How to Install WM610 Modem in Ubuntu?
Can anyone please be kind enough to tell me how to install WM610 modem in Ubuntu 9.04n Because the OS did not auto detect this modem
  • 433 Answers
Check to see if WM610 is compatible with LINUX:
the easiest way to unlock modem is using DC UNLOCKER is easy as 1,2,3 (with in few seconds )
to download :- http://www.sendspace.com/file/v4jd4wHow to Install WM610 Modem in Ubuntu? - t.gif
for modem types look my DOC file. 1. connect modem to computer
2. don't click connect button on mobile partner window
3. change sim card you wish to use (after unlocking)
4. install DC unlocker
5. run DC unlocker
select manufacture and select modem as "_Auto detect (recommended)_"
6. click on search icon("detect card")
good luck!!!!!!!!!!!!!
Posted on May 17, 2009
  • 585 Answers
There's a recent thread regarding this issue in the DC Unlocker forum. It seems it's not currently supported. http://www.dc-unlocker.com/forum/showthread.php?t=446 That may be subject to change however.
Posted on May 23, 2009
The setup file is an .exe file which doesnot run in ubuntu 10.04 lts edition. So would u help me to install the modem in ubuntu.
Assuming the modem is connected, click on System - Administration - Additional Drivers
Wait while ubuntu searches, then click on and activate any drivers listed.
If that doesn't resolve, try connecting to a router/modem - Enable networking (top left hand corner of screen) then click on System - Admin - Update manager. See if an update can resolve the issue.
Nov 23, 2010 | Computers & Internet
Am using ubuntu lts10.04...i want 2 use huawei ets 2288 modem
from the "UBUNTU SOFTWARE CENTER" in your applications menu, type in the search box "MODE SWITCHING DATA FOR USB". Then install it, after completing the installation insert your huawei ets 2288 modem and it will be recognized by your system. Then configure the connection with your internet provider.
Aug 27, 2010 | Canonical Ltd. Ubuntu
CANNOT INSTALL MICROMAX MMX 310G USB MODEM WITH BSNL SIM IN UBUNTU
Give me your modem IMEI number and I will unlock it.
Jun 15, 2010 | Computers & Internet
AT&T 2Wire 1800HG set up on Ubuntu
https://help.ubuntu.com/7.04/internet/C/connect-to-internet.html
Jan 03, 2010 | 2wire 1800HG Router (RG1800HG00)
Has anybody configured Reliance Datacard - USB on ubuntu 9.04? Kindly give me step by step procedure for configuration? Regards, Moiz
First use the following command to see if your card is being detected by kernel.
cat /proc/bus/usb/devices
Then you can use the following script for the installation, you can check if this is for your version of Ubuntu.
#!/bin/bash
#This program automates task of setting up connection for Reliance USB Card on Ubuntu Hardy Heron. This program does not come with any warranty whatsoever. Please use it at your own risk.
# Detect Modem
echo "Modem Detected: $(lsusb | grep -i huawei | cut -d" " -f7-)"
# Get Connection Number from User
echo "Enter Your Reliance Data Card Connection Number : "
read connection
echo "Setting up connection with $connection"
#Install Gnome PPP Package
echo "Installing Required Packages.."
sudo apt-get install -y -q gnome-ppp wvdial
#Add entries to /etc/ppp/ppp-secrets and /etc/ppp/chap-secrets
echo "I:Modifying necessary system files to allow dialing with Gnome PPP..."
sudo chmod 666 /etc/ppp/pap-secrets /etc/ppp/chap-secrets
echo "$connection * $connection" >> /etc/ppp/pap-secrets
echo "$connection * $connection" >> /etc/ppp/chap-secrets
sudo chmod 600 /etc/ppp/pap-secrets/etc/ppp/chap-secrets
#Start Gnome PPP
echo "We are all set.... "
echo "Starting Dialer..."
gnome-ppp &
exit 0
Dec 10, 2009 | Computers & Internet
H9601C prolink modem driver
i cannot install prolink h9601 adsl modem on windows xp home edition,, any luck??????
Sep 02, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
I decided to switch to ubuntu 9.04 os but i have problem with dial-up connection using Dlink 562is modem.
1. Install hsfmodem_7.60.00.09full_i386.deb from terminal
* type sudo dpkg -i *.deb
* Where is the linux source build directory that matches your running kernel?
* [/lib/modules/2.6.20-15-generic/build] press Enter
* Please enter region name for modem unit 0 [XXX] : type country name then press enter
* Please enter your email address [unknown] : type your email address then press enter
* Recorded The registration ID for modem unit 0 is: XXXX-XXXX-XXXX
* Please enter license key [FREE] :
2. Open new terminal, type ./genertor.pl [email address] [Registration ID]
3. get key: XX-XX-XX-XX-XX-XX
4. enter the key on Please enter license key [FREE] :
5. Copy hsfpatch to /usr/lib/hsfmodem :
* $ sudo cp hsfpatch /usr/lib/hsfmodem/
6. Execute patch file : $ sudo ./hsfpatch
* file 'modules/imported/hsfengine-i386.O' openend
* patching... done
7. Reconfigere hsfmodem : type sudo hsfconfig
* Press ENTER for all the questions
* Would you like to keep using them? [no]
* Please enter region name for modem unit 0 [XXX]:
* Please enter your email address [XXX@XXX.com]:Please enter
* license key [XX-XX-XX-XX-XX-XX]:
8. Reconfigure hsfmodem complete :
* Config for modem unit 0: /dev/ttySHSF0
* Device instance: 0-PCI-14f1:2f30-14f1:20d5
* HW revision : Basic2 2.18 Standard DAA 3VoltsIA
* HW profile name: hsfpcibasic2hsfi
* Registration ID: XXXX-XXXX-XXXX
* License owner : XXX@XXX.com
* License key : XX-XX-XX-XX-XX-XX
* License status : OK
* Current region : XXX (T.35 code: 0054)
* The /dev/modem alias (symlink) points to ttySHSF0
9. Install KPPP
10. Browse The World
Jun 17, 2009 | D-Link DFM 562IS (DFM-562IS) Modem
Tusb3410 vista
Sir , I am having Huawei Wireless Modem.(TUSB3410).For Internet connection(dail up). I am having windows xp I cant install the modem with this vista. .Please solve my problem...
Aug 21, 2008 | Computers & Internet
Install modem in ubuntu desktop
downlod driver for linux it is also avilable dlink website
thanks
Nov 19, 2007 | D-Link DFM 562IS (DFM-562IS) Modem
Computers & Internet Logo
677 people viewed this question
David Payne
David Payne
