Question about D-Link DIR-625 (790069292637) Wireless Router
Usb port uses
I have a DIR-625 and was wondering if I could attach a printer to the usb to share on the network.
  • DWDpcRepair May 11, 2010
    is the printer network capable?
  • 2,460 Answers
The answer is probably. Start here http://www.dlink.com/products/support.asp?pid=501&sec=0#manual If you don't have a RevC1, the answer is no. If the answer is yes, then you need to start reading the firmware notes and how to upgrade or make sure you have 3.08.
The notes and accompanying instructions are pretty solid.
Carl
Posted on Jun 02, 2009
I have a D-LINK DIR-625 router. i need to add a printer to the network but not sure how. Someone had told me that the router does not support the additional printer but i dont believe that. Can you please...
If the printer is a network printer connected via wifi or via ethernet you should be able to add it on your network.
If the printer is connected via usb port you will need to have a router that has a usb port and is able to add it on your network.
If the printer is lan (ethernet or wifi) you plug it and search in printer installation for a network printer. To easier step you may want also to reserve to the printer a fix ip address and a network name.
For further information you may want to follow producers instructions. If you don't have the manual you should be able to download it from producers website
Apr 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
I need to connect my printer to my wireless router.
Assuming your printer is network compatible:
  • If it uses Wireless, use your printer's configuration to connect to the D-Link's network. You may also want to use the D-Link's built-in DHCP controls to assign a single IP to your printer for simpler setup
  • If it has an Ethernet port, connect a cable from the Printer's Ethernet port to one of the 4 ports on the back of the router. This should connect the two and all going well, most printers will sort themselves out from here.
If your printer is not network capable, you will have to connect the printer to a computer then use Windows sharing options to share that computer's printer with the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
What programs do I have to remove from my hard drive to uninstall the DIR-625?
just go to open network and sharing and delet that enternet connection and then reinstall a new connetion.
Feb 22, 2011 | D-Link DIR-625 (790069292637) Wireless...
I don't know how to set a password on my d-link router because my internet is insecure. How do i do this? I have the default username and password, but i don't know what to do from there.
1.Open your Internet browser and type in the default IP address for your DIR-625 wireless router: 192.168.0.1. A window will appear asking for your DIR-625 wireless router network name and password. If you do not know your existing network name, enter the default network name, "Admin." Leave the password blank. If you have already set up a network name and password, enter it now. Select "Log In."
2.Select "Wireless Settings" from the left-hand navigation bar. Put a check mark in the box marked "Enable Wireless."
3.Type your new wireless network name for your DIR-625 in the box labeled "Wireless Network Name."
4.Type your new password for your DIR-635 in the box labeled "Pre-Shared Key."
5.Select "Save Settings" from the top of the screen to save your new password.
Feb 07, 2011 | D-Link DIR-625 (790069292637) Wireless...
Remote storage drive won't (USB) network to laptop
In fact the USB port on the DIR 825 is meant for share port.
So if you plug in a pen drive it should work.
May be the storage drive which you plugged into the router is not plug n play or something like this.
Mar 15, 2010 | Computers & Internet
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
D-link dir-625 in bridge mode
Try disabling the routers dhcp undet the network setting and make sure that the ip address is in range of your own network.
Jan 05, 2009 | D-Link DIR-625 (790069292637) Wireless...
How do I open port 30000 in a DIR-625 router?
Hello marquitos4,
Go to http://portforward.com/english/routers/port_forwarding/Dlink/DIR-625/DIR-625index.htm
and you will find all the info you need regarding port forwarding through your D-Link router.
The page is specific to the DIR-625 but just about any make/model is supported at http://portforward.com/
Enjoy,
FixThemAll......
Dec 15, 2008 | D-Link DIR-625 (790069292637) Wireless...
How to connect USB NAS to D-Link DIR 655
if you update your router firmware to the most current you can use the usb port to connect to an external hard drive or flash drive but you have to install drivers on the computer you want to access it with also i believe only one person can access it at a time
Oct 25, 2008 | D-Link Xtreme N DIR-655 Wireless Router
D-Link DIR-625 (790069292637) Wireless Router Logo
356 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
