Question about Iomega Super DVD (33110) DVD±RW Dual Layer Burner
I have an external DVD-Writter Iomega. How can read a DVD Ram of 9.4 GB capacity in this DVD Rom Drive. Thanks in advance George
  • gv_parapuzha May 18, 2009
    I want to read a DVD Ram of 9.4 GB Capacity in this drive.
Get a nero or cd&dvd burner to write
Posted on May 18, 2009
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
Hi!... I am using window 7 ultimate 64 bit. I am facing the problem of full HD. earlier when me using window Vista that has been ok. If there is any solution plz let me know!.. thanks Moiz Raja
windows 7 os requires atleast 16GB avilable space while windows vista requires atleast 15gb. It could be true that your system requirements are not sufficient for the new os you want to install
If you want to run Windows 7 on your PC, here's what it takes:
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
  • DVD-ROM drive
If you want to run Windows Vista on your PC, here's what it takes:
  • 1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
  • 40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
  • Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
  • DVD-ROM drive
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | HP w1907 LCD Monitor
My compaq presario700 laptop showing disk damaged while am installing windows xp..wat i do now...tanks in advance for u r advice..
I have had this issue in the past 9 out 10 times it's the disk has damage and that sector cannot be read to complete install,only other fix is try a external drive and if it loads ok your lazer is getting weak and you will need new dvd or use external drive cheaper fix,good luck
Jan 08, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
Gateway mx3222b laptop ram upgrade problem
your computer does not support 1GB memory sticks. The max memory for that system is 1GB which would be 2 sticks configured as 512MB
see below for the specs (i bold, italics and underlined the main part)
Processor Intel® Celeron® M Processor 370
1 MB L2 Cache | 1.50 GHz | 400 MHz FSB Display Screen 14-inch Widescreen Ultrabright™ WXGA TFT Chipset Via VN800 Memory 256 MB DDR2 (1 × 256 MB) SODIMM
Total slots: 1 DDR2 slot | Available slots: 0 DDR2 slots
Expandable to 1 GB Video S3 Graphics UniChrome™ Pro IGP
Up to 64 MB shared VRAM Audio AC'97 2.3 Compliant Hard drive 40-GB 4200 RPM hard drive Optical drive DVD +/- RW Multi-Format Double Layer
Write maximum: 8X DVD+/-R, 6X DVD-RW, 8X DVD+RW, 2X DVD-R DL, 2.4X DVD+R DL, 24X CD-R and 16X CD-RW discs
Read maximum: 24X CD-R/RW/ROM, 8X DVD-R/RW/ROM, 4X DVD+/-R DL, RAM discs Media Reader 4-in-1 Digital Media Manager
Secure Digital™, Memory Stick®, Memory Stick-Pro®, and MMC™ Modem 56K ITU V.92 ready fax/modem Network 10/100 Mbps built-in Ethernet
802.11g integrated wireless (up to 54 Mbps) Interfaces
  • 2 - USB 2.0 ports
  • 1 - VGA external connector
  • 1 - RJ11 (modem)
  • 1 - RJ45 (Ethernet LAN)
  • Microphone jack
  • Headphone jAck
Pointing device Touchpad with vertical scroll zone PCMCIA 1 - Type I or Type II; Card Bus Battery 6-cell Lithium-ion Dimensions 1.1 to 1.24-inches (H) × 13-inches (W) × 9.7-inches (D)
28 to 32 mm (H) × 330 mm (W) × 246 mm (D) Weight 5.01 pounds
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
  • 2 - USB 2.0 ports
  • 1 - RJ11 (modem)
  • Microphone jack
  • Headphone jAck
Chipset Via VN800
Expandable to 1 GB
Interfaces •2 - USB 2.0 ports
•1 - VGA external connector
•1 - RJ11 (modem)
•1 - RJ45 (Ethernet LAN)
•Microphone jack
•Headphone jAck
Weight 5.01 pounds
Mar 03, 2010 | Gateway Computers & Internet
Can Windows 7 be installed on X05? I get ACPI incompatible BIOS and have updated to last known one. Please help!
