Question about PPI PC2600 Car Audio Amplifier
Ppi pc2600 As soon as I try to hook the amp up, the fuse blows.  What gives?....
  • 631 Answers
If the fuse only blows after the remote voltage is applied, the output transistors are likely shorted. To eliminate the speakers as a possible fault, disconnect the speaker wires from the amp. Also disconnect the signal cables.
If the fuse blows without remote voltage applied, either the power supply transistors are blown or the B+ and ground are reversed (or they may have previously been reversed).
Posted on Oct 17, 2007
Some of the resistors inside it are fried need to know which one to replace them with
look for resistor color code chart on line. it will give you the value and the wattage size.
Mar 13, 2011 | PPI PC2600 Car Audio Amplifier
I just got my PPI dcx 300.2 amp back and i hooked it all up, and connected the fuse back in and started the truck, the amp turns on but the red light starts blinking and says clip out. The amp doesnt smell...
Are you sure everything is correctly connected. If you are running the amplifier in bridge mode then take note that the load to the amplifier can be no lower than 4OHM. dreamsystems
Feb 25, 2011 | PPI DCX-300.2 Car Audio Amplifier
I just replaced an amp and now the inline fuse by the battery keeps blowing
Most likely you have your power and ground connections reversed on the amp. That will cause the fuse to blow immediately upon contacting the two sides of the fuse. If the fuse stays intact for a short while but pops after turning the amp/car on and your connections are correct then there's a problem with the amplifier and it either needs to be serviced or replaced.
Dec 01, 2010 | PPI PC2600 Car Audio Amplifier
I got a ppi d1000/1 amp cant get any sound out of it?
Make sure your remote wire is hooked up in the right spot, also check your rca plugs and consider replacing them, check all fuses to make sure their not blown, a loose or not good ground wire or power supply wire will also cause this problem. If a power wire has a cut in it, that will also cause fuses to blow, as well as with a ground wire cut, ur amp will not be properly grounded.
Sep 26, 2010 | PPI PrecisionPower D1000/1 Subwoofer Mono...
Need lost power pluggs
both the power and speaker plugs are available on e-bay. search for ppi plug(s). You will find them there. Also, if you are interested in the actual maker of the plugs, I believe it's a company called WECO.
Jun 11, 2009 | PPI PC2600 Car Audio Amplifier
Ppi amp
Here is an archive od PPI PowerClass manuals...
http://narbi.free.fr/manuels/Amplis/Precision%20Power/Serie%20Powerclass/
Jan 30, 2008 | PPI PC2600 Car Audio Amplifier
Need owners manual
Here is an archive of PPI PowerClass amp manuals...
PPI PC1400
Since it's an intermittant problem and a relatively expensive amplifier, you should have it checked by a qualified tech. If you keep trying to power it up, it will eventually blow out the power supply transistors which will add as much as $100 to the repair bill.
Oct 19, 2007 | PPI PC1400 Car Audio Amplifier
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Car Audio & Video Logo
175 people viewed this question
Top PPI Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a PPI Car Audio and Video Expert? Answer questions, earn points and help others
