Question about HP Compaq Presario SR1401NX (PS565AA) PC Desktop
High pitched sound with flashes from power button
I would describe the sound as the computer screaming. Its not emitting from monitor or speakers but the computer itself as soon as its turned on. This started seconds after putting in a second RAM card, but even after removing the card the computer is making the same sound.
  • 1 more comment
  • madarose May 17, 2009
    Added note: Fans are clean.
    Thank you so much. Your probably right that the motherboard is damaged. Guess its time for a new computer. Thanks again :) Guess that teaches us not to mess with working computers and RAM cards. Next time we'll leave it to the professionals :)
  • madarose May 18, 2009
    No I didn't remove any other screws and I don't think any of the wires are pinched. The only thing we did was put in a second RAM card, but when my roommate wakes up tomorrow I'll have him check the power supply. Thanks :)
  • 585 Answers
Did you remove/replace any screws other than what it takes to open the case? The sound you describe sounds to me like the power supply is in distress, and the noise emminates from it. Check to see that you have not somehow pinched a wire somewhere.
Posted on May 17, 2009
  • 27 Answers
Check you have seated the memory properly in the slot and that no other cards or components nearby have been dislodged in some way. The PC is beeping as its unable to get past its basic power on check due to something wrong with the motherboard. Did you change any other configuration at the same time?
There should be a way of resetting the BIOS which might solve this. If you have the motehrboard manual look up how to clear the BIOS by removing a jumper (little plastic switch thing) which clears the PCs basic configuration. It should be on the motherboard somewhere near the battery usually. This might clear the error but if not you'll just have to get it looked at by someone in person as the motherboard may have been damaged.
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a Dell Latitude D630. When the laptop is switched on it emits a high pitched scream and will not boot. I disabled microphone in BIOS and machine boots fine. Re-enabled microphone and same probl
It sounds like a driver problem, normally the microphone is off on-boot-up. It should only be opened by a program wanting to use it.
Have you tried turning it off in the operating system, rather than the BIOS?
Download the correct drive here.
Product Support Dell US
Feb 11, 2015 | Dell Latitude D630 Laptop Computer PC...
View sonic computer screen was dropped and now when you turn it on the picture comes on and then it emits a high pitched sound and turns off. any suggestions?
Sounds like you may have broke at least one of the lamps . The high pitch sound you are hearing is the high voltage that goes to it .
Feb 05, 2011 | ViewSonic OptiQuest Monitor
Screaming high-pitched tone emitted by speakers when you power them up. This system has a subwoofer that powers the left and right stereo speakers as well.
your getting feed back check what is around your pc and move things around while the speakers are on like i said just move some things around or wawy from you pc see what happens
Mar 30, 2010 | Harman Kardon HK595 Computer Speakers
What does a screaming sound from the freezer mean?
Without hearing it, it sounds like a motor bearing that has gone bad causing the high pitched screech. If you can locate the source of the noise you might be able to oil the bearing, if that is it, with some light machine oil like 3-in-1. Best of luck
Mar 20, 2010 | Whirlpool Refrigerators
High pitch scream after i260 scans a few pages. Scanning stops
the main board in that scanner is going bad which is why its making the high pitch sound. Time to get another scanner or call Kodak and get a replacement scanner or go back to the store where you got it from and get a new one.
Jan 23, 2010 | Kodak Office Equipment & Supplies
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Alesis M1-Active left speaker emitts a very high pitched wine that sounds like feedback
have your built-in amp checked for trouble. there should be trouble in the output stage feedback loop. this is something to be done by a repair technician
Apr 11, 2008 | Alesis M1-Active MkII Main / Stereo...
Sound from monitor speakers distorted and high-pitched
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Altec Lansing ATP3
there is a lose connection near the main speaker .When i move it sound stops
Dec 17, 2007 | Altec Lansing ATP 3W Computer Speakers
HP Compaq Presario SR1401NX (PS565AA) PC Desktop Logo
159 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
