Question about Garmin StreetPilot 2720 GPS Receiver
Restarting while in use
I have a 2 year old 2720 that for no reason, keeps restarting while in use.When the unit restarts, it will continue with the trip. It will restart if you are in a trip mode or just have it on. I have tried another power cord. it does this whenever it wants to
  • 2 more comments
  • Anonymous Nov 15, 2007
    I am experiencing the exact same problem. The unit restarts for no reason - but continues with the programmed route. Unfortunately, you barely even have time to read the text route before it restarts. Not sure if it is the power connection of the dc cord. Tried using the ac power cord "indoors" and couldn't duplicate the restart problem. However, the indoor mode does not simulate realtime operation, so I still wouldn't rule out a software/hardware glitch.
  • dcbell560 Nov 19, 2007
    I tried another power cord and that was not the problem. I did do a firmwre update and that corrected the unit. It has been working well for the past 3 weeks. You should go to the Garmin website and download the latest FIRMWARE update.
  • troymotates Dec 18, 2007
    I have the same problem the unit keeps restarting every couple of minutes or so. I have tried fixing cord did not help matter.
  • 440rt Apr 13, 2008
    Mine does the same thing. It seems to be programmed into 25% garmin units to get people to purchase new units or have $225.00 bill to pay to fix it.
The 4-prong negative contacts on my speaker/power plug were losing contact. When speaker was bumped or moved the unit would go off and sometimes restart itself, other times a movement of the plug was needed.   Remove the fuse and carefully slide the contacts off, clean, adjust then reinstall.   No more power failures!!
Posted on Mar 29, 2008
I went on the Garmin website and downloaded the latest firmware and haven't had the problem since. Good luck.
troymotates
Posted on Jan 14, 2008
The problem is in the power cord connector at the unit. After a while the terminals in the cord loose tension and do not make good contact with the conductors on the back of the unit. Try cleaning the exposed condutors. If that does not help, a new cord will. YMMV
Good luck
Posted on Jan 13, 2008
The thread here at http://www.gpsreview.net/garmin-streetpilot-2720/ also suggested updating the StreetPilot's software/firmware and that seemed to solve things for me. One of the people at that thread mentioned that they needed to do a complete reset after the update (which can cause you to lose your customizations) but I didn't need to do that. I did the update about 2 weeks ago and it has been working fine since even on bumpy roads.
BTW, I had previously pulled apart my cord, too, and re-glued the connector pieces because I thought the connection was loose, but that did NOT help anything. The software update did the trick. I suspect that maybe some internal counter was overflowing and the update reset it or doesn't allow it to overflow anymore (just a theory, I'm a software developer :).
Posted on Nov 22, 2007
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Posted on Nov 19, 2007
Spin cycle keeps restarting
Likely to be motor, specifically the brushes. depends on how old the machine is. brushes are replaceable and tend to need replacing from4-5 years with some makes
Dec 08, 2013 | General Electric WCVH6800J Front Load...
I have Garmin nuvi 1300 GPS it keeps restarting. I've read that master reset can fix this problem. but how can I save all folders before restarting ?
a rebooting unit will most likely not be resolved by a reset. The problem is usually caused by a failed firmware or map upgrade. When the unit boots and can not find certain files or they are corrupted, the unit crashes. The unit must be flashed with a service firmware to gain access to the units flash drive so that the corrupted files can be replaced. Once access to the flash drive is obtained, the favorites can be backed up as well. Once the files are restored, then the unit can be flashed again with the factory standard firmware. More info can be found here:
http://www.sharc.net/gps_bootup_repair.htm
Mar 29, 2013 | Garmin nuvi 350 GPS Receiver
My pantech impact keeps on restarting for no reason at all. as soon as the backlight dims out, a green bar appears and restarts the phone each time. i have tried restarting it, a new battery, master...
There are widespread complaints regarding this phone's random restarts. The possibility is that you acquired a refurbished phone. You have two options in order to get rid of the random restarts at this point: 1. To trade in your phone. It would be helpful if it is on warranty 2. Obtain a new phone
May 01, 2011 | Cell Phones
Keep restarting every 5-10mins. was inf motherboard bad
Restarting loop in your computer can be caused various reasons.
1. Overheating of the processor.
2. Problem with your operating system
3. Motherboard failures
While restarting your computer you should be seeing the Sony logo and then the windows logo, post which you will go to your desktop background. If your computer is restarting immediately after the windows logo before loading windows desktop, then the problem can also be with the windows operating system. For this situation while your computer is restarting keep tapping the F8 key as soon as you see the sony logo, then choose safe mode and hit enter, This should load safe mode, in safe mode wait for some time and see if your computer is restarting. if not then the issue is with some recently made change or recently installed software or hardware. If it restarts even from safe then the issue is with the hardware of your computer
Mar 05, 2011 | Sony VAIO VGN-CS110E/Q Widescreen Notebook...
Computer restarting again and again
Ok, the first thing you need to do is when the computer is restarting and before you see the Windows logo screen press F8 on your keyboard. That will bring up the Windows boot menu. Arrow down with the arrow keys on your keyboard and choose to start the computer in Safe Mode with Networking. This way you can download the Sasser removal tool from the internet even though you are in Safe Mode. What this option means is that you are booting the computer with only the necessary drivers that are needed for the computer and any networking that you may need.
I hope this solves the problem. If not, please let me know.
Aug 17, 2009 | Symantec Norton AntiVirus 2008: Windows
D-Link dwl2700ap always restarting..need help
Check Firmware version here
Check if any source of interferences came around AP
Check if environment changed (water in, broken shell, connectors integrity.....)
Use AP manager software to check logs file and find possible reasons for restarting.
Jan 05, 2009 | Computers & Internet
Dfl-1600 sytem restart
Sounds like the firmware is looping for some reason. Try this to reset defaults:
Step 1: Make sure the unit is powered off.
Step 2: Press and hold the reset button located on the back of the firewall. While continuing to hold the reset button, power on the firewall.
Step 3: Continue to hold the reset button for 30 seconds after the unit is powered on.
Step 4: Release the reset button and the firewall will be at factory default settings.
Oct 09, 2007 | D-Link DFL-1600 Firewall
Shuts off itself
My 2720 just starting doing that today. used it fine for past 4 days on a trip, now it is acting up. Less than 1 year old
Sep 03, 2007 | GPS
Garmin StreetPilot 2720 GPS Receiver Logo
367 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
