Question about LG Heating & Cooling
Water draining from window air conditioner runs down the side of the house creating wet basement wall and mold grows inside basement. How to drain away from house?
  • 148 Answers
Your problem is definately the pitch of the unit
Posted on May 18, 2009
  • 252 Answers
If the inside is clean and the unit is installed with very minor slope toward the outside, you should not have any water draining. It should get picked up by the fan and blown thru the condenser (outside) coil, evaporating, and helping with the heat transfer. Take the unit out of the window. Take it outside, Remove the outer cover, and wash out the inside - especially the pan in the bottom and any slots where water runs from area to area. Try not to get the electrical control area very wet, if you do let it dry before re-assembly.
Posted on May 17, 2009
My ac window units are not draining water and creating mold in my house
Check the drain tube between the evaporator side to the back of the unit. It may have a packing plug installed. If there is one remove it or clean the drain tube.
Jul 23, 2014 | Frigidaire FRA08PZU1 8,000 btu Window AC...
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
Does air cnditioner give any foul smell when running
Hello typically a air conditioner does not give off a foul smell, sometimes the condensate that drains out can have a moldy kind of smell or if mold is growing inside the unit it can give off a foul smell called " dirty sock syndrome". The last possibilty is that if the condensate line is drained to a floor drain and on the negative pressure side of the evaporator coil it could be pulling the sewer gas up thru the line, in this case the condensate line must be trapped to prevent this. Also, I would recommend pouring some bleach into the condensate line every few monthes.
Jul 16, 2012 | Amana Heating & Cooling
Water is dripping from corner of unit that is inside the house, going down the wall and making the carpet wet.
Check your drain
also make sure the unit leans a little tilted
Towards the back
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 05, 2010 | Haier ESA3125 Wall/Window Air Conditioner
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
My Mitsubishi air conditioner has started to leak heaps of water from the side of the unit. It would appear to be something like a blocked drainage system, but I do not know how to open the unit to clean...
find the drain hole in the rear of the unit and take a piece of wire and rat the drain hole out, its got mold growing inside and plugging the drain
Oct 25, 2009 | Heating & Cooling
A.C. unit is draining on the inside of the house.
There is a drainage and it is stucked with dust, mold etc. Just open metal lid on the wall inside your house, where the coil is installed and where you're changing filters, remove air filter, there at bottom you will see the drainage hole (now under water probably). Rent an air compressor from Home Depot or Lowe's, stick the hose to that hole and turn compressor on. This shall blow the drainage through. After that slowly pour 1-2 cups of Chlorox or Tylex in there, let it stand for 15 minutes, then pour some more water and blow with compressed air again, then flush it with water and blow last time.
Do that at least once in two years, or you gonna have same problem again.
Sep 14, 2009 | Frigidaire FAC126P1 wall/window Air...
Leaking central a/c unit
All central A/C units have a condensate drain line that comes from just under the evaporator in the Main air supply plenum.
You may have a blockage in that drain line and will have to remove the pipe to clear the obstruction. Try flushing the drain pipe with warm water until it flows easily from the top to the end.
You might have a gravity drain that goes into a floor drain or a french drain along the basement walls. The other typical drain installation is a condensate pump that the water drains into and when the float in the tank is lifted, a small pump turns on and pumps the water (condensate) out of the house either thru a drain hose thru the wall, or into a drain in the basement, etc.
Check the entire drain line and anything connected to it for any possible obstructions and/or blockage.
If you have any other questions once you take a look at your installation, just add a comment and I'll check back within a day to provide more info, based on your input.
I hope you found this very helpful and best regards!
Aug 06, 2009 | Whirlwind FH-778 Air Conditioner
Central air conditioner leaking water somewhere. Water is going through furnace filter (furnace filter is wet) and ductwork and wetting the ceiling below. What should I look for?
look for a cover that covers the a A coil.take the small 1/4 in screws out and carefully remove the covers or cover if you have access do both sides. my basement has enough room to get to both sides. my house tlr you can only do one side. look for a drain hole blow it out with a air hose or garden hose run a wire if you have to.
Aug 01, 2009 | Heating & Cooling
Goldstar Air conditioner
Tilt the unit toward the window opening and clear the drain holes in the back and bottom of the unit from debris.
Jun 09, 2008 | Goodman CKL36AR36 Air Conditioner
Heating & Cooling Logo
238 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
