Question about Dishwashers
Dishwasher Hi I have a Asko bench top dish washer and it is leaking from the bottom underneath other wise it works perfectly and I love it Please help me fix it wendy fitzgerald & Allen Street Methven New Zealand
  • 878 Answers
SOURCE: Dishwasher does not dry the dishes thoroughly
Kayzy, The dry cycle for this model, starting with 587.14432 is approx. 37 minutes. Remove the lower toe panel and have someone verify that you are getting power to the element (120V) during the dry cycle, using heated dry. If this checks ok, remove the leads from the element and ohm it out. It should read between 23 and 25 ohms. The element will be on the left side, should be easy to get at. On the inner door, remove the vent cover by popping it out and see if there is a bunch of built up gunk in there preventing a good vent. Of course make sure you are using a rinse aid and have hot water (min 120 degrees) entering the dishwasher. Check these things out back. Kay, there wasn't a complete model posted. The only model I could come up with starts with 587.
Posted on Feb 06, 2007
  • 90 Answers
SOURCE: dishwasher leaking
need to know the brand and where the leaking is. (exactly)
Posted on Jan 05, 2008
  • 3 Answers
SOURCE: Water in bottom of dish washer
you probably have something stopping the drain pump operating (like a tooth-pick or piece of plastic that won't break down in water) its a take it to pieces job i'm afraid but if you are fairly mechanically adept you can do it yourself. the drain pump is quite small and nearby to the drain outlet- you need to remove the case and release the drain from inside the unit- remove the pump itself and you'll prbably find somthing stuck in it- remove and re-assemble. In the meantime DO NOT use the dishwasher as you will 'burn out' the motor as the pump rotors are jammed.
Hope this helps
Posted on Feb 19, 2008
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 291 Answers
replace the top spray arm and it should work ok again
Posted on Nov 27, 2008
  • 72 Answers
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food or residue from the detergent. A water pressure problem may be the culprit. You may need to replace the water intake valve. Another common problem is mineral build-up. If your house has hard water, the mineral build-up can clog the water jets. Clear each jet with a wire or pin, and run an empty load with some vinegar in the detergent dispenser about once a month.
Sometimes, the dishwasher has problems draining properly. There could be a clog in the drain hose, or a problem with the pump. It's also possible that the dishwater is getting too sudsy, and sensors in the washer aren't detecting the soap foam as water. This causes it to shut down the drain cycle too early. Just use less detergent.
Posted on Feb 02, 2009
0 characters
1 Points
My asko dishwasher D 1716 is leaving a white film on my glasses and other dishes. I have added Jet Dry but it has not helped. Also sometimes water leaks under the handle and runs down the front of the...
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Aug 27, 2011 | Asko D1716 Built-in Dishwasher
We have an Asko D3350 Dishwasher and the upper blade does not appear to be spinning and the dishes are not coming clean. Bottom appears to be working fine and dishes on bottom are clean. What could be the...
On my d3350 it is possible to choose which tray (bottom, top or both) is cleaning.
The button is the bottom left, and above it there are two lights. As you push this button, the lghts cycle through lower tray, upper tray and the both trays. You want both lights on.
Also try this - take the spray arm out (it just snaps free) and rinse it out in case there are some blocking materials in the arm which are stopping it from spraying
Dec 30, 2010 | Asko 24 in. D3350 Dishwasher
My Asko D1976 dishwasher is not cleaning dishes properly. There is a lot of clumped detergent left in the dispenser after wash cycles are complete, and many of the dishes have dried-on food left on them. ...
First of all, don't pre-rinse the dishes. Check the water temperature, it should be between 120 and 140 degrees. Be sure you are not partially blocking the dispenser door so that it isn't opening.
Sep 18, 2010 | Asko D1976 Built-in Dishwasher
Upper tray dishes are not cleaned(washed) the bottom are OK, why?
replace the washer water from bottom of the unit up to the top arm water feed assy,they get worn and water leaks by the hub arm that pressurizes the upper wash arm,this is also true on the center arm if the washer has one
Mar 09, 2010 | Asko 24 in. D3250 Built-in Dishwasher
After running a full cycle dishes are covered in detergent residu has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
Apr 01, 2009 | Asko D3251HDSS Stainless Steel Built-in...
I would suggest you buy some CLR and run it through a full heavy cycle with the washer empty. Be sure to put it in all dispenser areas and sprinkle about 1/4 cup into the washer before starting.
Feb 16, 2009 | GE 24 in. Profile PDW7800 Built-in...
Asko dw95.4 dishwasher flashing f2 when switched on
remove the dishwasher from under the bench and tip it back to let the water run out from underneath,remove the rear panel at the bottom and run test for leaks or blockages.
Oct 09, 2008 | Asko Dishwashers
Model d3121 does not "heat"... when I use it the water don't be hot and the dishes doesn't dry. you can answer in french i'll try to understand ... as you can see i'm not bilingual but...
In my case, the problem was with the control card, located behind the control buttons on the front. The relay driving 120V, 10A to the heaters had one pin dissoldered, probably because of heating. It was dark around the pin. See the picture attached. The top part showd the PCB with the faulty pin marked by a red arrow; the bottom part shows the other side of the PCB with the relay itself.
Remember that this relay/pin drived 1400 W.
I found the electrical drawings here:
Oct 01, 2008 | Asko Dishwashers
Asko dishwasher d3120
Hi this is known as an L1 fault (Not heating) you need to check the element,thermistor,wash motor,wiring or the pcb.Failing this you need to ring asko
Mar 02, 2008 | Asko D1776 Stainless Steel Built-in...
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
