Question about Maytag Neptune MAH5500B Front Load Washer
Clothes still wet washing on Maytag neptune
I have a maytag neptune MAH 5500 that I bought 6 years ago. It has a problem now. Washing clothes today that clothes still wet after final spin. I would like to know what is wrong with it. Thanks
  • 2 more comments
  • Anonymous Mar 12, 2014
    Final spin won't get up to speed and diagnostic shows a 23
  • Anonymous Mar 17, 2014
    maytag neptune washer mah-3 will only spin in one direction
  • Anonymous Mar 18, 2014
    top loader washing machine
  • Anonymous Mar 21, 2014
    motor does not spin
    clothes stay wet
  • 94 Answers
Your pump, or the hose between the pump and drum, might be clogged.  Could be spare change from unemptied pockets.
Posted on Oct 17, 2007
SOURCE:
Ou Maytag Neptune Washer MAH-3 will not drain.
This problem was answered a couple of years ago in detail. A search should produce it. Search the name Scruggs.
Sep 02, 2014 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer clothes staying wet after cycle
Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
The clothes are soaking wet after the run on the machine. It seems the spin function is not working. I have a maytag neptune model front load.
I have the same problem. I have spent about $1,400 in repairs on this damn machine since we bought it about 8 years ago. It works for a bit then something else goes wrong. This is the fourth time I've had this problem.
It's the belt, it's the motherboard, its this its that $200 a pop. Just enough to say ok, any more I'd buy a new one, then a few months later something else happens.
What happened to Maytag? My mom and grandmother both had maytags for years, decades without an issue. The new ones ****.
Nov 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front load has Lr on Time display
Im having the same problem what is the lr code and how do you get rid of it?
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
705 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
