AMD Turion 64 ML-34 (1.8GHz)
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Apr 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
    To u my friend
    nothing much buddy ...
    HDD: 40 GB
    Weight: 2.38 KG
    O.S.: Linux
    Price: Rs. 27,999*
    HDD: 40 GB
    Weight: 2.35 KG
    O.S. : Linux
    Price: Rs. 28,499*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 37,999*
    HDD: 60 GB
    Graphics: N.A.
    Weight: 2.9 KG
    O.S. : Linux
    Price: Rs. 38,499*
    Model No: Aspire 5502ZNWXCi
    Platform: Intel Centrino Mobile Technology based Processor Pentium M 735A (1.7 GHz / 2MB L2 Cache / 400MHz FSB) / Intel 915GM Express chipset.
    HDD: 60 GB
    Optical Drive: DVD+CDRW Combo Drive
    Display: 14.1" WXGA CrystalBrite TFT with 1280 x 800 resolution.
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 2 USB Ports.
    Weight: 2.38 KG
    Battery: 6-cell Battery
    O.S. : Linux
    Price: Rs. 40,499*
    Model No: AS 1641NWLMi
    Platform: Intel Centrino Mobile Technology based Processor PM 725A (1.6 GHz / 2MB L2 Cache) / Intel 915GM Express chipset
    RAM: 256 MB DDR2 533 RAM
    HDD: 60 GB
    Optical Drive: 8X DVD-Dual Double Layer Drive
    Display: 15.4" WXGA CrystalBrite TFT with 1280 x 800 resolution
    Graphics: N.A.
    Other Features: 56 Kbps modem / LAN / Intel PRO 2200 -802.11b/g Wireless LAN Integrated/ 3 USB Ports
    Weight: 2.38 KG
    Battery: 4-cell Battery
    O.S. : Linux
    Warranty 1-Year Global Warranty
    Price: Rs. 42,499*
    Apr 14, 2008 | Computers & Internet
    Aspire Acer 7520-5071 Notebook Logo
    Top Aspire Computers & Internet Experts
    Jax Planet
    Jax Planet
    Mark Dewar
    Joe Goldman
    Joe Goldman
    Are you an Aspire Computer and Internet Expert? Answer questions, earn points and help others
