Question about OEM Systems Car Audio & Video
How do you remove the dash speakers from a 1994 Buick Lesabre?
How do you remove the front dash speakers form a 1994 Buick Lesabre?
  • john_grubbs May 17, 2009
    top of dash has to come off first how is that done?
    Genius:
  • 1,148 Answers
Use a offset screwdriver,,if it has screw on top
Posted on May 17, 2009
How can I fix a vibration in the dash in my 1994 Buick LeSabre?
TRY ROTATING YOUR TIRES.HAVE YOU HAD A ALIGNMENT AND BALANCE LATELY?
Oct 05, 2014 | 1994 Buick LeSabre
Wher is the electronic control module located on a 1994 buick lesabre
Hi there;
On 1994 Buick Lesabre 3.8L SFI OHV 6cyl the Engine Control Computer is located front seating area, passenger side, behind dash, mounted behind glove compartment cavity.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 20, 2012 | 1994 Buick LeSabre
94 BUICK LESABRE RADIO WIRING
1994 Buick Lesabre Car Stereo Radio Wiring Diagram
Car Radio Constant 12V+ Wire: Orange
Car Radio Ignition Switched 12V+ Wire: Yellow
Car Radio Ground Wire: Black
Stereo Radio Illumination Wire: Gray
Stereo Radio Dimmer Wire: Brown
Stereo Radio Antenna Trigger Wire: N/A
Stereo Radio Amplifier Trigger Wire: N/A
Front Speakers Size: 4′ x 6′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
May 15, 2010 | 1994 Buick LeSabre
How do you remove the front speakers on the 1990 buick lesabre?
remove the upper dash pad first, then the rest you can figure out.
May 11, 2010 | 1990 Buick LeSabre
Remove the speaker covers and the screws that hold the speakers in place. Be careful - the windshield is too close and it will break if you hit it too hard.
Mar 18, 2010 | 1990 Buick LeSabre
Turn signal not working
i had this same problem and i alleviated it by replacing the column switch which isnt an easy task and I used a manual (which can be obtained at the library for free or you can buy one at your loccal book or auto parts shop)
Aug 26, 2009 | 1994 Buick LeSabre
Diagram needed
HELLO THERE: Here is a link that will help you out ok dont forget to rate this soultion this helps me out too 1994 buick lesabre serpentine belt removal 1994 buick lesabre serpentine belt removal. Custom made wrestling belts ... money belt zipper. chest injuries from seat belts. serpentine belt diagram 30 mitsubishi ...beltpedia.info/1994-buick-lesabre-serpentine-belt-removal.html
Aug 15, 2009 | 1994 Buick LeSabre
Front dash speakers
look around why ask everybody for the answer buy the repair manual
Aug 10, 2009 | 1993 Buick LeSabre
1994 buick lesabre heater core removal
The heater core is located under the dash, in the center. The container holding the core looks like a black plastic box. Remove the ash tray for easier access. You may have to also remove some other covers under the dash. You must first drain the radiator then you have to disconnect the hoses. There are two hoses connected to nipples of the heater core that go thru the center of the firewall. Remove the screws that hold on the cover to the heater core. Then you should be able to get the old one out. There might be a couple of other minor steps but I'm sure you can figure them out. For re-installation just go in reverse order to put it all back together.
May 25, 2009 | 1994 Buick LeSabre
Car Audio & Video Logo
283 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
