Question about Porter Cable 690LR Router
Router runs slow
Been shaping for about 2 weeks and now my porter cable router runs slow and hot. opened it up cleaned the armature, brushes look fine, router still runs slow
  • 5 more comments
  • sm_const May 17, 2009
    It spins fine, I took it apart and cleaned out any dust and sanded down the contact point on the armature. I don't think it's a bearing problem. Brushes look fine. I just runs slow and makes a strange sound, gets really hot too.
  • sm_const May 18, 2009
    Yeah a slight squealing and the heat is where you would grap the router if you weren't using the handles eg. main body
  • sm_const May 19, 2009
    porter cable 690lr (6902 motor)
    central coast calif.
    Ok opened it up again and sanded down the contacts and armature. I think it's back up to speed. I did notice that all my fan blades are missing :( I'm sure it's due to shaping material and a piece fell inside the router. It got hot and melted the contacts). I did notice a little play in the lower bearing but when I put the router back together there isn't any play. So now I need to find out if the fan that mounts to the armature can be replaced. Thanks for your help.
  • sm_const May 21, 2009
    Thanks for your help I found a fan and I'll have it installed locally. Thanks for your help.
  • David Ford
    David Ford May 11, 2010
    That sound is it like a slight squealing and where is the heat located
  • David Ford
    what do the bearings feel like. I am thinking they are seizing up causing you a problem. Unplug the tool and turn the armature shaft by hand to check.
  • 2,176 Answers
I still think that it is the bearings, especially since of the squealing noise which is a symptom of the bearing seizing up and the armature shaft would get hot transferring the heat to the motor housing. Give me the model number and brand and I will find a breakdown and part numbers for you and also if you give me your general location I will try and find someone local to get the parts.
Posted on May 19, 2009
  • David Ford
    David Ford May 21, 2009
    You must be living rigth. The fan on the model and type I looked at is available. Around 9.00. I suggest that you go to Dewaltservicenet.com and type in your model number in the middle of the page at the bottom and you will need the type number to see if it is for your router. Then you can back out and find a dealer close to you or give me a shout and I will find one for you. The downside is that the fan has to be pressed on (usually) so whoever you contact ask them if they can do it, and to be on the safe side as the armature is out I would also recommend replacing both bearings whether they appear good or not. saves time. Good Luck and let me know
I have a porter cable pancake compressor 135 and it's sparking and smoking . What do you think it is?
Heavy sparking at brushes indicates shorted armature or short in field. Examine commutator bars, should look dark gray to black but very smooth. If scratched or pitted most likely end of life. If not too bad could be weak brush springs or worn brushes. Brushes should be at least 1/2 to 3/4 in in length. If commutator and brushes good , suspect field. Good luck
Sep 28, 2016 | Porter Cable Air Tools & Compressors
How to remove the chuck from a porter cable router?
To remove the collet (not the collet nut) you must first take apart the armature from the field.
To do this,
1. Take the cap off the top by removing the two Phillips screws.
2. Remove the two brushes.
3. Remove the two Phillips screws hidden under the cap.
4.The only thing holding the top and bottom pieces now is a friction fit of the bearings. Tap with a non marking hammer on the top housing underneath the brush holders, and it should come apart after a few taps.
5.Use an armature split sleeve and put the armature sleeve in a vice to hold the armature.
6.Then use a wrench and unscrew the collet from the armature.
7. Just reverse this process to put it back together.
May 22, 2014 | Porter Cable Tools & Hardware - Others
"DWDewalt DW712 won't always start until I rap the housing. runs slow"
Start with the brushes - they are either worn low or the brush tubes are causing them to stick so they don't contact the armature - this is why it starts when you 'rap' it.
Running slow can be a bad armature or field from running hot because of the bad brush connection.
1) remove the brushes
2) remove the 4 bolts holding the motor to the saw
3) pull the armature out and inspect for signs of being burnt (especially look at the copper commutators where the brushes sit)
4) inspect the field for signs of being burnt
Nov 28, 2013 | Dewalt DW744S 10" Portable Table Saw with...
My 12 year old plunge router 7529 does not start. It worked just fine a couple of days ago and all then sudden... nothing. Any suggestions!
A 1 year old router...that suddenly stops working. My suspicions would be brushes first then the switch.
There are 3 different types of this router Type 1, 2, and 3.
Parts can be found here:
http://www.ereplacementparts.com/porter-cable-7529-type-plunge-router-parts-c-129_1672_1985.html
Brush is item 3 and switch is item 4.
pdf of diagram: http://www.ereplacementparts.com/images/Porter_Cable/7529_TYPE_1.pdf
Thanks for choosing FixYa,
Kelly
Kelly
May 11, 2011 | Porter Cable Garden
I want to test the armature to solve a brush arcing problem I have a volt meter. how to do this?
put your test probs on the armature and hold them were the brushes tuch on eather side you should get a reading from all of them "one at a time" check the commutator for burn marks or big gaps,,,if there there scrap the motor,
Aug 08, 2010 | Porter Cable Porter-Cable 6" Saw Boss 345
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Router doesn't turn on
Try removing and cleaning your brushes before you order anything. That is the first thing that fails on these. Then try pushing the brushes in and out of the brush guide to be sure it floats in and out properly. Next check your armature for dark areas and buff with 1200 grit emery cloth or wet/dry sandpaper.
Mar 24, 2010 | Electrical Supplies
I haven't used my porter cable router for several months. Went to use it today and it won't run...any suggestions?
If it was stored in an area that wasn't dry it could be as simple as replacing the motor brushes. Part number 869659 or 824216 is available for about $5.00. The motor is pretty easy to take apart if you want to give it a good cleaning. Check your brushes first a coin or a screwdriver to take out the black plugs on the sides adjacent to the power cord. they are spring loaded so be careful. I've lost one in my personal bermuda triangle garage floor. if they look corroded take a piece of fine grit sand paper and lightly sand them. see if that does the trick, if it doesn't and you are inclined i would clean the inner and outer fields of the motor.
Feb 15, 2010 | Porter Cable 690LR Router
My 890 series router motor is not always getting up to a high enough rpm. It cuts in and out to a speed so slow that it is unable to use
could be a couple things, the bearings could be seizing up, do you hear a noise or is the motor housing getting hot to the touch. Could be the brushes worn out, unplug tool and remove the brushes and check for discoloration on the armature and brush condition. These are about the only 2 things that could cause it other than a complete electrical failure which I doubt. You can go to Dewaltservicenet.com and type in your model number to download a breakdown for this tool if you intend to repair it yourself.
Sep 22, 2009 | Porter Cable 8901 Router
How do I disassemble a porter cable 1002 router? I am trying to get to the motor in order to clean out pieces of broken brushes.
How do I hold the armature still on a Porter Cable Model 1002 Router to take the nut off to change the inner bearing
Oct 14, 2008 | Porter Cable Tools & Hardware - Others
Porter Cable 690LR Router Logo
575 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
