Question about Philips 60PP9200D Television
Sparks We were watching TV and all of the sudden a loud noise came from the back of the TV. It sound like a popping/crackling noise. My husband moved the set to see were it was coming from and I turned the set back on there were sparks coming from a part (#313926720561) The tv is 14 months old and the date it has on it April 2006. We don't know what to do. please help.
  • cathy01 Mar 16, 2008
    We were watching TV and all of the sudden a loud noise came from the back of the TV. It sound like a popping/crackling noise. My husband moved the set to see were it was coming from and I turned the set back on there were sparks coming from the back.
  • Philips Master
  • 8,617 Answers
Thats the CBA board heres a link where you can get one but its expensive.
http://www.partstore.com/Part/Royal+Philips+Electronics/Philips/313926720561/New.aspx
Posted on Mar 24, 2008
Loud popping noise tv
EHT arcing takes place. Never switch the TV on, until this fault has been rectified. Doing so, will make too many other faults to occur. Contact any service technician.
May 23, 2013 | JVC AV-35750 35" TV
Watching TV and all of a sudden a loud pop came from the back of the set. Doesn't turn back on after unplugging.
Hello
Check its power supply regulator board. The pop sound you heard may be due to an explosion to any electrolytic capcitors on it. If the line voltage exceeds, this fault will happen. just repalce the damaged component. It is best to replace this board as card basis.
Mar 19, 2012 | Hitachi 50HDA39 50 in. Plasma HDTV
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
TV makes very loud crackling noise
crackling in the speakers of 42"flat screen tv
Jul 20, 2010 | LG 42LC2D 42 in. LCD HDTV
When I was watching the tv it suddenly started to flash off and on and then finally will not even turn on
Watching tv all of a sudden loud buzz noise,I shut off unit turned back on loud buzz came back about 30 seconds later loud pop pop then smoke came out of top of unit, i'm not please as this unit i bought about 17 months ago @ Canadian Tire Belleville & warranty is now not covered, pobably will never buy another Proscan product but am more concerned there could be a fire caused buy this than getting unit replaced
Apr 23, 2009 | Proscan 19LA20Q LCD TV
Loud popping noise
The 23" CRT set may have a high voltage breakdown in the flyback transformer or focus divider. Take the back off and operate the set in a dark room. Look for anything that has a blue glow around it or sparks flying when the pop occurs. I won't guarantee this will find your problem, but it is definitive if you see these!
I once had a set with these symptoms. I stopped the blue glow and arcing by covering the focus divider with epoxy. It worked for a couple of months before the divider literally broke apart.
Mar 02, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Crackling noise / loud static when tv is attached to antenna
Pick one:
RFI (Radio Frequency Interference) from nearby electrical/ electronic device.
Antenna misaligned to transmitter.
Antenna coax impedance mismatch.
Faulty connections.
Faulty antenna.
TV tuning.
If the OLD TV worked OK on same antenna it sounds like TV tuning or ANT socket/wiring loose.
Try:
Auto-tune TV with ant plugged in.
Get TVF (TV fundi) or friend to help align antenna.
Maybe a large bird sat on it.
Check coax for sunburn / deterioration. Renew if XX.
Oct 11, 2017 | Televison & Video
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
Cracking noise and flickering screen
Sounds like you have a bad flyback Transformer...Crackling is high voltage leaking. I would quit turning it on and replace the main board in the set if you are good at soldering you can replace the flyback transformer but cost wise it is easier to replace main board. 20" might not even be worth the repair.
Nov 02, 2007 | Insignia IS 20" TV040919 TV
Philips 60PP9200D Television Logo
290 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
