Question about Garden
I have a John Deere Riding lawn mower which starts
I have a John Deere Riding lawn mower with a kawaski engine which starts ok runs ok for about two minutes then dies, starts back up and does the same over and over.
  • rjivaro May 11, 2010
    Install a new fuel filiter and try again. Also, if your fuel is more than 4 months old, remove and give it fresh fuel, and as you approach the end of the mowing season be sure to have sta-bil in the fuel you put in it.
  • Phil High
    Phil High Aug 05, 2017
    I had a push mower that did that. The problem was it had the wrong fuel cap and wasn't allowing air to pass thru the cap.
  • 246 Answers
Hello roobar2009:
>>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
>>If you have Changed the Filter and the Gas and the Problem is Still happening, then
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 17, 2009
2007 riding mower John Deere backfires while trying to start will not start
Inspect/replace the air filter to ensure proper air flow.
Inspect/replace the sparkplug(s) to ensure proper firing.
Check the position of the "choke" (if equipped; & by the way, most riding lawn mowers do not use a primer bulb button to prime the engine before starting).
Jul 03, 2015 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
180 john deere riding lawn mower
Your deck belt slipping. It need adjusted or replaced
Aug 11, 2014 | John Deere Garden
John deere d140 ont move
there is a small handle on the back of most riders allowing you to free wheel the machine. If you can push your machine freely now then push the handle in and it should drive
Aug 04, 2014 | John Deere Riding Lawn Mower. D140 48 in....
Is there any manual for a john deere riding lawn mower model # la115
if you look up "john derre riding mower" blog or club, I'm pretty sure you will eventuality find a bunch of lawn mower enthusiast, with alot of time and resources on their hands. Most of the time you can find rare parts, paint, manuals and lots of extras.
Jul 16, 2014 | John Deere Garden
John deere d110 clicks but won't start
Starter solenoid. 10 bucks. just fixed mine, exact same problem.
Nov 09, 2013 | John Deere D110 19.5HP Single Cylinder...
JD 68 riding mower
dear sir
tour bottom end is going in your lawn mower or tyoyur block is cracked. sorry but thats the truth.
May 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Won't run and try use starting fluid that engine
did u make sure your jets r set in the carb or are your vacum lines hooked up right.
Jul 06, 2009 | Garden
BACKFIRES THROUGH CARB,WONT START ,MOTOR IS KAWASAKI FC420V IN A JOHN DEERE LAWN TRACTOR
Most likely water in the fuel. Drain the tank and clean the carb. replace with fresh gas. Mr fix it is a dumby
Apr 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
1,733 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
