Question about Apple iPod nano
Ipod volume control
My volume control password is lost how to unlock it?
  • Anonymous May 19, 2009
    my ipod nano volume control is locked and i forgot the code
  • 952 Answers
Use itunes and restore your ipod to factory default. Thats the only way to fix your password issue. I hope this helps.
Posted on May 17, 2009
How to unlock my volume control on my ipod 80gb classic
If you have the password or if no password was set, you can unlock it by going to Settings -> Volume Limit. Control the limit with the click wheel and press the play button to accept.
May 07, 2012 | Apple iPod classic MP3 Player
Volume limit password reset on ipod nano
Hi
How to Unlock iPod Volume Limit
Your iPod volume can be limited, and in many instances, a PIN number will be necessary to remove the limit. If you've forgotten or misplaced your PIN, you can still unlock your iPod volume limit using your computer.
1 Connect your iPod to your PC. Make sure your hidden folders are visible.
2 Navigate to the "iPod_control" folder. This will be a hidden folder. Once you've found the "iPod_Control" folder, navigate to the "Device" folder.
3 Locate the file named "_volumelocked" in the "Device" folder. Delete this file.
4 Eject and restart your iPod.
5 Navigate to "Settings" on your iPod. Select "Volume Limit." You'll be able to reset your volume limit with a PIN or password.
Tips & Warnings
Do not listen to your iPod at high levels for long periods of time; doing so can damage your hearing.
Nov 23, 2011 | Apple iPod nano
How do u unlock volume on ipod
  • From your iPod's main menu scroll down and select 'Settings > Volume Limit'
  • Enter your 4-digit combination numbers you used to set the volume limit using the scroll wheel to select the numbers
  • Press the 'Center' button to confirm your password
  • Use the Click Wheel to move to the maximum level on the volume bar to remove any restriction on volume
  • Press the Center button to confirm the change
What To Do If You Can't Remember Your 4-Digit Password
  • Download and install the latest version of the iTunes softwarehttp://www.apple.com/itunes/download.
  • Open iTunes and from iTunes interface click on 'Users iPod' under 'Devices'and click on the 'Summary' tab where you will see information about your iPod.
  • Click on the 'Restore' button. Restoring your iPod will take a while so be patient. Be warned though all your data will be lost from your iPod but your iTunes library will stay intact.
  • After restoring your iPod, unplug it from your computer, and reconnect it once again.
  • All your songs and files will be downloaded back onto your iPod. If it doesn't start downloading automatically, go to 'File > Sync iPod'.
Jan 24, 2011 | Apple iPod nano
Dont know the code to unlock my ipod screen and volume limit
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Jan 04, 2010 | Apple iPod nano
Volume limit unlock code
Apr 17, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
I forgot password of my ipod model no: A1137,2 GB
HELLO!!!!
I've been using iPod nano for 1 year.I forgot password for volume limit lock. so i can't change the volume.Plz tell me how 2 unlock the volume limit. Reply @ early as possible.
Jan 10, 2009 | Apple iPod nano
Volume control was locked when I received the ipod
go ask the seller... they will know and if they dont then just ask for a replacement...
Dec 26, 2008 | Apple iPod nano
Ipod lock code
Connect the iPod to the computer and restore through iTunes.
Aug 07, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Ipod nano lock forgot password
First, try to restore using iTunes. If this doesn't work, place your iPod in disk mode (hold the menu and center buttons down togther) and as soon as you see the Apple symbol come up hold the center and play (bottom) buttons down together until you see a check mark (disk mode). It may take a few trys.
Now connect your iPod to your computer. Go to my computer and right click the drive associate with your iPod (for example F: ) and scroll down to FORMAT. THIS IS VERY IMPORTANT - CHOOSE FAT32 and then check the "Quick Format" box. After you do this then use iTunes to Restore your iPods another time.
Jan 31, 2008 | Apple iPod nano
Apple iPod nano Logo
112 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
