Question about Furman PL-PLUS SERIES II (PLPLUSII) Power Supply
Furman pq4 (NEED A manual) Black face
Furman pq4 (need a manual) original Black face
Not sure which inputs & outputs to use ie: high or low,
And should front little buttons be in or out!!!!!!
I have the exact same two questions. Did you ever figure it out?
Posted on Nov 19, 2012
How do I eliminate buzz?
Things to check:
1. With your multi meter, measure from left ground to right ground. What do you get? Measure from each input ground to chassis. What do you get there.
2. Get or make a pair of shorting plugs. Plug those into the inputs. Power on. Hum there or gone?
3. Turn the pre-amp on. Connect. Level of hum change with preamp on?
4 additional information. How efficient are your speakers? This is a big amp, high-efficiency speakers may show some noise, while low-efficiency speakers won't.
A trip back to the shop may be indicated, too.
Nov 23, 2015 | Adcom GFA-5500 2-Channel Amplifier
Probable cause for engine check light to stay on longer but goes out when rev engine on a 2004 fatboy
Check fault codes...although light does stay on longer to show historic codes that need clearing. To clear...access codes then hold the button in until clear message appears.
To access codes...
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engineicon1.png and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignitionicon1.png Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 3 If the code is current it will reappear.
4 - Press and release the odometer reset button to continue to the next module.
5 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motoricon1.png Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performanceicon1.png (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylinder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Controlicon1.png Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutchicon1.png Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
May 07, 2014 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
How to retrieve engine code diagnostics 2005 flstni
To access codes
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
SP = speedometer
T = tachometer
23. P2123 TGS1 High
25. P2128 TGS2 High
29. P0122 TPS1 Low
31. P0222 TPS2 Low
34. P2119 EFI Motor Throttle Body Range Performance
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
79. P0577 Cruise Control Input High
11. B1154 Clutch Switch Input Short to Ground
Dec 11, 2013 | Harley Davidson Motorcycles
Fault codes
To access codes
1- Turn Ignition Switch to OFF & Run/Stop switch is to Run.
SP = speedometer
T = tachometer
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the . Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 3 If the code is current it will reappear.
23. P2123 TGS1 High
25. P2128 TGS2 High
29. P0122 TPS1 Low
31. P0222 TPS2 Low
Dec 11, 2013 | 2005 Harley Davidson FLSTN- FLSTNI Softail...
Behringer cx2300
follow this instructions and fix it. God bless you
Instructions
    • 1
      Plug one end of a shielded input cable into the mixer's main output, and the other end into the crossover's input. The cable connectors will be dictated by your particular mixer and crossover, and will be either standard 1/4" or 3-pin XLR connectors. Consult the owner's manual of all components for specific details and recommendations.
    • 2
      Plug another shielded input cable into the crossover "high" frequency output, and the other into the crossover's "low" frequency output.
    • 3
      Plug the cable coming from the crossover "high" output into the channel one input on the stereo power amp, and the cable from the crossover "low" output into the channel two input of the power amplifier.
    • 4
      Plug one end of the unshielded speaker cable into the power amp channel one speaker output, and the other end into the horn tweeter.
    • 5
      Plug one end of the second unshielded speaker cable into the power amp channel two speaker output, and the other end into the woofer. The connections are now complete.
Jul 13, 2013 | Behringer cx2310 super-x pro crossover...
What wires do I hook up to the high level in plug that came with my dual xp2100 2 channel amp
First, know that you need either high level input or low level input, but not both. Low level input is preferred (RCA cables). If you must use high level input because your head unit doesn't have RCA jacks, you connect the speaker outputs from the head unit to the high level input of your amp. The high level input plug probably has a black wire, this is "signal reference ground". A pair of grey wires which are right positive (grey) and right negative (grey with black stripe). And a pair of white wires, left positive (white) and left negative (white with black stripe).
Feb 26, 2011 | Dual Car Audio & Video
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
5=empty
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
11=empty
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
17=empty
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
Does anyone know where I can get the error codes for 2000 Harley Deuce and what do they mean?
I am not sure but these codes may be of great assistance to you/
Harley Trouble codes
The following procedure will instruct in retrieving and clearing ECM Diagnostic Trouble Codes and TSM/TSSM codes thru the Harley guage cluster as well as a list of codes.
