EASY ONE.... Your VSS (Vehicle SPEED SENSOR) stopped working and it is this Sensor that gives the PCM/ECM the information to change gears. Once you change your VSS, and get it working, the Transmission will start working again...
I am Assuming that the Transmission stopped working at the same time the Speedometer did? Is that right?
If it is, then this is a easy fix. 1 bolt and one Wire Connector and DONE....
all chevy made in that year have a speedometer issue i have a 2004 chevy that has the same issue the only way to fix it is to replace the dash insturment panel some of them the speedometer goes and the rest of the gages work fine or try replace the speed sensor located at the front of the transmission on the bottom
This has happened on our van multiple times. Through some internet searches I have found a solution that works.
Go to your van and, with the ignition off, press and hold the trip reset button. You will see 'Sof' and perhaps some diagnostic test numbers will show up on odometer; the unit will perform a self-test, and the system will do a reset and should it should operate normally.
