Question about Electrolux Gas Hedge Trimmer
Diagram for hedge trimmer
Where can i get a diagram to show me where the pipes go to and in the engine?
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
trippssmengi
  • 76 Answers
SOURCE: Long reach hedge trimmer
Try loosening the bolts up on the blades just enough to allow the washers to move freely a little, spray the blades down (but don't soak them ) with WD40 to lubricate the blades, that should solve it. If that doesn't do it then you may need to pull the gear housing cover off to see if something is jammed.
Posted on Jan 14, 2009
SOURCE: 22" excalibur hedge trimmer has no spark and will not start
remove plug and ground and see if you have spark at electrode.
Sometimes will not fire under compression.
Check that kill switch is not shorted, just remove the wire going to ground and try again.
If not probably bad coil.
Joe
Posted on Jan 20, 2009
rogrrabbit
  • 986 Answers
SOURCE: Expand-It Hedge Trimmer Parts
Belive it or not there is a nice selection at Homedepot.com
Posted on Jun 17, 2009
How much engine oil goes into the honda HHH25 4stroke easy start petrol hedge trimmer ?
Sitting the trimmer on a level surface you add oil til it is level with the oil filler plug. Shows how in the maual.
Here's a PDF manual -
http://campaigns.hondampe.com.au/.../ownersmanuals/hedge-trimmer/hhhd25own01.pdf
Feb 14, 2018 | Honda Garden
How is the fuel line diagram for 446T poulan pro weedeater?
Go to the following link where they have almost all diagrams for Poulan
http://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/poulan/hedge-trimmers/pp2822-966513101-2011-03/engine
Jul 15, 2014 | Poulan Garden
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
How do you lubricate a black & decker 8124 type 7 16" hedge trimmer. It is probably 15 years old and very "squeeky".
Use a spray lubricant WD-40 is my preference.Spray it all along the blades.Make sure to get where the blades attach.There is a large gear just above the blades on the inside of the trimmer,make sure to get it too. the link below is a diagram showing all the parts.That should make finding what I am talking about easy.
http://www.toolpartsdirect.com/cgi-bin/bigimg.cgi/blackdecker/8124-04_type_7
May 17, 2011 | Black & Decker 16Inch Hedge Trimmer
How do I change the primer bulb on my hedge trimmer. A mouse has chewded through it
Follow the link below,type in your model number and use the picture diagram as a guide. Most of the time you just remove four small screws that are located next to the primer bulb, then pull the primer bulb out of the metal retainer and reinstall your new one in reverse order.
http://www.ereplacementparts.com/tanaka-hedge-trimmer-parts-c-34785_34879.html?osCsid=aa2bgq59q5o7m5hu648n9ii5d4
Feb 06, 2011 | Tanaka 30" Double Sided 24cc Hedge Trimmer
My hedger turns off when I turn it side-ways to
The problem with Ryobi trimmers is the siting of the fuel outlet pipe the trimmes has to be full of fuel at all times
Jul 11, 2010 | Ryobi 26CC, 22 In. Hedge Trimmer
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Joe
Dec 02, 2008 | Electrolux Gas Hedge Trimmer
Electrolux Gas Hedge Trimmer Logo
118 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
