I connected my laptop to my tv but the picture is in 3 bits on the screen and fuzy top and bottom
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 78 Answers
Which method you used to connect it , check resolution of the laptop it may work fine , if you are using a normal TV ( non LCD ) it's a common problem , play around with resolution and it may fix
Posted on May 17, 2009
I have purchased a Samsung Led 50 inches tv in USA, The picture is not displayed full on the screen. Can you please suggest?
These are generic instructions for all TV's and all Remotes:
1. Press 'Menu' key on Remote (or 'Setup' key).
2. Go to Setup, View, or Picture tab (whichever one you've got in your Remote's Menu or Setup)
3. Change your Zoom or View aspect.
NOTE: Depending on the dimensions of your TV, you simply may not be able to view the entire picture using a correct aspect ratio (NOT stretched). On my 42" RCA is use a 4:3 Zoom setting to fill my screen but, it chops a little bit off the top & bottom. It's the best I can do with my current setup.
Dec 17, 2014 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
How to change from analog to digital
If you have an old analogue TV and wish to keep it, buy a digital set top box (which is just a digital tuner with no screen), then connect the antenna and TV to that. These STBs are quite cheap, and a good name brand will give you an excellent picture, with one qualification.
This is that the old analogue TVs have a screen proportion of 4:3, whereas the digital broadcasts are 16:9. So by keeping an old screen you will lose a bit of the picture at each side, or see a black band at top and bottom.
If you don't like that, you will need to buy a flat-screen (digital) TV and toss out the old one. There is a huge range of sizes and prices, so if you look for a special from a recognised retailer who will stand by the warranty, you would be OK.
May 31, 2014 | Orion LCD TV SLED2480 Sansui - 24"...
Toshiba 46xf355db upon start up there is a fuzy picture and lines
I believe that tv is about 10 years old. The best solution and probably most cost effective is to replace it.
May 17, 2017 | Televison & Video
Red fuzy screen
You had not fixed all connector properly.
Jan 23, 2010 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Screen display mode
Because the broadcaster is giving you the bars at top and bottom there is nothing you can do except use the different aspect or screen formats that are on your TV. Please take a few moments to rate my answer. Thanks....
Nov 20, 2009 | Televison & Video
Screen plays double
It is called convergence out IC failure and you need to replace 2, ICs in convergence section of TV.
If you are familiar with TV repair or can solder electronics parts in circuit board then let me know exact model number of Panasonic TV to guide you more with technical info or call local TV repair shop for repair.
Apr 24, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a Sony Grand wega im getting fuzy purple diagnol lines
Try changing the component cable to your Video 6 and see if you have the same problem. I tried this and figured out that the set top box from Verizon component connections may be bad. I also tried changing to a different set of component cables to troubleshoot. I figure its the box not my TV.
Mar 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Durabrand 21" tv picture distorted
To properly diagnose this problem,access to the servicer menu will be important.Also,the service literature for the horizontal and vertical circuits may be needed.Contact a tech who can help you that is familiar with Durabrand.
Sep 25, 2007 | Durabrand DU1901 TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
