Question about Sony Audio Players & Recorders
How to use Sony Electret Condenser Mic ECM-102
Looking for manual for Sony Electret Condenser Mic ECM-102
  • saros21 May 20, 2009
    dear mgueffroy,
    thank you very much for solution,but i am looking for ecm 102 model
    President:
  • 1,137 Answers
The closest manual I find is at http:// www.mutinymedia.co.uk/tie_clip_mic_files/ecm44b.pdf. Shows where the battery compartment is and gives specs and usage tips.
Posted on May 19, 2009
Not working
Is it an electret condenser type then it needs a battery in the shell. The body normally can be screwed open to expose the compartment. Otherwise if it is dynamic make sure it does not need a "Phantom" supply from your mixer. Is it a balanced mic then some of them need a transformer so without seeing it and do tests this is all I can offer
Mar 29, 2014 | Samson R31S Microphone
Casio wk-7600: I just purchased it and trying to set it up. I connected a dynamic mic. in "mic. in" slot as the user manual described. The mic. didn't amplify my voice. Do I have to configure the use
Use only DINAMIC microphon (computer microphons are not dinamic- they are condenser-electret) with MONO jack.
1. Turn knob (beside "mic.in") "mic.volume" (T-7) full clockwise.
2. Press "MIXER" (C-7).
3. Press "<" (R-17) while is shown "MIXER PART>:EXT(M/I)
4. Set (check) Part [ ON]
Volume: [80...127]
N.Tresh [0]
If after microphone disconection there is a noise from speakers - set
PART [off] or N.Tresh [20] (or higher))
Jan 12, 2014 | Casio Music
Hallo .i have a problem with this: microphone condenser electret toshiba EM-220 how should it work?? it need a phantom power 48+??? i have just a normal audio jack on the mic.to plug into my mixer with...
If it is a condensor mic, it will need phantom power, some mixing desks have specific inputs that have phantom power and there is usually a switch to press. Also some mics use a battery instead of using the phantom power on the mixing des.
Good luck
Aug 09, 2011 | Toshiba Audio Players & Recorders
My mic does not work. when i looked inside computer i notice that a plug that was labled mic power [yellow wire] was not plugged in. I power cleaned the inside with a air compressor and might have jarred...
Desktop PC's do NOT come with any Mic's attached, they only use a Mic, Jack usually Red. You can plug a Mic, into this and use it that way. Also you can get a USB Mic, or headset, this is usually what is done. That Mic. Power, & it supplies power to a thing called an "Electret Mic" I have found a link below.so you can find your manual http://www.foxconnchannel.com/support/downloads.aspx
Mar 05, 2010 | Computers & Internet
Hi, I bought a sony ecm mic brand new, but whenever i switch it on, the red light comes on for a fraction of a second and then goes off, and i cannot record with it. This is despite trying many new...
Ah, yes.
If you look in the manual you'll find that the mic is supposed to do this.
If the LED does not blink when you switch on then you have a flat battery, otherwise it shouldn't stay lit.
The manual is available here in PDF format: http://pdf.crse.com/manuals/3858569131.pdf
I hope this helps.
psibernaut >;-)
Oct 24, 2009 | Sony ECM-MS907 Professional Microphone
Mic not working with sound pod for T2900
yans, i have a trouble with the harman kardon audio driver for toshiba satellite m-305-s4820, would you like to send me the driver.
Apr 24, 2009 | Creative Labs Inspire T2900 Computer...
Sony ecm 719 doesn't aseem to be working properly
Hi kollydogg
The mic you purchased is a condenser type that requires either a battery(you now have), or a sony power supply. Without it, I would expect it to not do much at all. The specs look ok on it. Good for bootlegging concerts :)
regards
robotek
Jun 27, 2008 | Sony ECM719 Consumer Microphone
Crackling occurs after 1 minute of video&audio
Hi that all sounds to me to be a fairly classic "Electret" Mic problem. I have seen .. lol.. or rather, heard it, a few times B4.. the "Frying" sound you hear is the faulty electronics in the Electret microphone.. I would try replacing the Mic, if you can get one the same size, it shouldn't be too hard to Open the camera up, unsolder the old Mic, & replace it. There are really only a few standard Electret Mic inserts... As an aside, sometimes it can simply be a bad solder joints to the wires on the actual mic itself, ya may wanna try good reflow/resolder first B4 ya replace.. This sometimes is all it requires...
Aug 27, 2007 | Microsoft LifeCam VX-1000 Webcam
692 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
