Question about Panasonic AG-DVX100A Mini DV Digital Camcorder
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
Is there a battery tin your external mic?
Posted on Sep 12, 2010
  • 22 Answers
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
Posted on Aug 10, 2009
Recording Audio via the Audio In/Out
If this camera come with a Mic input or audio in put you will need to use a seperate amp. or use internal.
Dec 06, 2007 | Panasonic AG-DVC30 Mini DV Digital...
My external mic wont work! Please help.
If the mic is working on other camera's, what about the adaptor ? If there is a possiblity of checking the mic and the adaptor together on other equipment ? Use another mic with the same plug as the camera, ie. PC microphone (you can even test by using an earphone, the earphone can be used as mic) If it works then the XLR mic with adaptor is the problem. If ther other mic (used for testing) also did not work then the microphone jack (socket) in the camera is defective or the gain setting of the camera is set to minimum.
Jun 05, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
How to connect lavalier mic to panasonic dvx100b
Pretty easy, connect it to the xlr connector (hope your lav do have xlr connector) then swith the external mic switch on, phantom power switch to on, and front switch to mic (not line) and ajust the level.
Sep 14, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
Mics plugged into the xlr module don't seem to
mics have any on off switches? look for a switch labeled internal external mic. Could be in the menu.
Larry
Jul 27, 2009 | Sony HVR-A1U Camcorder
Audio level Issues with Sennheiser Wireless MIcs
Could be your capture device.  Isolate this problem by monitoring the quality of the audio at the RF reciever, then monitor it at the camera.  I'm assuming you do not have a EFP mixer or other device that will actually measure your Dbm or Vu levels - what happens if you play the tape in the camera and monitor the output of the camera with an external device - even a TV or stereo? If it sounds good on your TV turn your attention to the capture card.
Jul 05, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
Mic level problems
There is a small switch on the front side of the camera ( the lens side) make sure that it is set to mic (Input 1)
Hope this helps.
santhoshcj@gmail.com
Jan 31, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-DVX100A Mini DV Digital Camcorder Logo
343 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
