Question about Bosch & Power Vent Water Heater
Just fitted solid fuel stove with back boiler, water in system but not circulating through hot wwater cylinder.
  • Ned C Cook
    Ned C Cook May 11, 2010
    Possibility of water having been turn off on install? This has radiators?
  • 332 Answers
Is the circulating pump going in the right direction? if not reverse the pump if it is make sure your valve is not clogged going thru the pump, if it isn't a ball valve put one in, a gate valve could break off inside and it will still feel like it is working but it wouldn't be,
Posted on Jun 06, 2009
Taco 007 circulating pump stays on even though boiler shuts down
Don't know your specific unit, but in general, heating systems are two-stage devices:
1: Its too cold: the motorised HW/CH valve moved to the required position, and on achieving it, the circulaion pump starts and the boiler is enabled. (The circ pump may start immediately - its not usually important.) The hot water from the boiler circulates through the heat exchanger and/or radiators until the thermostat thinks its target is warm enough, whereupon it disables the boiler, stops the pump and closes/relaxes the valve(s).
2: The boiler is off while disabled. When enabled, it heats the circulating water to a 'high' temperature and seeks to keep it there. If it reaches that temperature, the boiler will cycle on and off as necessary to maintain the set 'high' temperature. (The circulation pump must run all the time the boiler is enabled.) This may be what you're noticing. Additionally, some boilers will run the circulation pump for a little while after being disabled to reduce the temperature if the water in the pipes and boiler.
Your question doesn't say how the pump running corresponds to thee thermostat settings, but if it were stuck on, I think you'd know!
Dec 31, 2016 | Water Heaters
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
I have an old solid fuel fire with a back boiler behind it...the pump is making a buzzing noise....some radiators hot some not...please help
Tell us more: What is the Solid Fuel?-- Coal?-- Wood? Is this a Steam boiler?- or a Hot water boiler?-- It sounds like Hot water, for you mention a pump-- Perhaps it is a Hot Water Circulation pump?
Does the Boiler have a sight glass?-- What is the water level?
Tell us more, so we can help you figure things out.
Mack B.
Oct 13, 2013 | Bosch & Power Vent Water Heater
Boiler working but radiators cold
Seems that you may have bad circulation pump.
Feb 24, 2013 | Water Heaters
I need a diagram for an indirect hot water system heated by a solid fuel boiler and an oil boiler
If you are using more than one heat source you will have 1 more pump than the heat source pumps Main pump = SYSTEM pump pumps through the indirect hot water system and back into itself. This is the system loop. The other two boilers tee into this loop upstream of the indirect tank, downstream of the SYSTEM pump. The cold water return to each boiler tees into the system loop next to and upstream of where the hot water for that boiler tees into the system the loop. The oil boiler will have its own pump on its return line from the sytem loop and the solid fuel boiler will have its own pump. When any boiler fires, it turns on its own pump AND the system pump. If you want a drawing email me -pipesster@gmail.com send a fax number and I'll fax you a drawing.
Jan 15, 2010 | Aquapure AP431 Hot Water System Cartridge
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
I am istalling a parkray cumbria 111 inset multi fuel boiler stove which has 4 atacmens (2at each side) and im unsure of whic pipes connect 2 which. i orginally had a gas fre in and have removed that and...
the two largest conn go too cylinder hot wate and the other two too heating if wet system via a pump on the return (bottom conn top is the flow) if all the conn are same size two from one too water other two for heating
Oct 08, 2009 | Water Heaters
Radiator heats up when running a shower.
Your boiler is overdue for a service.
Combi boilers are unlike regular boilers in that they have quite a few moving parts, it's vital that these are serviced annually if you want the boiler to remain reliable and to avoid expensive failures.
In your case, the diverter valve has most likely failed. Normally, when the heating is on this senses when there's a demand for hot water and temporarily diverts the primary hot water circuit to feed the domestic hot water heat exchanger. When the demand for hot water ceases the primary hot water circuit is diverted back to the central heating heat exchanger. The valve has a number of moving parts including a rubber diaphragm which can wear out and split and moving shafts which can seize.
When the valve fails it can leak and also can divert hot water to the central heating heat exchanger when hot water is used. The reason that only the highest radiators in the system are affected is probably because the failed valve does not necessarily cause the central heating pump to activate and circulate the hot water throughout the system (it does on some boilers though). If hot water is introduced into a cold heating system it will rise via convection to the highest points in the system like an old fashioned gravity circulation system which was unpumped.
Call a heating engineer out as soon as possible; I'm not going to advise how to do the repair yourself as gas appliances MUST be serviced by qualified persons only for reasons of safety. If you're lucky then the valve simply needs cleaning up and a few new diaphragms plus other minor seals and rings. If it's gone too far then the valve and possibly the manifold it's attached to will need to be replaced.
In the UK the part alone typically costs between £100 to £200 depending on whether it's just the valve or the manifold as well. The diaphragm kit typically costs up to around £15 and is routinely fitted when the boiler is annually serviced, and a new valve will already have new diaphragms fitted. For a routine service expect to pay for up to two hours labour (many can be done in one hour), but if the valve/manifold have failed it will be longer as one failure often causes other parts to need further inspection/repair.
I hope that I've helped you today, if so please return the favour by rating my answer.
Jul 10, 2009 | Whirlpool Aquatic Millennium VII -...
No central heating back boiler
back boiler run from a gas fire? check the instructions to operate the gas heat to the back boiler not just the fire
I presume that this a fully pumped system - air lock doubtful There maybe on/off valves on the pipes to and from the back boiler [situate close to cylinder] make sure they are on - anticlockwise turn
or there could be a blockage in the outlet from header tank usually in the loft. or If there is no water in it maybe the mains cold feed it is off.
Note if no water in it DO NOT USE the back boiler
May 03, 2009 | Bosch & Power Vent Water Heater
Bosch & Power Vent Water Heater  Logo
301 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
