SOURCE: Power Led Flashing red 6 times....
the thermocoupler fuse is what it is called by the way. i also saw that it could be the "power board" which could or could not be synonymous with the thermocoupler. anyway, again it is a common problem with these models. Scott Jackson, MS
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
SOURCE: Flashing yellow arrow
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: DVD player will do nothing
Ok so I took the cover off to see if I could figure out the problem. Don't have a complete solution, but I did get somewhere. There is a silver cylindrical motor attached to the eject mechanism wheels on the VCR side. When I unplugged the tape from the back of the little motor, the progressive light goes out and the sound from the motor stops. When I manually turn the wheel/arm attached to the motor, the other wheels/gears turn and I can manually eject the tape. Also when I get to a certain point, my progressive light starts flashing like yours was. Anyway it all seems to be related to the little motor. I figure if you replace that, it would work. At least that is what I might try, I'll keep you posted.
SOURCE: VHS to DVD dubbing
You need to try to copy just some homevideo videotapes not movies. All them are copyprotected. Recording stops then copyguard is detected. It should be noted in the manual for this unit at page 47.
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/RDRVX555.pdf
Good Luck