The only issue i can see is if your your ram has not been updated since leaving the factory, you will notice from the tables W7 requires a min of 1GIG and your machine leaves the factory with 256mb(dependant on country possible) so check your ram. I run windows 7 on 2GB and its great, your machine will take 2GB. The Samsung X05 was released 2004 and the NVIDIA Geforce 4 should be fine. i would point out drivers and compatability but windows 7 so far is really good but driver support is crucial
hope this helps
Here is the requirements for Windows 7
Windows 7 minimum specs
  • 1GHz CPU
  • 1GB of RAM
  • 16GB of drive space
  • DirectX 9-capable graphics card or integrated chip (true of most releases 2002 and after)
  • BELOW YOUR MACHINE SPEC
  • MPN nx05tp8e0a/suk
    Key Features
    Laptop Type Thin and Light Laptop
    Use Corporate Business • Small Business • Business
    Processor Pentium M 1.5 GHz
    Installed Memory 256 MB (DDR SDRAM)
    Display 14.1 in. XGA TFT LCD
    Operating System Microsoft Windows XP Professional
    Mobile Technology Intel Centrino Mobile Technology
    Processor
    Processor Manufacturer Intel
    Processor Type Pentium M
    Processor Speed 1.5 GHz
    Motherboard
    Chipset Intel 855GM
    Bus Speed 400 MHz
    Memory
    Installed RAM 256 MB
    RAM Technology DDR SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 2048 KB
    Hard Drive
    Hard Drive Capacity 30 GB
    Storage Controller Type Ultra ATA 100
    CD / DVD
    CD / DVD Type CD-RW/DVD-ROM
    Optical Drive Read Speed 24x (CD) • 8x (DVD)
    Optical Drive Write Speed 8x (CD)
    Optical Drive ReWrite Speed 8x (CD-RW)
    Display
    Display Tech XGA TFT LCD
    Screen Size 14.1 in.
    Display Max. Resolution 1024 x 768
    Video
    Graphic Processor NVIDIA GeForce4 440 Go
    Graphic Bus Interface AGP x4
    External Video Resolution 1920 x 1200
    Audio
    Audio Output Type Headphones • Sound card • Speaker(s) • SPDIF out
    Audio Input Type Microphone
    Operating System
    Platform PC
    Technical Features
    Expandability 1 x Type I/II PC Card Slot, 1 x Memory Stick Card Slot
    Expansion Ports 2 x USB 2.0, 1 x IEEE 1394a (FireWire), VGA out, RJ-11 (modem), RJ-45 (NIC), S-Video out
    Input Method Keyboard • Scroll Button • Touchpad
    Networking
    Networking Type Integrated 10/100 Network Card • Integrated Wireless LAN
    Data Link Protocol Ethernet • Fast Ethernet • IEEE 802.11b • IEEE 802.11g
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.90
    Battery
    Battery Run Time 2.2 Hours
    Battery Technology Lithium ion
    Dimensions
    Width 31.5 cm
    Depth 25.9 cm
    Height 2.4 cm
    Weight 2 kg
Nov 05, 2009 | Samsung X05 Notebook
Capacity of the inbuild optiarc dvd
Here the recording spec for the drive
It quotes double layer so it should be able to do up to 8.8 GB which is way way way way bigger than 4.37 mb.
DVD+R (DVD+R Part 1 Single Layer, Basic Format Spec Ver 1.3) / DVD+RW (Single Layer, Volume1: 4X Basic Format Spec Ver 1.3 and Single Layer, Volume2: 8X Basic Format Spec Ver 1.0) / DVD+R DL (DVD+R Part 2, Double Layer: Basic Format Spec Ver 1.0) / DVD-R General (Ver 2.0 and 2.1) / DVD-RW (Ver 1.1 and 1.2) /DVD-R DL (Ver 3.0)/ DVD-RAM (Ver V2.0 and 2.1 and 2.2 Class 0 ; Single side :4.7 GB/1.4 GB ; Double side :9.4 GB/2.8 GB) and CD-R/CD-RW media
Oct 29, 2009 | Compaq Presario 700 Series DVD-Rom Drive...
Cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Sep 17, 2009 | Iomega (33090) 250 GB Hard Drive
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
External drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Iomega 33089 250 GB Hard Drive
Dvd writter is not working
hey john,
do you have a burning software installed? you can download nero express @ majorgeeks.com
you mention that your friend gave it to you? was it working fine before? its easy to set up your new dvd writer whenever you have already installed a burning software like nero. well, you can also try clone dvd. it works very well too.
and also check for firmware upgrades for your dvd writer...you can find it here...
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-DVD-JLMS-XJHD166S-firmware-101.shtml
hope this hepls
Jan 24, 2008 | Lite On LiteOn 16x Black internal oem DVD...
Iomega Super DVD (33110) DVD±RW Dual Layer Burner Logo
99 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
