When i turn on pc show on monitor "disc read error occoured"
This can occur as a result of any unreadable drive that is in your boot sequence not reading. Remove all media from the machine(CD, DVD, Memory Card, Flash Drive, Floppy Disk, Printer with memory card slots), then try booting again.
If that doesn't work, chances are your hard drive is damaged. It may only be minor logical damage or could be serious hardware damage. That is more difficult to assess via subjective analysis but could be sent to a pro for assessment if you have files you require on the drive which are not backed up.
If this is the case and you do not have anything important on the drive or if you have your files backed up on a second source simply replace the drive and re-install your operating system, then restore the backed up files and move forward.
If you require any additional info or advice, just ask
Chris