3- Turn ignition switch to Ignition and release the odometer reset button. Background lighting sould illuminate, sppedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
P = ECM/ICM (Electronic Control Module) [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
"No Rsp" (no response) will also appear if the run/off switch is in the off position when doing this procedure.
19. P1511 Throttle actuator control power management failure of throttle control actuator
20. P1600 EFI Module Processor Internal Error
21. P1270 TGS Validation Error
22. P2107 EFI Module Processor Internal Fault
23. P2101 throttle actuator control motor circuit range/performace error
24. P2122 TGS1 Low/Open
25. P2123 TGS1 High
26. P2127 TGS2 Low/Open
27. P2128 TGS2 High
28. P2138 TGS Correlation Error (Twist grip sensor)
29. P0120 TPS1 Range Error
30. P0220 TPS2 Range Error
31. P0122 TPS1 Low
32. P0123 TPS2 High/Open
33. P0222 TPS2 Low
34. P0223 TPS2 High/Open
35. P2135 TPS Correlation Error
36. P2119 EFI Motor Throttle Body Range Performance
37. P2100 EFI Motor Circuit Open
38. P2101 EFI Motor Circuit Range Performance (Actuation Error)
39. P2102 EFI Motor Circuit Low
40. P2103 EFI Motor Circuit High
41. P2176 EFI Closed Position Not Learned
42. P1514 Air Flow Fault
43. P2105 EFI Forced engine shutdown
44. P1501 Jiffy Stand Sensor Low
45. P1502 Jiffy Stand Sensor High
46. P0572 Brake Switch Low
47. P0117 ET Sensor Low
48. P0118 ET Sensor High
49. P0112I AT Voltage Low
50. P0113I AT Voltage Open/High
51. P1351 Front Ignition Coil Driver Open/Low
52. P1354 Rear Ignition Coil Driver Open/Low
53. P1352 Front Ignition Coil Driver High/Shorted
54. P1355 Rear Ignition Coil Driver High/Shorted
55. P1357 Front Cylinder Combustion Intermittent
56. P1358 Rear Cylinder Combustion Intermittent
57. P0261 Front Injector Open/Low
58. P0263 Rear Injector Open/Low
59. P0262 Front Injector High
60. P0264 Rear Injector High
61. P0562 Battery Voltage Low
62. P0563 Battery Voltage High
63. P0501 VSS Sensor Low
64. P0502 VSS Sensor High/Open..
65. P1356 Rear Cylinder No Combustion
66. P1353 Front Cylnder No Combustion
67. P0444 Purge Solenoid Open/Low
68. P0445 Purge Solenoid High
69. P1475 Exhaust Actuation Position Error
70. P1477 Exhaust Actuator Open/Low
71. P1478 Exhaust Actuator Shorted/High
72. P0131 Front Oxygen Sensor Low
73. P0151 Rear Oxygen Sensor Low
74. P0132 Front Oxygen Sensor High
75. P0152 Rear Oxygen Sensor High
76. P0134 Front Oxygen Sensor Inactive
77. P0154 Rear Oxygen Sensor Inactive.
78. P1510 EFI Limited Performance Mode
79. P1511 EFI Power Management Mode
80. P1512 EFI Forced Idle Mode
81. P0577 Cruise Control Input High
23. B0563 Battery Voltage High.
Copyright 2008 © Fuel Moto - Fuelmotousa.com
Nov 10, 2010 | 2000 Harley Davidson FXSTD Softail Duece
I have a KLH SW-90 amp. When I plug in the RCA plugs I don't get any sound to the Satelight speakers. Is this a sub amp? Do I need to hook up the high input wires to make the satelight speakers work?
I have the same amp. there a two ways to use it: The phono plug inputs are low level, are for use as an amplifier only, and their only output is the subwoofer output. In this case, any stereo satellite speakers would be driven directly from your stereo amp.
The high level inputs are meant to be driven as the same as speakers from your stereo amp. A circuit inside samples the bass and directs it to the sub amp and output. this same circut passes unamplified outputs to the satellite outputs. PM me at moestevens@cox.net if you need further info.
Oct 24, 2010 | KLH Audio Players & Recorders
Furman PL-PLUS SERIES II (PLPLUSII) Power Supply Logo
683 people viewed this question
Top Furman Computers & Internet Experts
David Payne
David Payne
Are you a Furman Computer and Internet Expert? Answer questions, earn points and help others
