Will Not boot
I have a Dell XPS 710 that will not boot up, the power light is solid orange. Have pulled all memory and peripheral cards, the light stays orange. There is also an orange LED near the main power that is lit up. I am almost positive that this is a Motherboard problem.
    President:
  • 1,179 Answers
If the light is near the psu plug on the motherboard then this is more likely a power supply issue. If your computer is still under warranty Dell should replace it for free. Hope this helps.
Posted on May 17, 2009
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Orange light
If its a Dell E520
You can tell a lot about the condition of your Dell E520 computer simply by looking at the lights on the front of the unit. The color and condition of those lights can indicate a problem with the computer's hard drive, monitor and other components. Learning to read these lights and understand what they mean can save you a lot of time and make troubleshooting a lot easier and more effective.
Unplug the Dell E520 and plug it back in. If the amber light stays on, try moving it to a different power outlet and using a different power cord. Remove all peripheral devices from the E520, with the exception of the keyboard and mouse. A steady, amber power light can be caused by a malfunctioning piece of equipment. Turn on the computer on and wait for it to boot. If the computer boots with the peripherals removed, add back each peripheral one at a time, rebooting the computer after each device is added. Continue this process until you identify the malfunctioning device. Shut down the Dell E520 and remove all devices from the back. Remove the retaining screws on the back of the tower and remove the computer case. Locate the memory modules on the motherboard and remove them one at a time. You should see small, white retaining clips on the motherboard these retaining clips hold the memory in place. Spread those clips apart, then lift up the memory module and set it aside. Remove all the memory modules, then add them back one at a time, restarting the computer after each one is added. Continue until you identify the malfunctioning memory, then replace it with a new module. Remove any add-on cards for graphics controllers, networking and other purposes. Remove all the cards, then reinsert the cards one at a time until you find the bad card.
Feb 13, 2013 | Dell Inspiron Computers & Internet
I have a Dell Dimension E520 that I've used for
If the power LED is solid Amber, then the like answer is a bad motherboard or peripheral connected to it. So, remove any expansion cards (I See you already removed the Graphics card) and all external connections (Just use power cord) and see if the system will power on with any different indications. If the power LED stays Solid Amber, replace the motherboard
Aug 07, 2011 | Dell Computers & Internet
My dell Optiplex won't boot up after shutdown. It just hangs there with a orange light in the start up switch.
A solid orblinking Amber power button indicates a voltage problem. This can be caused bya defective power supply or a defective motherboard. Just to make sure thatnothing else is causing the problem, remove any PCI cards like modem, videocard, sound card, etc... Remove the memory modules and disconnect cables toCD/DVD drives. Look at the USB ports to see if any are damaged.
Mar 27, 2011 | Dell OptiPlex GX270 (GX270R) PC Desktop
Xp420 dell doesnt boot just a solid amber light on mother board high rpm on fan that doesnt slow no picture on screen....?????
Solid Amber light is a No-Boot scenario for all DELL PC. It may be either Power Supply, motherboard, memory or Proc. If you try to call Dell customer support they might try to let you isolate the problem by opening up your pc. But they will replace the parts necessary if they found out that its broken and your XPS is still under warranty.
You can call 1-800-232-8544 be sure to have you Service Tag or Express Service code ready.
Jun 21, 2010 | Dell XPS 420 PC Desktop
Solid amber light. No power to the system just the fan runs.
Solid amber light means the CPU is not being powered properly, that is USUALLY a bad power supply. Contact Dell and order another power supply. if that doesnt fix it, you have a bum board. (usually, you will see popped capacitors on the board if its bad). I will say, that in about 70% of these, its a bad power supply. power supplys arent cheap (unless you have a warranty of course) but they wont break the bank. a replacement is likely going to be about 40-70 dollars. I havent priced it, but you can ask dell at dell.com/chat. Good luck.
Nov 19, 2009 | Dell DimensionTM XPS 710 PC Desktop
I want to replace the PSU on a Dell XPS 710. How do I remove the old PSU?
Open up the back of the case, unplug the cables and pull it out.If you don't know where the PSU is, it's where the power switch pokes through your case.
Sep 25, 2009 | Dell DimensionTM XPS 710 PC Desktop
Dell Dimension 8400, no post. B and D amber.
GYGY diagnostic lights -- Memory is detected, but a memory configuration or compatibility error exists, and the 1-3-2 beep sound indicates the MEMORY test failed, which means one of the four memory has gone bad or the one of the four slots on the motherboard has gone bad, Neither the memory nor the mother board has completely gone bad, but either one slot or one memory has gone bad, try placing one memory on all slots and check which slot is the issue, then trying placing any 3 memory on the remainig slot to isolate the memory, then after that use the best 3 in the best 3 slots and check, you computer should work fine, this would help you for sure
Feb 06, 2009 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
594 people viewed this question
David Payne
David Payne
