Question about Microsoft Windows XP Professional
Wireless internet is not connecting
The option is not their as setup wireless network so please give a complete setup of wireless internet connection with modom. as a wireless router...
please sir,
  • 59 Answers
Dear,
Pl check with your modem wirless port is active or not samething in to your laptop and desktop.
after connection pl give your modem ip range and search for wirless device.
Regards,
Ravindra Shah
Posted on May 22, 2009
Need to connect my tv to the internet
Wifi dongle will available for TVs. If you had USB port on TV,connect that dongle on that and access internet.
Nov 10, 2013 | Sharp LC46SB54U 46 in. LCD TV
The router installs fine on one lap but I still can't connect my other laptop
your first option is to go to http://192.168.0.1 Here Select admin from the drop down menu and leave the password field Blank.
Once the page loads youll see a series of options. this is the routers linux interface section. you will see D-link on the top left.
Select the first option Install router.
the steps would be as follows.
Step 1.
Insert the Router Setup Wizard CD in the CD-ROM drive. follow The step by step instructions. Once you done this And i believe you have already. see step 2
Step 2.
Select the Option
Setup on the Top > Internet is on the left side.
Under the Internet connection Wizard Hit the Setup Wizard button.
Step 3.
Now on the Setup page Same place where the setup Wizaed is. just below their is another option called Wireless Security Setup Wizard.
Press the Launch Wireless Security Setup Wizard Button.
Read the 3 steps then click the next button to continue.
Steps for step 3.
1. Enter a SSid this will be the network name you see when you want to connect to your own network. example.. MyHome
2. Select your security option then click next. (For simplicity chose WEP)
3. click apply.and let the router reboot.
when it comes back online you should see your network you just setup. our example was MyHome.
If you are new to router setup. use the Wep security called Good on your routers security WEP. and just write the key it gives you down. this is the code you need to connect your devices and is considered ok for a simple home network.
Nov 22, 2011 | D-Link DIR-615 Wireless Router
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Linksys will not connect correctly to my laptop
Try a new setup.
On your computer, insert the supplied Setup CD that came with your Router. Setup should start automatically.
NOTE: If setup doesn't load automatically, please click here.
The first screen greets you with the Software End User License Agreement. Please take a moment to read through and understand the agreement. Once you're ready, go ahead and click Next.
NOTE: The Linksys Wireless-N Router model displayed on the setup screen may vary based on the Linksys Wireless-N Router model you have.
Step 4:
On the next window, please follow the on-screen instructions on how to connect your Linksys Wireless-N Router:
kb21463-002_en.png Plug one end of the power cable into your router and the other end into an electrical outlet.
NOTE: The Linksys E3000 features a power switch, located at the back-end of the unit, next to the power port. Please make sure that this switch is ON. Other Router models may not have this feature.
kb21463-004_en.png Plug the Internet cable into the yellow port in the back of your router labeled "Internet". Plug the other end into the modem.
QUICK TIP: Click Show me how for an illustrated guide on how to complete the above instructions.
After completing the above steps, click Next to continue.
Step 5:
Setup will now perform a series of tests to determine the optimum configurations for your network. You may notice your computer connecting and disconnecting to a wireless network several times. This is normal. Your wireless network is simply being secured.
NOTE: The setup process automatically generates a unique and secure Wireless Network Name (SSID) for your convenience.
kb21463-006_en.png Step 6:
The next part of the setup automatically detects your Internet connection type. If you are using a DSL connection, you may be requested to enter your account details. If this is the case, simply enter your Account name and Password in the allocated fields. Otherwise, you may skip ahead to Step 7.
NOTE: If you don't know your Account name and Password, your Internet Service Provider (ISP) will be able to provide these details.
QUICK TIP: Click Examples to see what your Account name should look like.
kb21463-007_en.png NOTE: Cable Internet users will not see the above screen.
Step 7:
Sit back and wait a moment as setup finalizes your Linksys Wireless-N Router settings, and re-establishes your Internet connection.
kb21463-008_en.png Step 8:
Once your Internet connection is up and running, a confirmation window similar to the screenshot below will appear on your screen. Your Linksys Wireless-N Router is now secure and connected to the Internet. This concludes the setup process. Click OK to continue.
Step 9:
You will now be taken to the main Cisco Connect window which lets you manage and further personalize your network settings. If you would like to learn more about the available features in Cisco Connect, please click here. Otherwise, you may click on the Close button to exit Cisco Connect, and begin surfing the Internet right away.
