Question about Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX...Power, Green Light, All OK, No Sound!
I have a sony amp (XM-2200GTX) I have it properly hooked up (4 gauge power to battery, Excellent ground, Good speaker wire, etc.).  Here's the problem.  The green light is on but I can not get any sound.  I've tested the subs on another amp and they're fine.  I've tested the head unit outputs, etc.  Everything checks out and leads back to the amp.  Again, the green light is on.  It's never gone to red and yet I can not get any sound out of it. Anyone have any ideas?  Thanks
  • Anonymous Apr 17, 2008
    Same damn problem with mine.
  • 631 Answers
Sony generally drives their power light from a source that does not rely on the amplifier's switching power supply. This means that it's not a good indicator as to the health of the amplifier.
As long as you have B+ and remote voltage, it will light up. Since you've tested the speaker and the signal source, I think the amplifier is likely defective.
Posted on Oct 17, 2007
SOURCE:
My amp is not turning off even when my car is totally off. It never did this before.
Check the power lines. There might be some sort of short or the power amp might have been directly connected to the battery. Re-wiring the power cables might fix the issue.
Jun 20, 2010 | Sony XM-2200GTX Car Audio Amplifier
Can you bridge a sony xm-2200gtx amp, if so what polarity on which channel. Currently pushing two speakers. trying to see if i can bridge it and use a singe speaker?
left positive and right negative-make sure the speaker that you intend to run in bridged mode is 4 ohms or you will kill your amp
Nov 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hooked up to a kicker L712. Worked fine now its in protection mode. When i turn it on the light is green for a second then turns red. It wont stay green. What should i do? Is it the circuit board?
perhaps you are pushing the amp to hard check that the gain control knob is not turned all the way up. This will cause the amp to overheat. If not that check all of the wiring to the amp for a possible short.
Jun 05, 2009 | Sony XM-2200GTX Car Audio Amplifier
Amp makes a constant loud bump
try grounding the rca shield to see if it stops, if it does you have an rca ground problem in either your head unit or your amp
May 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
Bridging problems
Normally bridging an amp is using the left + and the right -
Here is a link to your amp specs
http://www.crutchfield.com/p_158XM2200/Sony-XM-2200GTX.html?tp=115&tab=features_and_specs
Jan 30, 2009 | Sony XM-2200GTX Car Audio Amplifier
How do i bridge a xm-2200gtx.
Usually the Left + and the right - is bridged. Here is a link to the specs on your amp:
Sony XM-2200GTX no sound but light will go on sometimes
I'll assume that you've checked the amplifier's on-board fuses.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Nov 05, 2008 | Sony XM-2200GTX Car Audio Amplifier
Got power to my amp but no bumps
make sure your rca cables are good and also check the bass adjustments on your amp
Mar 09, 2008 | Sony XM-2200GTX Car Audio Amplifier
Sony XM-2200GTX Car Audio Amplifier Logo
385 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
