Question about Whirlpool Dishwashers
Dish washer draining water from the top of sink.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
I had the same problem. took apart the inside pipes but did not work . outside my kitchen sink there is a clean out . got a big wrench and opened it up , took the water hose and put it inside the cleanout. Oh my gosh ! it was so yucky.. but it worked. hope this helps.
Posted on May 17, 2009
Water backs up from the drain in my dishwasher and smells. what is the problem?
Two things can cause this problem:
1. The check valve in your dishwasher may be defective, allowing water and food debris to seep (or run) back into your dishwasher.
2. Your drain hose may not be "mounted up" the way it should be. Look under your sink. Look at how your drain hose is connected to your garbage disposal. If the hose runs down to the floor of your cabinet and into your dishwasher, that is wrong. Instead, it should be mounted up so that water from the sink and garbage disposal would have to flow up first to get into the dishwasher. If you do this, then even if you have a bad check-valve in the dishwasher, it will prevent the problem (or greatly reduce the problem) of dirty water flowing back into your dishwasher.
May 17, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dish washer wont empty out leaves about 2 or 3 in in it
Drain hose clogged or Not ran in the proper draining position, under the sink where the hose ties into the drain system or garbage disposal, the hose should be higher than the connection point, I have fixed this by tie strapping hose to the bottom of the counter or sink, hope that helps ?
Feb 27, 2015 | Kenmore Dishwashers
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Water keeps backing up on to my counter top from a drain on the sink. WHY?
If you have a built in disposal in your sink, the perforations in the disposal screen are too small to let the water exiting from the dish washer's pump to go down the drain fast enough, or the perforations are clogged sometimes. The answer is to put a sink stopper in the drain of the sink, which will block the back flow.
Jan 01, 2011 | GE Nautilus 24" Built-in Dishwasher
My dish washer leaks water
The hose from the air gap on top of your sink to the garbage disposer is plugged.or kinked probably.Unless you have a new garbage disposer and the plug wasn't knocked out at the dishwasher drain connection
Jun 23, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dish washer has a sulper smell when turned on.
Without seeing it and assuming the dishwasher is functioning properly, the drain hose from the dishwasher to the sink drain might have a kink in it from when the put in the new sink.
You should be able to visually look at this under your sink.
Good luck
Get back to me if you need more assistance
Kurt
Mar 19, 2009 | Plumb Pak Continuous Waste Center Outlet,...
Frigidaire Dish washer MODEL
hi there aaliyazaidi2.is the water clear or dirty that you find in the dishwasher?there are two ways this could be happening.1,if the water is dirty[although it dose not have to be ,but its a sure clue]its you drain line of your dishwasher.what happens is because the drain line is lower than the sink drain, when you use your sink water runs by way of gravity in to the drain hose and then fills up your dishwasher,till you drain it or wash a load...to solve this problem you need too make a loop as we repairman call it.get some zip ties ,or what ever[string] and tie your drain hose off at the top off the sink under the sink cabinet[imagin your drain hose as a roller coaster, the hose coming from the dishwasher is the start of the coaster before it goes to the top of the big hill.what you want to do is ,at the top of the roller coaster hill,tie your drain hose to what ever you can under you sink causing a hill so when your hose goes back down ,it ends up into your disposer or what ever plumbing it ends up into.[hay i hope i helped you understand what i mean their];#2,the other way is your dishwasher water valve may not be sealing well. the water would only be clear if this was the issue and could be warm water because its only hot water to the dishwasher.what happens here is because the water valve is not sealing water slowly adds to your dishwasher may be drops at a time,and over the hours gone by it accumulates and the you notice water in the tub.to solve this you replace the water valve.its[most of the time blue,but could be tan or white]under the dishwasher.the water line from your house goes to it.i hope this helps you you can email if you need more help. God bless ,tom
Feb 25, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Water backs up to the dish washer from the sink .
Check the drain hose under the sink. It should have a high loop an upside down "u" like a hill the water can't climb to get from the sink to the dishwasher. That is where I'd start. Good luck.
Jan 07, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Our dishwasher was gushing water after a cycle
If you dish washer pumped or drained water up into you sink then you drain line from the sink or even further down is clugged up, Machine out drain line. A drip sized cable machine can be rented. I recomend a 1/4 inch line. You will only have to go frim the sink to the main line.
Dec 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Dishwashers Logo
44 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