NOTE: To launch Cisco Connect again at later time, on a Windows computer, go to Start>All Programs>Cisco Connect. To launch Cisco Connect on a Mac computer, navigate to the Applications folder in Go, and then start Cisco Connect. For more help on this, please click here.
kb21463-010_en.png NOTE: Cisco Connect is automatically installed each time you use the Setup CD or Easy Setup Key to setup or connect to your Linksys Wireless-N Router.
Nov 02, 2010 | Linksys Wireless-G WRT54G Router
I had a computer problem and now my netgear won't work. When I got my desktop up and running again and now we can't connect to the internet on our laptop, wirelessly. For some reason the Netgear wireless...
Please follow the below steps to configure settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
If your laptop has Windows XP then perform the below task:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
If your laptop has Windows Vista then perform the below task:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
If your laptop has Windows 7 then perform the below task:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
Hope the above steps allow you to resolve the issue. If you need any further help then revert back so that we can assist you further.
Regards
Anand
Apr 12, 2010 | NetGear WGR614 Wireless Router
I don't know how to use wifi on my Toshiba A45 S120
Open the Network Settings program. Click on the Control Panel in your "Programs" bar and select "Network Settings." This will give you options for modifying how you connect to the Internet. Select "Connect to a Network" or "Show Network Status and Tasks." Both selections will show you whether you are disconnected from the wireless network. Select "Manage Network Connections." This selection is located on the left side of the window; clicking on it will show you whether you are connected to a local area connection or wireless network connection. Engage the wireless connection. Turn your wireless switch to "On," then right-click on the wireless network connection. Select "Connect/Disconnect." Wait for the IP address acquisition. It may take a few minutes for your Toshiba Satellite to pick up the signal and transmit your IP address. When this is complete, you will see the word "Connected" next to the name of your wireless connection, and a series of bars that indicate signal strength. Launch your favorite browser to access the Internet using the wireless connection.
Feb 11, 2010 | Toshiba Satellite A45-S120 Notebook
How do i make my speedstream 6520 wireless?
"If your PC has not been connected to a broadband modem or other network device, you will need to
perform the PC configuration procedure below. Remember to restart each PC when finished. If your
PC has been connected to a broadband modem or other network device, continue to the “Using the
Wireless Connection” section below.
1. Start your Web browser. In the Address box, enter the following: »speedstream.
2. Press Enter. The SpeedStream Simple Setup Wizard will launch.
3. When prompted, enter the Internet connection information provided by your
Internet Service Provider.
4. At the end of the Setup Wizard, you will be given the option to either connect to
the Internet or further configure the optional settings of the gateway.
5. If additional configuration is desired, select the icon for the service or option
you wish to configure: the gateway’s firewall and security settings, User
Profiles and content filtering, or home network options."
"Using the Wireless Connection
By default, the SpeedStream® Gateway is configured to work
seamlessly with other SpeedStream® wireless products. The default
wireless interface settings are:
SSID: SpeedStream
Channel: 11
Mismatched wireless settings will prevent successful
wireless network connections between devices, so
you may need to reconfigure some wireless settings
to ensure that all settings match between wireless
devices if you are:
a) Using another manufacturer’s wireless products
b) Adding the SpeedStream® Gateway to an existing
wireless network
The Setup Wizard will walk you through setting up wireless settings."
Jun 14, 2009 | Computers & Internet
Ntegear wgr614v5
If your computer is online when it is connected to the modem using an ethernet cable, you can disconnected the pc from the modem. Use an ethernet cable to connect your modem to the ethernet port of your NETGEAR ROUTER. Turn on power of the net gear router. Connect your pc to the NETGEAR. Right click the network connection icon(at the buttom right of your screen) then click STATUS then click details. You should get an ip of 192.168.x.x. Open your browser, type on the address field http://www.routerlogin.net
USERNAME:admin
Password:password
when you are in the router page, click on set up wizard. it should configure the router and give you internet connection after the wizard completes
Mar 11, 2008 | NetGear WGR614 Wireless Router
Canot connect wireless
Make sure that your wireless is set to access point only and not firewall mode.
Feb 03, 2008 | Buffalo Technology WHR-G54S Wireless...
Microsoft Windows XP Professional Logo
124 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
