Question about Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Line Trimmer pull start will not engage engine.
I actually have two craftsman line trimmers that you can pull the cord and feel very little resistance and nothing happens. It seems like the clutch will not engage the engine any longer. How can I repair this myself. The first time this occured I took my line trimmer to Sears for a repair. They repaired it but it only lasted three times and then it was back to not engaging again.
  • Anonymous May 25, 2009
    I have the very same problem with my flymo xlt 3000 multitool
  • John C Bridgers Sr May 11, 2010
    Hello mark_m_rhoad:
    >>From your Description it Sounds like the Starter Pawls or the Starter Clutch is Damaged and Requires Replacing.
    >>Send me the Model Numbers Off the Unit, Please. With these I can Locate the Proper Manual and Better Assist you.
    Thanks.
    Respectfully
    jbridger (John)
Hi I have a craftsman 4 cycle model no. 316.791970 gas trimmer. When I pull on the rode there is little resistance . I took the sparkplug out and put a flash light down the hole and there is a thing that is moving . What should I look next, or do you know what is wrong? Thanks for any help! I've had it only 3 years and already Sears have replace the clutch assy.
Posted on Apr 19, 2013
3 Suggested Answers
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 376 Answers
SOURCE: Craftsman 32cc Line Trimmer pull start will not engage engine.
With a flashlight, look into the area just in front of the pull rope. You'll see the fins on the flywheel. Turn the flywheel with a small screwdriver until you see a bracket mounted on it. There's is one on each side. While holding the flywheel still with another screwdriver, spray penatrating oil on each one and work them back and forth a few times. You'll feel them loosen up. They are spring loaded and should snap back into place. Hope you can understand this. Good luck.
Posted on May 25, 2009
Craftsman 32cc gas trimmer won't start.
Take out the plug and shoot a shot of starting fluid in it replce plug have a can of carb and choke cleaner to help it along until it picks up fuel spray by the air cleaner the carb and choke cleaner
Jul 21, 2014 | Craftsman Convertible 32cc Gas Line...
32cc trimmer stars but wont continue running
Hi donald, if your trimmer is starting but not running it sounds as if the problem is lying with either one of two things. Firstly locate the air filter and make sure it's clean. If it is then the problem is most certainly with the carbrettor. It may need the gaskets replacing to allow the suction from the engine to pull the fuel through.
Aug 31, 2013 | Craftsman 25cc Gas Line Trimmer
Repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Aug 24, 2009 | Craftsman 25cc Gas Line Trimmer
How to add more line in my craftsman 32cc
Invert the trimmer pull the center of the head straight off. Wind new line in counter Clockwise direction. There should be a hole or notch to place the center of the string in. insert each end of the sting through one of the holes in the head and reinsert the spool into the proper position. Be sure that the automatic advance is movable by pressing down and pulling out more string. Cut string to proper length and restart your trimmer
Jun 06, 2009 | Craftsman 25cc Gas Line Trimmer
May 25, 2009 | Garden
Have craftsman 32cc gas line trimmer it runs until given gas
May 04, 2009 | Craftsman Garden
Craftsman 25cc Gas Line Trimmer Logo
1,551 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
