Question about Canon BJ I6500 InkJet Printer
Code to get rid of the 7 Orange light flashes when Print head is OK.
CANON Wide Format A3 Printer, showing 7 Orange flashes - print head problem. Print Head is OK, so how do I get rid of the flashing orange light. Trevo Aust.
I bought a new printer!
Posted on May 19, 2009
Hp 7000 won't print A3 paper size
mau nanya gan,printer ane hp k7000 gak mau print a3 tlng beri info gan ?
Feb 24, 2012 | HP Officejet 7000 Wide Format Printer...
Reset. Orange light blinks several times. Then Green. Then orange several times, then... on and on. Cannot reset. All ink cartridges have ink.
count the number of orange flashes in between the green light. two flashes = out of paper, 3=paper jam, 4=empty ink tank, 6=print head not installed, 7=print head defective, 8=waste ink tank is almost full
Jun 08, 2010 | Canon i850 InkJet Photo Printer
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Mar 25, 2010 | Canon Office Equipment & Supplies
Canon S300 printer. 7 orange blinks, 1 green. I
According to the manual found here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=330&modelid=6609
7 orange lights represents a bad print head, and the printer will need serviced or replacement. Since printers are so cheap lately, I would just go shopping. Hope this helps! Thanks!
Oct 21, 2009 | Canon BJC S300 InkJet Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Canon S520 printer stopped printing has 7 orange lights before the green light on printer has an error code
Hi ...
light flashing 7 times means that there is an issue with printer head. Try and perform the below steps to reset the printer head whcih might resolve the problem. If this doen not, I would suggest you get your printer checked by a technician.
Reseat the print head
  1. Confirm that the printer is powered on.
  2. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
  3. Hold and slowly move the print head lock lever up and down several times.
  4. Lower the print head lock lever to secure the print head.
    Note: Holding the print head may cause it to not be seated properly. Perform this step using only the print head lock lever.
  5. Close the front cover.
Don't forget to vote if this helps ... Cheers :)
Aug 05, 2009 | Canon Office Equipment & Supplies
I have a canon s9000 and am getting the following error code: 1 green light followed by 7 orange lights, then repeats. Any help appreciated peter
This is indicating a defective print head.
Remove and reinstall the print head. If this does not resolve it, then you will need to look at getting a new print head.
Mar 07, 2009 | Canon i950 InkJet Photo Printer
Can not print from my Cannon i950. 'paper thikness lever position
A friend of mine had the same problem and turned out to be the print head. They can be pricey so a new printer would be in order probably. Could also be the waste ink counter as well. Here are some steps to see if you can get rid of the 7 orange blinks:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
If this doesn't work then you know its the print head for sure.
Feb 10, 2009 | Canon i950 InkJet Photo Printer
Canon BJ I6500 InkJet Printer Logo
1,014 people viewed this question
old marine
old marine
