Question about Toshiba Satellite A75-S213 Notebook
Active desktop recovery
When i first log on the white screen with the active desktop recovery button in the middle of the page comes up and then after a second the normal desktop screen comes up and the flash back and forth. i can get into internet explorer but there is no toolbar at the bottom,the one with the sart button so i cant access programs.....any suggestions?????
    Problem Solver:
  • 6 Answers
It sounds like there is something causing the process explorer.exe to not start properly. Most likely a virus, but could be something wrong with windows itself. First of all, when you get to that white screen and there is no toolbar down the bottom, bring up the task manager (press control alt delete) and click the new task button down the bottom. Then type in explorer.exe and hopefully that will start up the toolbar down the bottom of the screen. you can also use the new task button to browse for any anti-virus program you have to run a scan to see what is causing the problem.
Posted on Oct 17, 2007
Very slow and I keep getting the white screen about restoring active desktop. Then it won't let me restore.
You will need to try reloading the operating system of the computer, this is on the recovery disks you should have made when you first bought the laptop. If you do not have the disks contact the manufacturers support site for details on ordering the recovery disks
Jun 12, 2012 | Acer Aspire 3634WLMi Notebook
My arcos no working teh touch screen so bad because for example u press a dive k d q etc
I believe you are trying to say that your touch screen isn't working. Your touch screen is probably locked. Its similar to a button hold lock, when this is activated, you can't press any buttons do anything unless you unlock it. To unlock the touch screen, press the ON/OFF button (don't hold the button for a long period of time. A message will appear on your screen asking for your conformation (approval) to perform the task. If that doesn't work, tap the TOOLS option, then select SETTINGS, and choose SCREEN. Once you've done that, choose the "Touch Screen Calibration" button and follow on-screen instructions given. If the second solution doesn't work, the "Touch Screen Calibration" option can be forced by using a feature called 'System Recovery'. To do a system recovery, Press and hold the Power button, then the Volume + button as soon as possible until you see a white screen, as system recovery is beginning. While this is happening, you will not be able to use the touchscreen to navigate between items. In order to navigate between items, you will have to use the Volume + & Volume - buttons and use the Power button to validate your selected task. The system recovery feature gives you a lot of options. Select the "Touch Screen Calibration" option and follow on-screen instructions given. I hope this activates your touch screen again.
Mar 22, 2011 | Archos 7 Digital Media Player
Hi, My desktop screen is white say this Active Desktop Recovery Microsoft Windows has experienced an unexpected error. As a precaution, your Active Desktop has been turned off. To restore the Active...
This could be a sign of possible issues. I would check the drive for bad sectors. I would run a test of the memory (such as Mem test86) and verify there are no problems.
Jun 28, 2010 | Microsoft Windows XP Home Edition
My uncle's hp compaq d530c will start up show windows starting then comes a black screen with white wording saying that you want start up normally? you press yes it takes you back to the windows xp trying...
Turn the computer off and then disconnect all the external devices like (printer,usb devices etc)connected to the computer along with the cable for the internet .Then disconnect the cable for power that would be right on top at the back panel of the computer tower and with the power cable disconencted press and hold the power button for atleast 30 seconds.Turn the computer on if it takes you to the desktop then it means that there is some external device that is causing the computer not to come up to the desktop so find which deveice has gone bad check it by conecting one device at a time.
Next thing that you can try is turn the computer off and then when you turn the computer on or as soon as you press the power button to turn the computer on start tapping the F8 key repeatedly until you get a black screen that says advance boot menu option .Then used the arrow keys on the keyboard and then hit enter,select the operating system and then when you get the log on screen select administrator .If it takes you to the desktop then you can try doing a restore by going to start?all programs ?accessories?system tools and then system restore ? select the date when you think that you r computer was working fine and then click on next next to exit from the wizard.Should fix the issue .
If it takes you to the desktop and the restore does not work then go to ?start?run?type in msconfig?when the system configurtation utility page loads up the go to the startup tab click on disable all?apply ?go to the services tab?disable all?apply and ok to close the page and then restart the computer.If it takes you to the desktop then go to msconfig click on enable all for startup ,restart the computer .If it boots up normally to the desktop then there is a service unders services that is causing the problem,so we need to isolate the service that is is corrupt .Select a group of services and the restart if it does not boot the computer to the desktop then there is one service among the group that is not letting the computer boot up so check one service at a time and check .Once the faulty service is found let it be unchecked will not be a problem.
If the computer does not boot up to the desktop then without wasting time on any trobleshooting steps recovery needs to be done that takes the computer back to its original factory settings.To do this instead of the f8 key tap the f11 key till you get the screen that says system recovery ?click next until you get the screen that has advance option ?click on it ?select destructive recovery ?click next the recovery will start and the computer will be formated (whatever you have added after you bought the computer would be lost ).If the recovery does not work this was then it needs to be done from the recovery disks and fot that you call call HP...
all the best.....
May 20, 2010 | HP Compaq d530c PC Desktop
Script error, active desktop in recovery mode, how do I fix script error says line 65
How to enable / disable windows active desktop. Question:How to enable / disable windows active desktop.
Answer:Microsoft Windows XP users
  1. Open the Control Panel.
  2. Open the Display icon.
  3. Click the Desktop tab.
  4. Click the Customize Desktop button.
  5. Click the Web tab in the Desktop Items window.
If you wish to enable the Active Desktop, check My Current Home Page.Add your current home page into your desktop or click New to addanother web page and/or other Active Desktop features. To update thecontent, click the Synchronize button.
If you wish to disable Active Desktop, make sure all checkboxes in this window are un-checked.
Nov 09, 2009 | Compaq Presario 5000 PC Desktop
Problem with the screen
get yourself a virus remover and install it on the recovery menue. how to get in ur recovery menu when u boot up ur computer hit f 8 than go in to the recovery menue and install it. u can also change ur settings were u dont have to go to the log menu in the biggininghope it help a little
Jun 29, 2009 | Dell E198FP LCD Monitor
This program will remove those antispyware
Mar 25, 2008 | Dell Microsoft Windows XP Home Edition
I Droped my player
See if the manufacturer has a recovery tool on their website. If not:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware.
Nov 27, 2007 | Zvue ZV002 Digital Media Player
Toshiba Satellite A75-S213 Notebook Logo
700 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
