Problem for Festool Drills / Drivers
Generic problem for all Festool Drills / Drivers
Festool charger not working light not on
festool charger not working light not on
Comments:
May 28, 2009
- festools reply was buy a new charger $208
Solution #1
posted on May 27, 2009
Rank: Guru
Expert
Rating: 89%, 809 votes
Here's a link to the Festool support site, where you can access lots of knowledge base information by entering your model number, Otherwise, I'd email them with your question. They tend to be pretty good with support for their products...
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Comments:
May 28, 2009
- Well, at least you know. I'd open it up and see if it has a fuse. I once was able to repair a Makita charger by soldering a new fuse into it. If it doesn't work, can't do much harm to see...
Questions and Unsolved Problems for Drills / Drivers
what is the best 18 volt cordless drill on the market?
Posted. Thank You!
what is the best impact driver
Posted. Thank You!
Hi I have Makita charger DC18RA, when charging the red and green lights flashing in the same time, I...
(More)
(More)
Hi I have Makita charger DC18RA, when charging the red and green lights flashing in the same time, I change 4 different batteries but it happens the same. Could you give me an advice Thanks! Khanh.
Posted. Thank You!
Congrats on your 3 solution. You're helping others! Someone may even thank you with a Testimonial.
Ryobi 18V battery won't recharge
Posted. Thank You!
I have a makita driver and drill with a keyless chuck accessory. I am unable to get the drill bit...
(More)
(More)
I have a makita driver and drill with a keyless chuck accessory. I am unable to get the drill bit out from the chuck...it just keeps spinning but does not loosen the drill bit.I have pulled the collar back towards the drill and reversed the drill direction but with no luck - the chuck has been only used 2-3 times so is as good as new!! Thanks S.
Posted. Thank You!
