Question about Kodak ScanMate i1120 Flatbed Scanner
Kodak i1120 scanner smart touch button doesn't start scanner
OS is Vista Home Basic. I installed driver and smart touch software that came with the scanner. The button on scanner doesn't initiate scanning but scanning works fine when started from system tray menu. Removed scan driver and installed latest driver download, then installed smart touch patch upgrade. Again, everything works normally except the scan button on the scanner. Interestingly, I installed the original software on an old notebook running Win XP and the scan button works when scanner is connected to that PC but I also installed the original software on a desktop PC running the same version of Win XP and button won't work with that PC. It is obviously a software issue which I can't find addressed in the literature or mentioned anywhere on the web. Kodak call centre could only suggest taking unit back and exchanging it. Did that. Same problem. Kodak help is pretty useless. Anyone have any ideas to fix the problem? The scan button feature is one of the main reasons I bought the scanner.
5 Suggested Answers
SOURCE: Kodak Smart touch button not working
I had same problem with Kodak s1220 scanner. Smart button didn't invoke the oem program in Windows 7 64 bit. It started the windows program which wasn't as slick as the oem. I un-installed and re-installed programs in all kinds of orders to no avail. The updates didn't address the issue. I finally started digging in the various folders in the update package and found a directory called "Button app" it had a install setup program and a file called "killKSS". After that it worked! Sweet. Now if I can only charge kodak for my time.
Posted on Jan 17, 2010
SOURCE: Acrobat 8.1
Upgrade to Acobat 9.0 Pro. It seems to work in that can scan pages for a document, HOWEVER, adding/appending to already scaned pages for a document seems to crash 9.0. For example, say I scan in pages 1 - 4. I cannot then scan pages 5 -6 as part of the same document--crashes Acrobat.
I think this finally proves the problem is Acrobat 8.0 and NOT the i40 drivers.
Posted on Mar 18, 2009
  • 7 Answers
SOURCE: Kodak 3520D scanner Front Scan Mod gain issue
Lamp need to be replace and re-calibrate.
Posted on Jul 20, 2009
SOURCE: Scanner runs only on Windows 95
staviemarinmaskin@swipnet.se
Posted on Aug 10, 2009
Kodak scan mate i1120 not connecting to outlook
Don't use outlook to acquire images. Use Smart Touch. Within Smart Touch you can call a program like Outlook to open and accept a scanned document. Read the user guide for Smart Touch. http://graphics.kodak.com/docimaging/us/en/support_center/index.htm
Mar 06, 2014 | Kodak ScanMate i1120 Flatbed Scanner
Mac kodak scanmate i1120
I am assuming you are inquiring about MAC drivers for the i1120? Not happening.
Jan 24, 2014 | Kodak ScanMate i1120 Flatbed Scanner
Trying to set-up a Kodak Scanmate i1120 Scanner on a notebook with Windows 7 Professional 64 bit Downloaded and installed "InstallSoftware_i1100v1100_v1.11.exe" When I try to run "Scan...
You need to uninstall old driver then reinstall new driver from below link. Click here Click on above link download driver for your os uninstall old driver and all usb drivers from device manager then install driver. Make sure there is not any incompatible usb drivers in computer. Let me know if you need further assistance. Thanks for using FixYa.
Jun 21, 2011 | Kodak ScanMate i1120 Flatbed Scanner
I bought the Canon Canoscan N1240u flatbed scanner. I downloaded the drivers and plugged in the cord that came with it but it doesn't do anything.
Just to be sure, did you install the driver in addition to downloading it? Full software or basic driver. The software must be installed before connecting the data cable. What OS are you using? (if you have Vista 64-bit, it is not compatible) If you didn't install the software, uninstall the OS driver and disconnect the data cable before attempting to install the Canon software. Otherwise see the notes for scanning with other software.
First are you trying to use the scanner buttons? These will only work if the full software is installed. For the buttons to work, you have to set up the scanner button destinations in the Canon software first. Also a monitoring program must be running for the button presses to work.
So try scanning from the computer first. If you still get an error, try a new data cable. If you are using a USB hub, try a direct connection. Make sure your USB ports work with a known working device. You can also check if the ports are disabled for security (in the Device Manager for Windows) or power savings (an advanced setting from the Screen Saver).
Once you have scanned successfully from the computer, go to the Settings section of the Toolbox to set the default destinations for the scan buttons.
If you only installed the basic driver, you can scan with Paint (XP or Vista), File > Import from Camera or Scanner > New Scan. Vista also has Windows Fax and Scan (New Scan) and Photo Gallery to acquire scans. I don't know the Mac software. Third-party software will also work if installed.
I hope this helps.
Jan 12, 2011 | Canon CanoScan N1240U Flatbed Scanner
How to install kodak i 1220 flatbed.
1st You download Scanner Driver. Kodak Scanner Driver After this install the Scanner driver in the system.
Installation of Scanner Driver
  • Go to the control panel
  • Click on the System Icon
  • Click on the Hardware Tab
  • Click on the Device Manager then
  • Select the Unknown Device or scanner device where yellow Question Marks sign on it.
  • Right click on it and uninstall it.
  • After this go to the top of the device manager and click on scan for hardware changes.
  • Driver installation Wizard start.
  • Brows Your Driver from the Hard Disk and click on next.
  • Driver will be install.
May 03, 2010 | Kodak ScanMate i1120 Flatbed Scanner
Problems with Kodak i1220 Smart Touch software
Go into C:\programdata\ and remove the kds_kodak folder. It may ask you to skip files it can't delete. Just click skip for all of them (probably around 15 files). Then reboot your computer and you should be able to scan.
Jan 23, 2010 | Kodak i1220 Pass-Through Scanner
Kodak I1220 is connected but can not be started by button nor smart touch
update the driver and the smart touch driver from the kodak website. make sure that the scanner is not connected when you do this. if this does not resolve the problem, then contact the kodak scanner support call centre as this could be a problem deeper within the pc
Nov 09, 2009 | Kodak i1220 Pass-Through Scanner
Aug 20, 2009 | Kodak ScanMate i1120 Flatbed Scanner
Scanner installation in vista OS
i m using color flatbed scanner of acer i m not able to install the mira CD in windows vista home basic what is the solution for this .. the cd given to me is MiraCD 90.S0805.406
driver snapscan e 20 per vista os
instalacion de scanner 5000
I hae a MiraCD 90.s0805.406 -
Dec 12, 2008 | Office Equipment & Supplies
this is not support you have to go the web site and download the software and driver of the scanner o/s vista 32/64 any one
Jun 01, 2008 | Office Equipment & Supplies
Kodak ScanMate i1120 Flatbed Scanner Logo
1,821 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
