Question about GE Microwave Ovens
Constantly runs but does not heat
We shut the door and it starts running on it's own but does not cook. The buttons do not work to shut it off. The only thing that we can do is unplug it. We plug it back in and it starts running again. Nothing shuts it off except unplugging it. We bought it and installed it July 2008 and has been working fine until now. What can I do? My GE microwave is a JVM1540SM2SS. When warming food and the cycle expires, it stops heating and beeps but the fan kicks into high mode. Sometimes the fan will not cut off, it only toggles between high and low. I have to slap the right side of the control panel to make it cut off. The turn-table also starts turning as soon as the door is shut. Again, I slap the control panel and it stops.
  • byronlong May 17, 2009
    Is this circuit board located behind the control panel? I just found my receipt, great timing for GE, I bought it in March of 2008.
    Thanks for the info! Looks as though I'll spend close to $100 just for the part. Think I will be replacing instead of repairing.
    Sergeant:
    Champion:
  • 387 Answers
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
Posted on May 17, 2009
  •  Robert Allocca
    Robert Allocca May 17, 2009
    Yes, GE now make garbage products. Replace it with an LG which is far superior.
  •  Robert Allocca
    Good decision. I hope you willl not buy a GE product.
When cooking the fan doesn't run anymore. When I start cooking food the fan used to start right away, now it runs for a few seconds then stops but the food is still being heated.
The fan, a door switch, or control board relay may be causing the fan issue. Running the MW without a fan will not only cause steam buildup inside the cavity, it will cause the magnetron to overheat. If the MW has a thermal protector on the mangetron, it should shut the oven off when the temperature gets too high.
Nov 08, 2017 | Microwave Ovens
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
Model R-1460, when I shut the door it runs but doesn't heat up. What needs to be done to fix it?
Do you mean that when you close the door, the fan comes on? If so, it sounds like a bad door switch. Probably the secondary interlock switch.
This failure is caused by opening the door when the unit is in cook mode. On ALL microwaves, not just one or two brands.......
Be sure to push the stop button before opening the door to add or stir... Or wait for the cook cycle to end. (This is why microwaves have a two step function on the stop/clear button. Hit stop once to stop cook mode and twice to reset timer).
You should use an ohm meter to check all 3 switches. The switch can be either stuck 'closed' or physically closed but not 'making' electrically.
Sep 13, 2009 | Sharp Microwave Ovens
New Frigidaire Microwave fan and turntable run constantly, will not cook.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
If you don't have warranty coverage for some reason:
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 29, 2008 | Frigidaire Microwave Ovens
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
Microwave buttons not responding - microwave running constantly with door shut
It seems the micro switch for the door close have moved from and is not aline the door clip or the micro switch is faulty
Dec 17, 2007 | Sanyo EM-S9515W Microwave Oven
Sounds like a defective door interlock switch or a broken switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it's not a problem with the door switch or door switch mount, it may be a problem on the control board. We repair these for $39.95 for customers nationwide. Reply back if you still ned help.
May 29, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Microwave Ovens Logo
288 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
